How do we get to the switch to replace it...do you have to take the whole back of the machine off and go in that way?
    Champion:
  • 274 Answers
If the top does not come off then yes its in the back
Posted on Jul 05, 2010
On and off switch has Been pushed in slightly but still works Miele W3623 wash machine. Is it possible buy a new switch
replace the whole display panel or can buy the switch
Tony, It looks like Miele wants whole panel replaced on the washer.
Miele Customer Support Product Manuals Brochures
Mar 31, 2016 | Miele Washing Machines
The on off switch won't move
the electronic modul has the switch on it build in ,in the first models there where modifications by this module , but thats a 3 years back , or there is only to much dust fine grit-dirth inside , open the 3 screws
blow the whole machine out with a compressormeanwhile move through the switch slide back and forth and spray some wd40 below the switching slide, look first by replace the electronic to the position of the switch if remount the machine .
Aug 10, 2015 | Fein FMM250Q Select Multimaster...
Machine wont agitate
Could be several things, is the machine filling up with water?
1st thing is the water level switch, inside at the rear of the machine, If water is not detected then the machine won't start.
This is probably the cheapest and easiest to replace first.
Isolate the machine from the mains, lift the whole top lid (insert a flat blade 4" from each side at the front top seam to release).
Lid will tilt all the way up and back.
Switch is rounded about 3" diameter at the back behind the drum, 3 wires with a small hose attached, replace keeping all the wires in the correct places and re-attach the hose.
Does the machine spin - motor OK
Nov 29, 2010 | Admiral AW22 Top Load Washer
Need to replace spin switch on Kenmore 110.26832690. Have switch but can't get to it.
you would need to remove the outter base,,,,first unplug machine,then remove the screws on the control panel each end,,some machines you have to remove the panel end caps to get at the screws,,,then pull the panel forward a bit and flip it back it has plastic hinges on top so be careful,,then you can unplug the lid switch,,pop off the 2 gold clips with a screwdriver that hold the base to the back panel,,,,then open the lid reach inside the rim pull the back of the base up and towards you and lift off ,,,if you look inside and pay attention to how it comes off the bottom frame it will be a whole lot easier to put back,,,once the base is off you can replace the lid switch then reinstall the base,,, don't forget to plug the switch back in!
Mar 07, 2010 | Kenmore Washing Machines
My pfaff 1222 SE has a broken switch. I don't
I foud the correct power switch for your model (I have the same machine). This is located under the dark brown plastic cover. You can buy it on ebay and the item # 360066934338.
Jul 15, 2009 | PfaFF Creative 7570
Washing machine will not drain or spin.
HELLO: YES THE LID SWITCH IS BAD. TO REPLACE THE LID SWITCH YOU MUST REMOVE THE COVER ON THE MACHINE. FIRST REMOVE THE TWO PHILLIPS SCREWS FROM THE CONTROL CENTER ON TOP BACK OF MACHINE . TILT BACK THE TIMER AND CONTROL CENTER GENTLY. THERE ARE TWO FUNNY LOOKING LID RETAINER SPRINGS THAT HOLD THE ENTIRE THREE SIDES OF THE MACHINE TOGETHER REMOVE THESE WITH A FLAT BLADE SCREW DRIVER. REMOVE THE POWER PLUG FROM THE WASHER UNDER TOP. SLIDE COVER OFF MACHINE THEN REMOVE THE TWO PHILLLIPS SCREWS FROM THE LID SWITCH ASSY. UNPLUG SWITCH FROM COVER AND REPLACE WITH NEW UNIT . THERE IS ALSO ONE GROUND SCREW 5/16 THAT WILL COME OFF FROM UNDER NEATH THE COVER. THIS SOUNDS A LITTLE COMPLICATED BUT THE WHOLE PROCEDURE CAN BE DONE IN LESS THAN 10 MINUTES. THANKS FROM RUSTY AT RVANS@NETZERO.NET
Jun 08, 2009 | Whirlpool Washing Machines
I do not know how to remove the top from my whirlpool washing machine to replace the lid switch
Unplug the machine.
There is a screw at the bottom of the console on each end of the machine, remove them.
The console should then lift up and roll over the back(just make sure its supported or suports its self).
At the center of the machine there is a white plug, for the safety switch, unplug it.
On each side of the machine there is a brass colored clip, use a flat screwdriver and insert it into the front of the clip, push back smartly, this will release the clip. PAY ATTENTION to the way the clip comes out. (which end is the front of the clip) mark things if your not too handy so it goes back together easly.
This machine is put together alot like a puzzle so paying alot of attention to what you do will alllow you to put it back together.
The whole cabinet rolls forward, the sides along the bottom sit on an edge on the bottom, but the front is hooked UNDER the bottom edge. try to notice this. as you rotate the cabinate the front will fall free after you rotate the whole thing over about 45 degrees. The back will kinda float.
Apr 08, 2009 | Kenmore 24032\24036 Top Load Washer
Lid switch
pop the top of washer open the whole top this should go back with screw driver
under lid the switch is right there replace accordingly
Jul 04, 2008 | Kenmore 22422 Top Load Washer
Fix it myself
Hi
You are on the way.  Since you have the switches laid back now with clear space in front of the washer.  Remove the Screws from the back and roll the whole Body forward.  This will expose the inner workings of the washer for you.  I like to bring the washer out of the house to an open area to do this.  It makes the job a whole bunch easier. The lid does not pop up.
Nov 01, 2007 | Roper RAX7244KQ Top Load Washer
How do you replace lid switch?
Crispy, the whole cabinet will lift off, I will attach a diagram, the only difference is your model will have the consol screws in back...Catriver, post back.
Aug 16, 2006 | Whirlpool LSQ8243H
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
