Question about Onkyo TX-SR876 Receiver
I have an Onkyo TX-SR876 Receiver which is connected to Sky+ HD box throught HDMI. When watching certain sky channels I get random intermittant black screens blanking out the picture showing a 1080 scaling. This builds in frequency and on occasions switches to a grey 'noise' (no picture at all). Is this a problem with the Receiver or the Sky+ HD box? I have recently had the skybox replaced with a new one. This does not seem to have solved the problem, which suggests to me that it is a receiver problem. What can be done to solve it? I have no such problems with the Sony BD player.
  • Ian Summerfield
    Ian Summerfield Jul 04, 2010
    could be an incompatibility between the two.try connecting the sky box directly to the tv,and output the sound from the optical output of the tv to the amp.like i have done.you may have to just use component cables from the sky box to the tv,that way therell be no audio trying to get thru.just a tip
  • 6 Answers
SOURCE: cable connection to Onkyo TX-SR605 7.1
You will have to connect your coax to the tv coax input.You can view cable this way.To use the hdmi input to tv,you will have to change your input settings back and forth on the tv menu from hdmi to rf input.There is no way to hook your cable to the txsr.
Posted on Jan 09, 2008
SOURCE: Onkyo TX-SR605 conected to Mitsubishi DLP TV
What I think I did and how I fixed it!
FACTORY RESET ON EVERYTHING!
All you have to do is to do a factory reset on everything, but I thing mostly on your 605, but I would do it on the TV as well. I think what had happened is after I set everything up for the first time, it worked great. As the days when on I started to play with all of the futures the 605 and the TV had to offer. I was turning them on and off to see what everything did. What I think I did was, I turned on something in the 605 that the TV did not know how to cope with. If I had to guess, I think it is the Lip-sink feature (Spelling?) in the 605.
Anyway disconnect everything, look in your manuals of the TV and the 605 to see how to do the factory reset on both. Then turn your TV on. After it does it’s start up for the first time (again), start connecting the 605.
It has been working great for me after I did this. Do not count on help from the people you bought it from or the people who made it. This stuff is so new they do not really know how to fix it.
Robert…
Posted on Jan 27, 2008
  • 84 Answers
SOURCE: Problem with component input and 720p HDMI output
does your cable box have an hdmi output? if it does try an hdmi cable instead of componant cables[ i know the hdmi cables aren't cheap] if not, if the reciever has componant outputs, use them instead.
hope this helps
wg
Posted on Feb 02, 2008
SOURCE: Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Posted on Jun 02, 2008
Gurudristi
  • 98 Answers
SOURCE: onkyo tx-sr806 reciver ''DTS HD''
hdmi connection between player and AVR. Right?
I am sure you would have also done the first time setup and set all the 7 speaker as well as the subwoofer thru your auto or manual speaker set up and that the reason you are getting Neo6.
On your Receiver, please also check the format of the digital input signal thru "Displaying Source Information" Press the [RECIEVER] button, and then press the [DISPLAY] buttorn repeatedly to cycle thru the available information.
a).. If the information shown say that DTS - ES Discrete, DTS- Matrix, DTS -HD and so on.... then we need to check as to why the receiver is not accepting the signal.
b).If the information shows otherwise and a 7.1 signal is not availalbe, then its possible that the source(in this case the BD player/or the recording is not sending the required signal).
lets take the case (a). In this case if you have all the 7.1 set up in place and you are getting the required signal , then you can assign a default listening mode to each input source that will be selected automatically when you select each input source.
Press [RECEIVER] button followed by [SETUP] button and enter listening mode setup, use up , down buttons to select the input source that you want to set and press [ENTER].
then use [up], [down] button to select the signal format that you want to set.
then use the [[LEFT] and [RIGHT] buttons to select a listening mode.
When you are finished, you can press [SETUP] again.
The above is with experience with ONKYO AV Receivers. In case you have a problem , please let me know so that I can go thru the SETUP menu of your particular receiver i.eTX-SR- 806.
HOpe the above sort out. DO let me know.
Please do rate this solution and thanks for using FixYa!
Posted on Mar 05, 2009
Can you connection satellite sound to optical input
Yes you can run optical lead from sky box to receiver in the sky box setting you need to tell it that you are using optical and on the receiver u need to bind 1 optical with hdmi input this is done though input settings hops this help
Dec 21, 2013 | Onkyo TX-SR606 Receiver
Onkyo tx-nr509 Receiver not talking to Panasonic TV TX-L42E31B
Hello, I am sorry about your issue. If the cable is long from the receiver to the TV it may cause video issues. Please try a reset of the receiver by pressing and holding vcr/dvr and then on/standby. When display shows clear let go. The receiver will shut down. Turn back on and test. This procedure will take the receiver back to factory defaults. Thank you, CB
Mar 24, 2017 | Onkyo TX-NR509
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Lost colors when using composite cables with Wii
puedes subir o bajar la resolucion de tu t.v o pantalla ya que algunas son HDMI u otras FULL HD probablemente no este bien ajustada o los cables no estan funcionando bien o estan trozados,....
May 02, 2010 | Onkyo TX-SR607 Receiver
Got sky installed today only thing getting on screen is "no video signal"
Sounds like the "channel" you are trying to watch on is not the one it's plugged into, or a faulty lead.
check the connection from the sky box to the tv, and select the av or hdmi channel that it is plugged into on the tv.
check the lead by swapping it for a known good one, for example from a dvd or ps3, but unplug from the dvd/ps3 and plug into the sky box(make sure that all the units are powered off when swapping leads) and try on the channel you normally watch/use the dvd/ps3.
If you suspect the sky is at fault, press menu on the sky remote and then flick through all the av/hdmi channels until you find the menu, then try to reinstall/retune the sky box.
If that don't work phone sky......................
Dec 30, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
HDMI SOUND
True HD can only work with HDMI interface and is only available on some newer HD DVDs. Check the DVD to see if the True HD encoding is available.
Feb 11, 2008 | Onkyo TX-SR605 Receiver
What settings
What ever you want. the onkyo reciever allow you to select what input the hdmi inputs are assigned to.
you can assign DVD to hdmi 1, or 2, what ever you want.
Check the manual how to assign inputs.
Nov 07, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR876 Receiver Logo
100 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
