Question about LG WM2688HWM TROMM SteamWasher
LG WM2688.. water heater not working
My machine is a little over one year old. Are premature water heater element failures common in these machines, or is it more likely the control board or thermistor that's causing the water-not-heating problem I'm currently experiencing with this machine? (I ordered a new heating element and the gasket clamp pliers special service tool, and will be servicing this myself)
    Sniper:
  • 68 Answers
I would also check that the unit is grounded. A non grounded unit can cause problems with the electronics
Please rate this solution
Posted on Jul 29, 2008
  • 489 Answers
No, these heater normally should last a long time.  Are you sure the heating element is bad and not the control board that feeds the power to the element?
Posted on May 02, 2008
Why does the4 heater go through thermocouples
Check to see if the machine has a fan. If so, clean the blades real good with alcohol and QTips. Also while inside check to see if the vents on the heater elements are clean. If it's stopped up, air cannot circulate thru the heater properly causing heat to build up in the unit thereby causing thermocouple failure prematurely.
Feb 21, 2015 | Heating & Cooling
Lg wm2688 drum light won't turn off
its happerning some time after used dry option,,,becouse this iscondensation dry systterm,,all the humidity become water power connetion getting wet,, afetr some time its will gose off....
Apr 13, 2014 | LG WM-2277HW Front Load Washer
TE code wm2688hnm
proceed with common sense and logically, fix it use the Vom or DVOM .God bless you
For this error code you need to check both the water heater or element and thermistor, basically the washing machine is reporting a fault on the heating circuit with this fault code but it is not capable of identifying exactly where the fault actually lies.
On non-display panel models this fault code is denoted by the lights for 95, 60, 40 and cold being lit or flashing.
  • Check water heating element
  • Check heater for contunuity,
  • Check steam heater for continuity usually
  • Check thermistor or temperature sensor
  • Check the thermistor resistance,
  • Check wiring to water heating element
  • Check connections to water heating element and temperature sensor
Aug 03, 2012 | LG WM2688HWM TROMM SteamWasher
No hot water
Failure of the heating element or there is no supply voltage from the controller to the heater.If so you need to check the voltage to confirm and replace the heater after checking coil continuity.check this link: http://www.espares.co.uk/advice/washing-machines/a/7/1393/how-to-replace-the-element-in-a-washing-machi.html
Mar 12, 2012 | LG WT5001CW Washer
NO HOT WATER
it has a hot water element that can burn out
have it checked by an electrician or technician
Sep 11, 2017 | LG LDF6810ST Stainless Steel Built-in...
Dirty Laundry...
It has nothing to do with the filter and everything to do with a failed heater element. Even if you can get the element replaced, the machine is now seven years past it's original five year design life and you may simply find that another major failure occurs shortly after repair.
You may be able to get around the problem by switching to a cold water laundry powder. it costs more, but is far cheaper than a repair.
May 16, 2010 | Hotpoint VBXR1090D Top Load Washer
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
. I have a LG WD12126RD front load washer dryer
This is a heater error. The heater element is open and not working. This is usually the problem but it could be other things also. You need a service call from an LG tech.
Jan 11, 2010 | LG WD-12126RD Front Load Washer / Dryer
Aquarius 6kg wma52 blows main power breaker
yes check for a heater element down to earth or at least a wire on the element off and touching the case, but i am confident its a heater element, rate me when you fix it, work with safety unplug when working on machines
Sep 16, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Rotten Egg Smell
Repair man told me this is common with front load washers. I was told to put Sunlight dish washing detergent (for dishwashers not hands) in the machine (about 1/2 cup) and do a hot wash with the machine empty.
Jan 21, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
214 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
