I have the HD LCD model 40X787. To program the channels I have to scan in analog and then the programing will associate it with the digital HD channels. What will happen after feb 2009 when there is no analog channels. How can I scan for channels?
  • bakervet Apr 18, 2008
    My HD TV is connected to an over the air antenna. I do not have satellite or cable. That is why it is so important that I find a solution to this problem.
  • 4,234 Answers
The only people effected by the changeover are those that use external antennas for TV reception. I am assuming that you use cable or satelite correct?
Dan
Posted on Apr 17, 2008
  • ABRsvcs Apr 18, 2008
    Based upon what I read in the manual, when the changeover takes place, the auto tuner will detect the lack of the analog signals but will detect the digital ones. You should not have any problems. This set is designed to pick up the digital broadcasts.
    Dan
I have a 20 inch panel sharp Aquos tv every time I try to auto program it, it say eds channels are not programmable in using a clear antenna.model number is LC20B6U-SM
This LCD was manufactured before HD signals were transmitted so It has an analog tuner that is why it isn't programming any channels. Over the air signals became digital 2009 so every TV was required to have a digital tuner to decode the new channels. If you still would like to used this LCD, you will require a digital adapter.
Copy and paste the this link for additional info:
http://www.consumerreports.org/cro/electronics-computers/news-electronics-computers/pulling-the-plug-on-analog-tv-206/index.htm
Sep 05, 2015 | Sharp Televison & Video
I have a Samsung hdtv but its not playing in hd.I have it hooked up to cable straight from the wall bypassing the cablebox.Is it the tv or cable?
You do not indicate if you have auto programmed the television to get digital channels, If you are selecting a channel without a decimal point, for instance 82.3 is NBC hd in my cable system. If your cable provider does not produce these on direct cable then you can not get HD without a box.
Try to Auto Program your tv in the cable mode STD format, this can take up to 20 minutes to complete scan including deleting scrambled channels. After programming try the lowest or highest analog channel like 2 or 70, channel down or up from there to see if any digital channels appear.
Mar 01, 2013 | Samsung Televison & Video
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Can't program digital channels only has analog option
If your TV does not have a digital tuner, you'll need a digital converter box.
After the digital switch in June, did you have channels then? If so just do a rescan.
Jan 11, 2010 | Broksonic CCVG1935 19 in. LCD TV
My 47" LG has an internal HD reciever but it isn't picking up any HD channels.
Is it connected to an antenna? Did you do a channel scan for digital channels? See www.dtvanswers.com or http://dtv.gov/iguide.htm for more information.
Sep 03, 2009 | LG 47LC7DF 47 in. LCD HDTV
Can't get HD channels after voncersion
The "HDTV ready" TV only has analog tuner included. That unit can be used with external HDTV tuner to receive digital television.
Jun 15, 2009 | Mintek DTV-263 26 in. LCD Television
No audio on some hd channes
Try pressing the MTS button on your remote while on the channel that does not have audio and select stereo. Most likely this will be set to SAP (secondary audio programming) and there is no SAP programming on that show. This is not something that could be avoided. It was during the channel scan, it locked in the SAP audio broadcasts for some reason.
Apr 03, 2009 | Vizio VW42LF 42 in. LCD HDTV
Digital channel signal blue screen only
Press the "INPUT" button and make sure "TV" is highlighted.
Mar 21, 2009 | Vizio VX20L 20 in. LCD TV
New TV doesn't register being HD ready during test TV stations do
Try going into the setup menu and make sure it is set to antenna then do a channel program. You don't need to wait for a test there are plenty of channels already there. Both digital and analog channels are still available so you will still a message that you are not receiving digital if you are putting it on an analog channel. The channel number has to have a dot(.) in it like 8.1, 24.1 If there is no dot you are on an analog channel
Mar 13, 2009 | Westinghouse Electric W1603 15.6 in. LCD...
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
