Question about Kyocera Mita FS 1010 Laser Printer
Hi! Im just wondering for what use the (compact flash) memory card is, when installed in a Kyocera Mita FS-1010? (Beside firmware updates)
  • 29 Answers
Found this in a manual.
Insert the memory (CF) card into the card slot located on the rear of the printer. A memory card is a microchip card that may contain option fonts, macros, forms, etc. The printer reads the contents of the card into its internal memory when printer is turned on. The presence of this data in the printer memory can be confirmed on the status page printout. For details of available memory cards, contact your Kyocera Mita dealer.
1 Turn off the printer. Never insert or remove a memory card while the printer power is on. Failure to turn the power switch off will immediately halt the printer with the four indicators turned on. It also could result in damage to the printer’s electronic parts or the memory card. Turn the power switch on again to restart the printer.
The only thing I have seen it used for (other than firmware) is to store certain info or fonts for forms (ex. tax paperwork or medical).
Hope this helps.
Posted on Aug 24, 2010
Kyocera fs-1010 printing problem
Specify the type of paper you are using in driver preferences.
Oct 14, 2015 | Kyocera Mita FS 1010 Laser Printer
Hi, I have a problem with my Kyocera FS-3900DN. The display shows the fault 7410:0043899. How can I fix it? Thanks
Will just reflashing the firmware fix this?
I have replaced the EEPROM (as per my post near the top) on a few of these, so that the printer will come to ready and then flashed the EEPROM via parallel port with upto firmware.
skyp techbelkin
Dec 19, 2010 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
I want to change the IP address of printer
try this one...used cd installer with network settings in your controller the installer im talking you about is the installer on your printer....
Oct 19, 2010 | Kyocera Mita FS 1010 Laser Printer
Kyocera FS-C5030N KX firmware update tool
you are overcomplicating it... all you need is a compact flash card big enough for the firmware... then you upload the firmware to the card and stick the card into the printer... but first power down printer and plug it out and then turn it on and follow the display... it will prompt you
here is the steps...
you will see ready
then press menu... arrow down to memory card
press forward arrow
you will see format
press enter
you will see processing
when its finished
you will see ready...
turn off machine... unplug it...
pull out compact flash
plug machine in
turn it on...
the **** for the compac flash is on the right hand side at the bottom by the ventillation opening...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Oct 09, 2009 | Kyocera FS-C5030N Led Printer
Kyocera Mita FS 1010 every few days it prints out all the pages
Format the harddrive, or go to the properties and change the setting that says leave copy on the harddrive, if all this not working try to initialize the memory and you will be fine.
double check on the driver properties check if it says direct printing or it keeps any copy on the machine.
Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Feb 13, 2009 | Kyocera Mita FS 1010 Laser Printer
My Kyocera fs-3900dn has the message: call service 0150:0040557. What does it mean?
0150 - Engine PWB EEPROM error. Detecting engine PWB EEPROM communication error.
Solutions:
1. Switch the printer OFF; unplug the power cable; wait 20 seconds; plug in the power cable; switch the power ON, If the error comes back follow the next solutions:
2. Update / Burn the latest firmware version. You may need to call a Kyocera Service Provider because you need a CF card (compact flash memory card) and the FIRMWARE.
3. Replace the Engine PWB (a board) - again you have to call a Kyocera Service Provider.
Dec 30, 2008 | Kyocera FS-3900DN Laser Printer
Kyocera FS-3830 with error F030
Try www.kyocera.com and look around for links to software upgrades.
Nov 30, 2008 | Kyocera Mita FS-3830N Laser Printer
Kyocera fs1920 problem
F030 = main controller PCB System Error (frimware upgrade required)
do you have access to a Compact Flash Card & a Card Reader / Writer?
or is the printer connected via Parallel?
Nov 08, 2008 | Kyocera Mita FS-1920 Laser Printer
Looking for Kyocera Mita Ecosy FS-1010 Instruction Manual
A downloadable copy of the Kyocera Mita FS-1010 user manual is available here.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 12, 2008 | Kyocera Mita FS 1010 Laser Printer
Kyocera Mita FS 1010 Laser Printer Logo
141 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
