Question about Kenmore 21.0 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
The freezer section has quit freezing but fridge is cold. It looked like someone had left the door open and things started to thaw. It is a Kenmore freezer on the bottom style. It was a Hand me down so I am not sure how old it is. There seems to be a lot of water dripping which I assumed was the ice maker, so I turned the water off while I try to get his fixed
HVACRH20
  • 237 Answers
SOURCE: water dripping from freezer to fridge
Sounds like the drain for the defrost cycle water may be plugged and you eventually overflow water. See if you can find the little drain hole for the coil defrost water and check for dirty/plugged. Try to pour hot water in the drain area and see if it runs out the drain fast (if real slow it's a problem). Make sure the water is also going down to the holding pan near the bottom area/compressor area (that's where it evaporates later). Let me know what you find.
Posted on Nov 30, 2006
SOURCE: freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Posted on Apr 20, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Posted on Apr 28, 2009
bobicehouse
  • 1524 Answers
SOURCE: Freezer quit working on '04 Kenmore Trio Elite 25' bottom
Can either be starting components for compressor, or Motherboard.
Posted on May 04, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
Freezers high tempeture light is on and freezer is not getting cold
Door left open usually starts a defrost failure, the evaporator gets blocked with frost and the fan motor can't circulate cold air into the fridge section- while the freezer fan is running, put your hand in front of the slots where the cold air should be blowing in the fridge section- if you don't feel air flow, you have a blockage. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Kenmore Refrigerators
I have a 23' free standimg dispensing side by side ref. my ref is not cooling but the freeze part is working
when you open the freezer door do you hear the fan blowing?all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer and into the fridge side,there are ducts on the bottom left side where the air return sto the freezer,if that's blocked the fridge will get warm,also if the fan is blowing depending on your model you could have a damper,it's in the fridge section up top where the cold air blows into,all it is is a door that opens and closes to let the air in when the fridge section gets warm and then it closes when it's cold enough,if the damper is bad it won't open and let the air in,sometimes it gets stuck in the open position and things start to freeze in the fridge section.if you can't figure it out send the model number and i can see what model you have,open the fridge door,look up on the right side near the ceiling and you should see a tag with the model number.good luck and have a great weekend.also from the bottom up in the freezer,remove the second bin of food and touch the back inside wall of the freezer,if there's frost or like snow on the back inside wall of the freezer you have a defrost problem,let me know what you find.
Aug 07, 2012 | Kenmore Refrigerators
Everything is freezing in the vegetable drawer
For this problem, its indicating towards problem with damper assembly.----------
The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is remained open, its not closing.Due to this the cool air from freezer section is running in to fridge section non-stop.Due to this the vegetables and other food in the bottom drawer freezing.--------- In this problem the damper assembly needs to be replaced.---------------
This should help.Thanks.Helpmech.
Oct 31, 2011 | Kenmore Refrigerators
Freezer side is working fine. the fridge side appears not to be as cold as it use to be. a few days ago my kid left the door ajar all night. how ever it should be cold by now. there is power I can hearthe...
When a refrigerator door is left open the freezer will continue to run to keep it cold and since it can't cool an open area it will freeze up on the inside, to resolve this you will need to unplug the fridge and open the freezer door and allow the freezer to thaw completely, once it is thawed you can plug it back in and everything should go back to normal after a 24 hour period
Jun 28, 2011 | Kenmore Side by Side Refrigerator
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
The freezer works well but the fridgedoes not get cold enough
all the fridge does is blow cold air from the freezer down into the fridge section so if the freezer is working then either the evap fan isn't working or the air ducts are frozen up.first thing open the freezer door,you should hear the fan blowing,if not the fan motor could be bad,if it is blowing,touch the back inside wall of the freezer,is there any ice or like snow on it,if so you have a defrost problem,one more thing to check,open the fridge door,look under the bottom draws,is there any water there? or any water dripping into the fridge section from the freezer,if so you have a blocked drain and the air ducts are frozen.let me know what you find,send the model number off of the fridge,open the fridge door and look on the left side up near the ceiling,you should see a tag with the model and serial numbers just send the model
Jun 05, 2011 | Kenmore 21.7 cu. ft. Top Mount...
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 04, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
My side by side kenmore refrigerator, freezer isnt freezing
the fan in the freezer is not working to blow the cold air in the freezer you need a new fan you need a repair man it will cost you $300 good luck i have the same problem don't buy samsung they are useless that why home depot don't sale samsung
Nov 12, 2009 | Samsung RS265LABP Side by Side...
Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Aug 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kenmore Elite 106-74202402 Freezes food ice solid in the fridge
Hi
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
29 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
