Question about Nikon Coolpix L11 Digital Camera
Lens error - Nikon Coolpix L11 Digital Camera
  • 1 more comment
  • Anonymous Dec 03, 2008
    the screen displays the message lens error without any evident damage to the actual lens
  • Anonymous Dec 31, 2008
    When I try to turn it on, it says lens error.
  • Anonymous Jan 12, 2009
    the camera was dropped and the lens will not retract and the notice on the LCD is that there is a lens error
    Problem Solver:
  • 14 Answers
I have a solution, Its a step by step solution with images. will be quite helpfulll
see link http://www.fixya.com/support/r1861862-solution_nikon_lens_cover_error
_mukesh
Posted on Mar 26, 2009
I just helped a friend with his L11.
The lens would go out and back in again and it said "Lens Error".
I disassambled it and inspected som poor fragile peice of electronics...
Why can't even brands I used to have faith in create hardware like cameras that would withstand to be carried around?
I figured it could be sand in the small plastic gears (since I'm from sweden and the cameraowner is from Arizona...) There was some small grains of sand in there but the mechanics were doing great.
Enough talking...
First: Take the batteries out and wait a long while. I don't know the risks involved with cameraflashes but please don't hurt yourself.
Solution: There's a little thin flexible "circuitbord" that runs around the lensmodule. It has a small white lable on it that is slightly wider than the "circuitbord" itself. Under the lable there's a small sensor. In the black plastic part of the lensmodule there's a hole for the sensor to point in. In my case the few square mm of sticky lable to hold everything in place couldn't hold it in place anymore. I glued that in place and the camera is working fine. This is all located between the lensmodule and the capacitor for the flash.
I suggest that you try not to disasseble anything else than the cover to begin with. I tried first to see if it was the problem by sticking a piece of toothpick in there to hold it in place.
If you need to proceed taking the camera apart you'd need to remove (soldering) the batteryconnections from the mainboard.
Other useful information. If the lens is moving in and out several times (not all the way) that's probably because of bad connection where the flatcable from the lens module reaches the mainboard.
Good Luck!
To Nikon I'd like to say: You used to have a good reputation. Good reputation is worth more than short term profit from bad compact cameras.
Best regards
Andreas
Posted on Dec 04, 2008
  • 477 Answers
It needs replacement. Send it in for repair around 65.00 to get fix or more depends on who you go through.
Posted on Apr 17, 2008
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
Tip
Sanyo digital camera showing lens error 1114 or 112
Hi.
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera had been exposed to sand or dust, try blowing canned air on the lens.
If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
on Apr 09, 2010 | Cameras
Lens error
Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Keep us updated.
Jun 03, 2011 | Nikon COOLPIX S200 Digital Camera
My camera say lens error 111000
Your lens problem is common defective. It need lens unit replacement or just repairable.
Try just some basic things first-just to make sure it's actually the lens that's broken. Replace the batteries with fresh ones. Failing that, replace the memory card.
Keep us updated.
May 31, 2011 | Kodak Easyshare C813 Digital Camera
Lens error, restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 14, 2009 | Canon Cameras
Jun 28, 2009 | Canon Cameras
Lens error= restart camera - this is the message I am receiveing from my cannon SX110 IS
May 24, 2009 | Canon PowerShot SX110 IS Digital Camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Lens error 25 and 15
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 25, 2008 | Kodak EasyShare C330 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
545 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
