Question about Samsung 760BF (White) 17 inch LCD Monitor
Going to sleep
I switch on PC and monitor Samsung 760 BF starts to show analog/digital/analog/diginal. At the end it goes to sleep. I use a digital/digital cable.
What can be the problem, please?
Problem not in your monitor, but in your videocard, I've got the same. Your videocard overheats and your monitor shut down. You need to check cooler on your videocard. Maybe it full of dust. Sorry for my bad english) hope it helps to someone.
Posted on Feb 09, 2013
SOURCE: problems with digital cable
Check the source on the monitor, there's a button for it on the front.
Posted on Apr 23, 2008
yooperbud
  • 8637 Answers
SOURCE: Analog and Digital.
Your monitor should have come with two cables. One is for analog and the other is for digital and is rectangle. Before turning on the computer connect only the Digital cable to your monitor and the video card on the computer. Most monitors will automatically seance the Digital and operate when you start up the computer. Make sure the monitor is ON when the computer starts. Your manual should have instructions that will help.
DO NOT CONNECT BOTH CABLES UP. Only the one needed.
Hope this helps. Bud
Posted on Jan 26, 2009
SOURCE: Samsung 2233 stuck in analog
in your mon there will be small left arror image in box called enter button,,,,if u press that button its shows analog and digital in that have to choose digital.....
Posted on Apr 25, 2009
mahjid
  • 202 Answers
SOURCE: when the monitor is turned on it displays
check the data cable from the CPU to the monitor, it measn the monitor did not detect any signal from the CPu, or the system is not booting. Good luck
Posted on Sep 11, 2009
  • 1768 Answers
SOURCE: samsung monitor flickers on digital but not analog
1. this may be due to cable select and or cable not being secure at connection point
2.check your instruction manual for proper setup for digital signal to the LCD monitor and the to your video source.
Posted on Mar 27, 2010
Monitor goes to sleep immediately after turning on the computer. How can I fix that?
go to start,then pc settings,then monitor or power options the to power and sleep and change on plug to 4 hours and on battery to 10 minutes
Jun 11, 2015 | Computers & Internet
Auto detect analog
You can try reseating Monitor Cable on both ends.
Test Monitor on another Tower/Desktop PC? Vice Versa.
Let me know if it works
Thanks
Jan 14, 2014 | Dell Computers & Internet
Monitor will not awake from sleep mode. Pilot light is amber when asleep. If the monitor is turned off pilot light goes from amber to off or black or nothing. Turning the monitor back on the pilot light...
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
Sep 03, 2017 | LG L196WTQ-BF 19" Monitor
Monitor wont come out of sleep mode
I'm guessing you are using a the VGA input of this monitor (the smaller "D" shaped connector with 15 pins) on the back. If not, and you are using the DVI input (larger white connector), then check your PC video output. I've seen this occur with HP monitors when they accidentally get set to "digital" input. Its easy to set that way (even by mistake), but not as easy to reset to analog (VGA). To do that, you'll need to find someone with a DVI output on their video card. Once you connect to a DVI source, the monitir will come on and stay on. You then need to go into the menues of the monitor, find the setting and change it back to "analog". After you do of course, you won't get an image on your monitor until you reconnect to an "analog" (VGA) source.
Jun 02, 2010 | HP w1907 LCD Monitor
Monitor goes black when i turn it on
just a big hardware problem in your monitor
Sep 23, 2009 | Samsung SyncMaster 216BW Monitor
No analog signal
Sounds like the graphics card is gone belly up. Try the monitor with another pc or just replace the graphics card.
Hope this helps
Jun 12, 2009 | ViewSonic VX2235WM Monitor
New LG 2452T keeps going to digital power saving mode
i had the same problem.
connect the monitor with the analog cable and shut down your pc.
while it is off unplag the analog cable and place the digital one(dvi).
this should fix your problem m8 ;)
Feb 28, 2009 | LG Flatron L2320A 23" LCD Monitor
Monitor stuck in sleep mode
It will do this when it's not getting a video signal from the computer. Make sure that the signal cable is firmly plugged in at both ends. Also verify that the computer is actually starting up. The monitor may not be getting a signal because the computer isn't sending any.
Sep 25, 2008 | Compaq TFT5015 15" LCD Monitor
Monitor
Double check the monitor cable, both going to the monitor, and going to the computer. Ensure it's securely connected. If this doesn't change anything, try rebooting your computer. When the power light flashes, it's in sleep mode and doesn't detect either an analog or digital signal - so either your computer has gone into sleep mode (you can awaken it by hitting any key or moving the mouse) or the cable isn't attached securely. Since your computer is brand new, it's unlikely that anything has broken down already. Another thing to check is to make sure that the resolution in your Display Settings is the correct resolution for the monitor - although it's hard to do this if you can't see what you're doing.
Best of luck, hope this helps!
Jun 07, 2008 | Gateway FPD2275W LCD Monitor
Samsung 760BF (White) 17 inch LCD Monitor Logo
102 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
