Question about Garden
I have a Homelite Model 26cs # UT32000 and the pull string to start the unit broke. It broke at the end of the pull so I sould have enough cord to re-string. What do I do???
  • 760 Answers
Replace the string that's why it broke.
Posted on Jul 04, 2010
How do I fix the pull string on a push mower?
Hi Barbara:
The pull start assembly is usually attached by 3 or 4 bolts.
Start by removing it. Depending on where the pull cord broke, you may be able to use it shortened a bit, but replacement is probably a good idea.
There is a spring inside the thing the cord winds around (spool)that retracts it after you've pulled on it. The tricky part is making sure that the spring is wound up enough after you've installed the replacement cord.
Look at the way the old cord is installed. If you can, grab it with some pointy pliers and pull it all the way out, winding up the spring tension at the same time. There should be a way to hold the spool (look for a hole you can slip the end of a nail into) so you can change the cord. Then Take the nail out and make sure the cord retracts all the way.
Next step is to re-install it on the mower.
Cheerfuls!
Jun 13, 2015 | Garden
My string ran out and there are no instructions on the package I purchased so I am not sure how to wind the string on the Mighty lite 26cs. Could you please help me. Thanks.
Here is a video on 3 different heads. Yours is probably the first head that he demonstrates:
The only thing that is not demostrated is a left-hand vs. right-hand trimmer. The spool retainer may twist off in the opposite direction if you have a left-handed trimmer.
Good Luck!
Jim
Aug 08, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a Homelite Mighty Lite 26cs gas weed **** and the starter cord will not retract into the weed ****. How can I get it to retract so it can be pulled to start the weed ****?
This is somewhat common in the the "zip start" machines. The recoil pulley is 2 plastic housings with a round coil spring between them. It is designed to need less effort to pull and start the machine. When pulled on with great effort/frustration, the middle spring bends and damages the upper housing. The only semi-permanent solution is to replace the pulley assembly. The part is relatively cheap thru Homelite.com. If you can do it yourself, go for it. A repair shop will most likely charge you $20 to $40 in labor to do this.
Aug 05, 2010 | Homelite Consumer Products MightyLite...
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite 21506a
There wiil be a nut or a knob at the end of the spool where string comes out turn it left to loosen and right to tighten it. Rmove spool pull down and spool will come off foll directional arrows that shows which way the string should go put spool back on tighten screw or some you can turn with knob at end make sure it's tight before starting.
Jul 06, 2010 | Homelite Mighty Lite Lawn Trimmer
Pull cord all the way out, and will not recoil
I started to take mine apart but when i loosened the 4 screws on the yoke the string rewound so ive been running it like that.
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
329 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
