Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
I have a Kenmore Elite model 106.55606400 (side-by-side). Recently (last 2 months or so), the cooler stops working while the freezer works (and makes ice, etc.). If I defrost the unit, then both sides work for about a couple of days, then the cooler side stops working. I tried various temperature settings but that doesn't help. I see ice build up in the rear of the freezer but I don't see any ice forming by the vents connecting the two sides (top or middle/bottom). This is a 2004 model and the fridge has worked without any issues over the last 5+ years. I don't want to pay a ton of $ to only replace it ultimately. Any help/suggestions? I will keep defrosting it in the meantime (which is a pain if you have small kids as I do).
  • 62 Answers
SOURCE: Kenmore Elite Bottom Freezer Mod. #795 75544401
The unit was built bt LG. It is a computer controled unit and the timer is built into the main control board on back of the unit. However, the most likely cause of the broblem is the defrost terminator located on the evap on the upper right hand corner. Also, try unpugging the unit it will reset the computer board. You will also have to defrost the unit.
Posted on Aug 30, 2008
tech master
  • 120 Answers
SOURCE: Kenmore Side by Side defrost Issue
well tia i need the model number so i can guide more to wich part is failing but if you want repl the timer and defrost thersmotat you can repl all parts under 200 dollars versus 1500 for a new refrigerator is worth fixing it
Posted on Oct 17, 2008
Richie_asg1
  • 1036 Answers
SOURCE: side by side refrigerator and freezer not working, (fan not working either)
This doesn't sound good does it?
The good news is that the compressor at the back, is probably fine, it's just waiting for the signal to turn on.
First, try adjusting the controls from minimum to maximum to see if you can get any life out of it.
If you have no power to the display, please state this.
If it does function - but not properly, please state this.
If there is no action at all, I suspect there is a fault on the main control board, or the motor run capacitor is faulty. With a faulty capacitor, you may get a 'click' when first turned on, and the compressor will buzz or get warm without actually cooling.
Hopefuly this will help, but please get back with more information.
Thank you.
Posted on Jan 01, 2009
  • 59 Answers
SOURCE: will not cool proper on fridge side
THIS IS A DEFROST PROBLEM EITHER THE THERMOSTAT OR DEFROST TIMER IS BAD! THE THERMOSTAT IS LOCATED BEHIND THE WALL IN THE FREEZER COMPARTMENT ATTACHED TO THE COILS TO KNOW IF ITS BAD IF WILL HAVE A RAISED SPOT ON THE BACK LIKE ITS BUSTING OPEN CHECK THAT
Posted on Apr 27, 2009
  • 245 Answers
SOURCE: Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Posted on Jun 26, 2009
My kenmore elite side by side refrigerator isn't cooling properly
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
12_9_2012_3_01_59_pm.jpgKenmore
Dec 08, 2012 | Kenmore Elite Side By Side Refrigerator -...
I have a Kenmore side by side model # 106.53609202 and its about 8 years old. About a month ago it stopped making ice. I've already replaced the water valve behind the fridge and waited 24 hours and...
OK, remove the cover on the face of the ice maker and let me know if the model look like this picture:
12_17_2011_1_36_01_am.jpgIf it looks like this model, I have the service manual for it with all the testing procedures.If it doesn't, see if you can get a model number off the unit. They make about 4 different model for this unit.
Happy Holidays!Richard
Dec 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I unplug the Kenmore elite not working after unplug
um engine? not sure there is an "engine" on it but there are 3 things that make noise 2 fans and the compressor. Are all three running
Jul 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore elite model 59676539500 and is not blowing cold
hello, that would be my first guess can you hear the compressor trying to kick on at all ? how old is your kenmore ? if theres no cooling anywere and out of the blue it just stoped cooling then your right with the compressor
Apr 01, 2009 | Refrigerators
Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Oct 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer works but cooler isn't cold
Try unscrewing the light, bulb mine did the same thing I couldnt figure it out. It turned out to be the light switch! Everything is fine now.
Aug 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
251 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
