Question about Whirlpool Duet GHW9150P Front Load Washer
My washer is giving me code 5ud. What does this
The washer is shutting off during cycles and giving codes like f35, 5ud. It won't complete cycles.
  • 5,081 Answers
The F35 indicates that the main control board detects a problem with the analog pressure sensor (water level pressure switch) in the washer. This component senses and controls water level in the washer. This failure could be caused by a pinched or broken air hose between the air trap at the bottom of the washer tub and the analog pressure sensor. It can also be caused by a clogged air trap or a failed analog pressure sensor. If you are able to unplug the washer and pull off the top panel, you can check for the probable cause of this failure.
To remove the top panel, remove the screws on the very back of the panel that secure it to the washer cabinet. Pull the top panel back slightly and then and off of the washer. It is on the side wall just behind the expansion control board. You can check the air pressure hose connection and the wire harness connection on this component.
This component costs around $99.This information was based on the general description of the washer model that you provided (Kenmore Elite front load washer). There are several different models of this washer.
The following link explains the error in more detail and how to correct:
http://www.fixya.com/support/r3608687-sud_error
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code can be generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
COURTESY:jsrock - A senior expert of fixya.....
Posted on Jul 05, 2010
What does 5ud mean 10 minutes from finishing 5 Ud displayed can't open door?
The SUD (not 5UD) code is displayed when excess foam is detected (possibly because excessive detergent is being used). If your machine does not cure itself, you may have to run an "Eco drum clean" cycle (if your machine has it) or a 90 degree cotton cycle with no detergent and no load.
Aug 29, 2016 | Samsung Washing Machines
What does F35 code mean and what to do?
  • Run an empty cycle without using any detergent. Often the fault code displays when too much detergent is used and the detergent sits in the drainage system. A cycle without any detergent is often enough to clear out the buildup.
  • 2 Pull the drain hose out of the standpipe mounted to the wall behind the washing machine. Complete a visual inspection of the hose for any clogs. If you see any, remove the screw that holds the hose clamp onto the discharge pump and then force water through the drain hose with pressurized water from a garden hose. Reattach the hose and then run an empty cycle to see if the code goes away.
  • Read more : http://www.ehow.com/how_11368049_fix-whirlpool-washer-f35-code-alert.html
    Oct 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    Washer code 5ud
    Hello & Welcome to FixYa
    Sud error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
    Kevin
    Dec 02, 2011 | Kenmore Elite 45986 Front Load Washer
    Whirlpool Duet Sport Model WFW8300SW0 basket won't
    The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, call for service.
    I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
    Hope helps.
    Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
    Error code f35
    F35 (on some models)
    ANALOG PRESSURE SENSOR FAILURE
    If this failure is displayed, there is any malfunction of the steamer
    component detected by the Steamer Electronic Board.
    Possible Causes/Procedure
    Check if pressure hose is fixed correctly.
    Check if the airtrap is not blocked.
    Check if the hose is not blocked.
    Make sure you are ONLY using HE SOAP!
    Correct usage amounts are as follows:
    Regular HE SOAP = 2 Tablespoons
    2X HE SOAP = 1 Tablespoon
    3X HE SOAP = 1 Teaspoon
    The information on the soap usage comes directly from Whirlpool Tech Line.
    SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE
    WASH CYCLE)
    If suds are detected continuously by the pressure switch during the drain
    or spin phases, the washer will fi ll 4 liters of water and during 5 minutes
    the unit will rest without tumbling, the water will be drained and it will try
    to spin or drain again.
    If too much detergent was used:
    Run through a RINSE/SPIN cycle.
    Run a NORMAL cycle without adding any detergent.
    This should clear the unit of the excess detergent.
    Check the drain hose and make sure it is not plugged or kinked.
    Unplug washer or disconnect power.
    Check wire harness connections to the drain pump, pressure switch,
    and Central Control Unit (CCU).
    Check/clean drain pump filter of foreign objects.
    Check drain pump.
    Check the pressure switch.
    Verify CCU operation by running a Diagnostic Test or any cycle.
    Apr 19, 2011 | Kenmore Elite HE5t Washer
    Stopped on the rinse cycle an give the 5 ud message.
    The Sud (5ud) error code indicates a suds lock. This is normally caused by excessive detergent causing too much suds. It can also be caused by not using HE (High Efficiency) detergent. Overloading the washer can also cause this problem. Try running a cycle with no clothes and no detergent added. See if suds emerge in the washer even though no detergent was added.
    Nov 21, 2010 | Washing Machines
    Code F35 on Kenmore Elite HE5t front loader washer.
    F35 is a water level error.
    The water level switch (pressure switch) has malfunctioned.
    If you remove the top panel, three screws in the back, you will have access to the pressure switch.
    With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
    If the fault codes return after doing this, you will likely need to replace the pressure switch.
    Also - please be sure to use He soap.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
    Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
    Whirlpool Duet Mdl GHW9150PWO Washer stops
    HI. this code represents a Long Drain issue.
    If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
    Press PAUSE/CANCEL twice to clear the display.
    NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
    Potential Causes
    • Check the drain hose and make sure it is not plugged or kinked
    • Check the electrical connections at the pump and make sure the pump is running.
    • Check the drain pump filter for foreign objects
    • If the above does not correct the problem replace the pump
    Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Getting error message #5UD and F35
    F35 ANALOG PRESSURE SENSOR FAILURE
    If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
    1. Check if pressure hose is fi xed correctly.
    2. Check if the airtrap is not blocked.
    3. Check if the hose is not blocked
    IF YOU GET ERROR MESSAGE SUD
    SUD error message, and are observing some water in the tub that is not draining at end of cycle, and your washi cycle is taking a lot longer that normal to complete,then here is what to do.
    Please rate this solution
    RNJ VINODKUMAR
    Oct 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    919 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
