Question about ASUS M2N-VM DVI - Motherboard - micro ATX - GeForce 7050PV - Socket AM2 - UDMA133, Serial ATA-300
Raid 1 Degraded error message
Changed motherboard from M2N-PV-VM to a M2N-VM-DVI. When I rebooted the system I got the Raid is Degraded message. Selected the disk from the F10 dialog box and Windows starts for about 1-2 seconds and then does a reboot.
  • jjflory Jul 05, 2010
    One of the options for the RAID 1 is to build a new RAID. Does anyone know if this will wipe out the existing Windows install and all my files?
    I have a backup drive but I dont want to reinstall all my software.
wombiro
  • 17 Answers
SOURCE: Asus A8N SLI RAID showing both drives as "degraded"
This problem usually occurs if: 1) The computer never finished booting 2) A sticky button on you keyboard (F8 or Control Key for win98) 3) Less Memory for windows xp and ME. Try checking if all the memories as well fixed on the board and are being read. 4) Corrupt system files. 5) Incorrect bios configuration (Try changing the bios settings to optimum performance of fail safe to confirm that. All the best.
Posted on Aug 25, 2007
SOURCE: ASUS P5B-VM DO Motherboard
Please update your BIOS if necessary to do some fixes, optimization, and even hardware or software support.
Posted on May 29, 2008
  • 153 Answers
SOURCE: raid 1 problem
When you are booting your machine, notice the prompt to press keys to get into your RAID controller. Press them and get in. You have to tell it that you want to use that new drive to rebuild your array. You really wouldn't want it any other way. Then when you boot windows it will be able to rebuild it and the message should become one of happiness, given adequate time to rebuild.
Posted on Apr 21, 2009
  • 4 Answers
SOURCE: M2A-VM random reboot
there is no windows xp sp3.all sp3 are made by hackers which used to hack the systems easily.so please change ur operating system and also uncheck the My computer(right click)->properties->advanced->startup and recovery,uncheck the automatically restary.
ur problem may be solved.
Posted on Jun 04, 2009
mattofilms
  • 110 Answers
SOURCE: were can i download ASUS M2N-VM DVI - Motherboard
try this site if you wish to scan your computer for missing drivers.
http://drivers.softpedia.com/get/BIOS/Asus/Asus-M2N-VM-DVI-Bios-0113.shtml
OR
downloadable driver:
http://www.howtodrivers.com/model550236.html
Posted on Jul 06, 2009
No monitor signal on my m2n-vm dvi after installing my new graphics card asus en210.The graphics card was tested on my other pc and works fine..any help?
First boot the computer without connecting Graphic Card, then go to BIOS and find for VGA option change the option to compatible mood, save the setting and come out of it. now off the computer re connect your graphic card and start the computer.
Aug 15, 2012 | ASUS M2N-VM DVI - Motherboard - micro ATX...
What type of battery does the M2N-VM DVI motherboard use?
Most motherboard BIOS batteries use a 3 volt lithium battery, this is a coin size battery type CR2032
Apr 06, 2012 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Hi i have an asus M@n68 vm motherboard. After i have flashed the bios from 0306v to 1006 i was told to reboot but when i reboot it my pc wasn't unable to start can u plz help
sounds like your bios has corrupted.
if you know anyone with an eprom programmer they can remove the chip and re-flash it.
if this is the case there is no-other way to fix it.
May 06, 2011 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Cannot install audio device for my motherboard M@N-VM DVI
First of all make sure you have original(health) diver. Check them on ASUS support page. To do this go to http://support.asus.com/download/download.aspx?SLanguage=us-us Select your products(MOTHERBOARD) Select Series(LGA775) Select Model(M2N-VM DVI) Then select your OS Then find your AUDIO DRIVER.
Then try installing it. If you still get error, let us know about error( error number, what kind error it is...)
Mar 27, 2011 | ASUS M2N-VM DVI - Motherboard - micro ATX...
I need all lan and wan and audio drivers for the M2N-VM DVI
Here is the website with all drivers and you just have to chose the operating system (windows xp , windows 7 etc)
http://www.asus.com/product.aspx?P_ID=fyD1uSu233yBDeCq
Mar 05, 2011 | ASUS M2N-VM DVI - Motherboard - micro ATX...
No monitor signal
have you tried checking the monitor to another computer? it could be the monitor?
if not, could be the graphics/video card, or even the motherboard itself could be faulty!
Jun 19, 2009 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Raid 1 problem
Apr 21, 2009 | ASUS P5GD1-VM Motherboard
I have asus m2n-e board, i used 80 gb hard drive in sata 1 socket, used 4 hard disk of 250GB in from 2-5 ports and used 320 gb hard disk in port 6, configured 4 250gb hard disks in raid 5 using the mother...
USE DIFFERENT PORT FOR PROBLEM OCCURED HARD DRIVE AND CHECK SAME PROBLEM CONING TO THAT PORT ALSO .THEN THE PROBLEM IS WITH YOUR HARD DRIVE .REPLACE IT.
Dec 31, 2008 | ASUS M2N-E Motherboard
CMOS Checksum error.
the only thing i can think of is when you changed the battery somehow the board terminals positive negative are not in proper contact with battery
did you try resetting bios by the pins on the motherboard
somewhere on the board is printed bios reset or words to the effect
most times it is a 2 pin connector with a jumper only on 1 pin connect the jumper across both pins remove and try to reboot
hope this helps
Jul 14, 2008 | ASUS M2N-VM DVI - Motherboard - micro ATX...
ASUS M2N-VM DVI - Motherboard - micro ATX - GeForce 7050PV - Socket AM2 - UDMA133, Serial ATA-300 Logo
193 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
