Question about Element Electronics FLX3210 32 in. LCD TV
Had the same power issue as everyone else. I replaced the contol board. Then got a picture that was so wacked out, like watching a negative. Replaced the T-Con board but still the same. Remote does not work either. What else could I try?
  • 11,361 Answers
Are you getting clead DC voltages from the power supply? Power supply is always the fisrt palce to check when work on any electronics, no clean steady DC you will get a lot of strange problems.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 04, 2010
I have a Samsung Model HPT5054X/XAA 50" plasma TV. the picture went black but still have audio.I purchased a reman Y sustain board.The Y buffer boards looked good. Now when I reassembled the unit,st
Did it work with the Y-sustain board replaced? Likely if it did not work then there is an issue with the capacitors on the Y-sustain board and the power board. Check these caps for failure and replace them with the exact type. Likely the caps are blown and cause voltage loss in one or both boards.
Feb 01, 2015 | Samsung HPT5054 50-Inch Plasma HDTV
Negative picture,lamp indicator flahing 3 minutes after turning tv off
sounds like your system board is really shot ....did you have a power glitch recently? got backup?
Feb 11, 2008 | Sharp 65DR650 65" Rear Projection...
Sharp 52" LCD-Negative picture
hi bring the menu up if it's the same as the picture, the mainboard could be the problem, also can be a bad panel thanks
shaun
Mar 04, 2017 | Televison & Video
I have the dynex dx-lcd32-09 model tv.One day I was watching ashow on tv and all of a sudden the picture went white,But can still see the image.I tried everything from turning it on and off to back on...
The T-con also called LCD contoller board needs to be replaced. You can check this link to find the part for your LCD. This board is located in the upper middle part on the screen under a metal shield.
I would suggest to contact them first before order the T-con board.
Sep 14, 2010 | Dynex DX-LCD32-09 LCD TV
With no picture but only sound on my Akai PDP 4294
Try replacing the Y-sustain board. Might have to replace buffers attached to it too. Have you had it diagnosed? My picture went out and I replaced the power supply board. Worked for 2 weeks then acted up again. Got a different power supply board. Same thing 2 weeks later. Was told it now was a bad Y-sustain board. Replaced y-sustain board. Worked OK for about 2 hours then started having picture issues. Not the same issues before power supply or y-sustain problem. Was told that you might have to replace buffers attached to y-sustain when you replace y-sustain. Tired of dealing with it and only watch a couple hours a day, so I don't always have the problem unless I watch the TV for a long time. Will eventually replace buffers to see if that works. I would definitely find a place that gives free estimates or close to free to get a technician diagnosis. Then you can decide if you are able to do the work yourself.
Jun 06, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Picture problems
OK to help assist everyone having the BLUE HUE and CURVED LINES Issue on their Rear Projection HDTV no matter their model. Here are the steps to take. The first thing to check is the FOCUS BLOCK or G2 Focus Transformer or CRX F-Pack. I have replaced mine, however it didn't resolve the issue. I am onto the next item the CRT Board for Blue (Which is the board under one of the three color lamps inside your tv) Please see photo below (if photo is not large enough below go to link to review notes as well) If the CRT Board is not it, then the next step will be the Signal Board which is a larger board in the back. In a week I will have a picture of both.
INSTRUCTIONS:
  1. Remove the outside cover
  2. Remove the wood plank/panel
  3. In the front is the G2 Focus Block/Transformer, while set is on turn the top 3 knobs till the screen goes black/dark grey.
  4. adjusting the colors till you receive the desired or normal color/picture.
  5. Once you have received the proper color/picture tap the side of the Focus Block.
  6. IF The colors go out of wack again and the blue comes back strong then this "CAN BE" the Focus Block.
Replace the G2 Focus Block aka Focus Transformer, if Hitachi it's called a CRX F-Pack. This item will cost about $50. Not expensive. You will likely need a soldiering iron. DO TURN OFF & UNPLUG THE TV WHEN INSERTING ANY METAL OBJECTS INTO THE TV!!
FOLLOW THE PHOTOS/DIAGRAM in link below for assistance in the above instructions. I will post my next process since it was not my Focus Block that was an issue.
ONE SOLID PHOTO Go to URL CLICK HERE, click on that image to enlarge. Hope this helps you all out!
Mar 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
No picture or sound
INSTRUCTIONS:
Feb 23, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
Toshiba 42PW33Q rear projection gone blue
INSTRUCTIONS:
  7. NOTE: IF the color stays stable, then you problem is resolved and you do not need to replace it.
Nov 18, 2007 | Sony KP-57WV700 57" Rear Projection HDTV
Blurry picture
you probably have a bad convergance board you can get one at partstore.com but if the color is realy out of wack you will need the board it is very easy to install even for a novice unplug the set take off the lower back hte board is on the upper right only one screw and a couple of plugs but first try to adjust the lens have someone watch and loosen the wing nuts and turn the lene,s slowly one at a time i started with the red one you need to have the set on when you do this i replaced the board first works great now
Nov 12, 2007 | Samsung PCN5425R 54" Rear Projection...
Element Electronics FLX3210 32 in. LCD TV Logo
155 people viewed this question
Top Element Electronics Televison & Video Experts
Josh Whitehead
Josh Whitehead
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
