Question about Amana 3.2 cu. ft. Top-Load Washer
Washing machine will fill with water but motor just hums
    Champion:
    Scholar:
  • 210 Answers
Sounds like the motor can't turn. Try taking the belt off and start it it the mortor runs the motor is ok. Then try turning pump it may be locked up or something stuck in it. If the motor don't run replace it. If it is huming it is geting juce and trying to start. If the belt is turning anything else try to turn it too. Good Luck
Posted on Jul 16, 2010
    Champion:
  • 274 Answers
Sounds like clutch is out.replace
Posted on Jul 05, 2010
Why doesn't it fill or run?
motors don't hum unless there is a faulty start /run capacitor in the circuit
the hum can be from a faulty water control solenoid
could be a faulty program control board
call in a technician and get a quote
Feb 15, 2016 | Summit Professional SPW1102 11 lbs. Front...
Motor is running but won't agitate and belt is on ? I can hear the motor humming and it will fill up but it wont agitate.
Check drum turning by hand ok not sticky sounds like could be motor if it hums and no turn..
Oct 18, 2014 | Hotpoint Washing Machines
Have a whirlpool washer that now hums when I turn the cycle on, no water just a hum
I had a similar problem - had to get a technician out - there was a valve at the back of the machine that allows the machine to fill. It had split (apparently its a common problem? there are separate valves for hot and cold water, so I'm not sure if using a different cycle choice (ie cold only), may let the machine fill?). 10 minute fix job
Jul 14, 2012 | Whirlpool Washing Machines
Washer fills, then just hums for about two minuts and shuts down
Hello
The hum sound is coming from the motor that is probably bad and needs replacement. Hope you understand...the washer fills with water which indicates that the control and the water inlet valve are both fine however, as after this you hear a hum sound it means that the motor is bad. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool washing machine
the drive belt may have gone or the brushes on the motor if it's old could be something to do with the controller but look to motor and blt first
Jan 10, 2010 | Whirlpool Washing Machines
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Crosley washing machine
the drain pump is blocked and will need to be cleaned out as the humming is comming from that pump motor by the sounds of it
so check that
cheers
Mar 15, 2008 | Crosley CAWC529JQ Top Load Washer
Help
The humming noise is the fill valve...this sounds usually is overpowered by the water fill, but if its faulty it wont let the water in....Replace the fill valve
Jan 20, 2008 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
224 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
