Question about Xtatix XCA-PP2A Webcam
Now ive tried plugen into another computer... message came right up load disk, ard ware new hardware found
  • 6,993 Answers
before you insert the web-cam into another computer, make sure you install the driver first. If you install the driver on the computer, the computer will automatically install the web-cam and will not ask you load to load disc.
The disc is requesting for is the web-cam driver. So install the driver first, then insert the web-cam after that, and the computer should install the web-cam.
But make sure you install the correct driver for the web-cam.
Good luck.
Posted on Jul 04, 2010
Cannot view documents on the Ydrive of my external ard driv
Control Panel, Administrative Tools, Computer Management, Disk Manager, in the right panel right click on the disk, assign new drive letter e.g Drive Q
Dec 04, 2013 | Iomega (33090) 250 GB Hard Drive
Hello, ive just bought a brand new motherboard (GS7610 ULTRA) and i have installed it into my case with all my components and when i go to start my computer up, it goes pasted the boot menu and then i get...
Are you trying to install this OS (Operating System) , or is it already installed on a hard drive?
If you are installing it, make sure you change the boot order to the optical drive (DVD drive). If it's already installed, was it installed with an OEM disk? If yes, then you might need a new Windows XP disc. This is because, when using an OEM disc, if you change the hard drive or motherboard, it doesn't really work.
Sep 24, 2011 | EliteGroup GS7610 ULTRA Motherboard
As I am loading my copy of Printmaster 16 Silver, I get an error message that stops the process. I now have a new PC that I need this installed on. Same as old PC, XP Professional operating.
Make sure you dont have ANY anti-virus, ad-ware, spy-ware software running. Ive found that Broderbund products do not like them running in the background while installing. If youre afraid of internet viruses, just disable or unplug your network cable while installing.
Sometimes running in safe mode, may correct this problem also.
Nov 30, 2009 | Broderbund PrintMaster Platinum 16
My computer will not install the wireless USB software. I need help. I get through the first couple of prompts and then it just looks like it keeps loading but does not.
What is the operating system on your computer. If it is windows XP or VISTA, then try to install the adapter using the found new hardware wizard.
Do not run the disc that comes with the wireless adapter. connect the adapter to the computer first. you will get the message found new hardware.
if you do not get the message that means the adapter is detected by the computer or the software might be installed already. uninstall the software and then connect he adapter.
If you get the found new hard ware message then it will ask you can windows connect ....
select = no not at this time and click next.
on the next window select the option install software automatically and insert the disc that comes with the adapter. it will install the software .
after that you will need to connect to the network.
Click Here for more info
Oct 06, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
My new computer has a LG DVD player , but it just stopped reading a disk, i have went to hardware un installed and computer found new hard ware , but want work -has power light is on
Make sure latest drivers are downloaded.
You can also go to my computer, go to dvd drive, right click, properties and make sure device is enabled and working correctly. If need, reinstall dvd software and codecs
Aug 25, 2009 | Televison & Video
I want to download music to my lg vu. I do have Windows media works but when I put in the usb cable its not recognizing the hardware and says no device found. How can I get it to work?
Dear
When u connect ur phone to pc there will be a pop-up in right corner of ur pc saying new hardware found, when u rcvd that message go to my computer & you will see a new folder has been added there called removaable disk
open that folder & copy whatever you want to copy in ur phone
If there is no disk appear load pc suite to ur pc,
setup cd is available in your mobile accs.
If u dont have it click here for download
Thanks
Mar 19, 2009 | LG enV VX9900 Cellular Phone
Emachine t3112 only work in safe mode
you need to run the new hardware wizard as there are differnet drivers needed for the mb
Dec 19, 2008 | E-Machines T3112 (RBT3112) PC Desktop
In spite of re-loading the software for my CanoScan LiDE 90, when I try to use it, I get the following message: "Cannot communicate with scanner. Cable may be disconnected. Check status.Scanner...
check this
go to File
print
see if the driver is there, if Yes right click on it and set as default
If no, then re-load when it says found new hardware.
Sep 17, 2008 | Canon Office Equipment & Supplies
SONY VAIO PCG-7G1M Wont boot
First you understand yourself is that after the windows logo screen apperars and its get restart means there is some changes or malfunction happened to your hardware - Although you changed your hard disk will not solve your problem. Please clarify as follows
1) did you load you operating system to this hard disk by any other computer help - if you load it with the same system try to reinstall the system.
If the problem existing 100% your motherboard is partially damage I think the uniprocessor side voltage variation is happening while you press keyboard some charge (voltage) you are supplying to the motherboard, sometimes some key pulse is more than 5 volt so that pulse support to get moved some points
First check your windows try to reinstall agian - I predict that you got this hard disk installed through some other laptop so the hardware configuration is different.
Thanks Hothawk
Jul 17, 2008 | Computers & Internet
Xtatix XCA-PP2A Webcam Logo
114 people viewed this question
Top Xtatix Computers & Internet Experts
David Payne
David Payne
Are you a Xtatix Computer and Internet Expert? Answer questions, earn points and help others
