Question about Motorola TalkAbout T6530R (14 Channels) 2-Way Radio
When I turn the unit on it comes up with channel 1- sub channel 1. I cannot get the channel up button to respond to get another channel. It appears to be locked. How do I unlock so that I can change the channel and sub channel? Thank you Duane
  • 532 Answers
I believe you have the manual with you. Use the manual to unlock your phone.
Best regards.
Posted on Jul 04, 2010
How do I Change the frequency on a Rkio Nike TWo way radio
Hi Gary - I copied this from the RIO NIKE manual:
mode button
Press MODE to select the setting you want to change.
The normal display is replaced by the adjustable setting.
Use the + and - buttons to adjust the settings.
These are the settings you can change.
1. Main Channel (1-14)
2. Sub Channel (1-38)
3. Channel Scan (ON/OFF)
4. Sub Channel Scan (ON/OFF)
5. Button Confirmation Tone and Roger Beep ON/OFF)
6. Vox (OFF, ON LO, ON HI) (psc[communicate wxonly)
When you have proceeded through all adjustable settings, the normal display will reappear. Or, press TALK at any time to return to the normal display.
select main channel
There are 14 main channels.
To select main channels:
1. Press MODE until CHAN is displayed.
2. Press + and - keys to select the main channel.
select sub channel:
Each main channel has 38 sub channels, sometimes called
CTCSS channels. Select one of these sub channels to transmit
on a channel that is free from traffic.
To select sub channels:
1. Press MODE until SUB CHAN is displayed
2. Press + and - keys to select the sub channel.
Note :If you select channel "0," you will be able to receive transmissions from all the sub channels of the main channel you selected.
Download manual:
Jan 27, 2014 | Rio Nike PSC Communicate (14 Channels)...
Leapster2 is 2 1/2 years old. Placed brand new batteries in Leapster2. Try to power it on, screen comes up like it is going to turn on, and it turns off.
Welcome to FixYa!
Ensure NO GAME is in unit
Power Unit off
While turning Leapster 2 on, hold down HINT KEY. (Key in middle with question mark on left hand side)
Once unit switches to other menu, Hit A to begin calibrating.
Follow prompts with Sylas pen to reprogram Stylus pen.
Once you are done it will return to original Calibrating Menu.
Power Unit off Turn unit on with game inserted. Stylus pen should respond.
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Do comment if it helped or not in any manner ill know.
Apr 15, 2011 | Leapster 2 Handheld Game
Wireless speakers will not pair with the main unit
TheSony Audio Interactive Radio Frequency (S-AIR) is a wireless digital audiotransmission signal that plays surround sound using a radio frequency that canbe placed anywhere that is convenient within the maximum communication distancewithout the signal breaking up. The system can transfer up to four channels ofCD quality (48kHz, 16 bits) audio data with no data compression.
You have to pair the S-Airunit with the Main HTS unit. When the sound transmission is not established,the indicator of the S-AIR sub unit does turnsoff, flashes or turns Red. Please try the steps mentioned below and checkif the issue can be resolved: · Make sure that there is no other S-Air unit nearthe one which you're using. If any, place it more than 8 meters (26 1/4 feet)away from the unit. · Make sure that the units that you are trying topair are within one meter (3 feet) of each other. · Confirm that the ID of the main unit and theS-AIR sub unit are set to the same ID. · You performed pairing the main unit and anotherS-AIR sub unit. Perform the pairing steps again with the desired S-AIR subunit. · The unit is paired to another S-AIR sub unit. Cancelpairing. · Install the S-AIR main unit and S-AIR sub unitaway from other wireless products. · Stop using another wireless product long enoughto confirm if the S-AIR main unit and S-AIR sub unit gets connected. · The S-AIR sub unit is turned off. Make sure theAC power cord is connected and turn on the S-AIR sub unit. How to cancelpairing? · Perform the ID setting of the unit as follows: · Press POWER to turn the unit on. · Press the FUNCTION +/- button repeatedly untilDVD appears in the front panel display. · Press DISPLAY while the system is in the STOPmode. · Once the CONTROL MENU display appears on the TVscreen, press the up arrow or down arrow to select SETUP , and then press + . · Once the options for SETUP appears, press the uparrow or down arrow to select CUSTOM , and then press + . · Once the SETUP display appears, press the uparrow or down arrow to select AUDIO SETUP and then press + . · Once the options for AUDIO SETUP appears, pressthe up arrow or down arrow to select S-AIR SETUP , and then press + . · Press the up arrow or down arrow to select ID ,and then press + . · Press the up arrow or down arrow to select thedesired ID, and then press + . · Once you select an ID (A, B, or C), theconfirmation display appears. · Once you have selected a new ID (or evenselected the same ID as before), pairing is cancelled. NOTE: To confirm the current ID, performsteps A-G listed above. When you pair the unit with the S-AIR sub unit, PAIRINGappears beside ID on the display for selecting an ID.
Pair the unit again and check if the issue is resolved.
Good Luck!
Nov 03, 2010 | Sony BRAVIA® DAV-HDX576WF Theater System...
Hi all, I have a MK MX-2000 sub that no longer works. Appears to power up but no audio. I've verified the two internal fuses are fine as is the power transformer and DC rectifier which provided about 45...
The sub is common to both channels. So is the source and its configuration regarding Low Frequency steering.
Have you established that there is audio programming coming onto the sub?
If you suspect something upstream of the sub, try one channel at a time, swap them, whatever. Feed it with a different channel to see it that makes a difference.
Feb 14, 2010 | Audio Players & Recorders
Dear Sir,I am not able to see all the ch, I 4to5 times contact costomer care but no one responding properly.some times the add is heard but no one responding. please kindly do the needful.Dish tv...
It would be our pleasure in helping you get those missing channels back. The first thing we want to do is press guide button twice to display "Favorites List" option. Press guide button to rotate through selections until "All Sub" is selected. By selecting All Subs the programming guide will only display the channels that you are subscribed to. If you are still not getting those missing channels we need to check some things on our side; please give us a call at 1-800-333-DISH (3474) or use or online chat too here: http://goo.gl/QR0vg.
We hope this helps. Thanks for choosing DISH Network!
Phillip Chang
DISH Network Customer Service Department
Jan 30, 2010 | RCA DISH Network(r) 311 Satellite System
My Leapster 2 comes on, shows the name on screen & ask to touch my name w/ the pen; however when I touch the name, nothing happens. It keeps asking to touch a name or "guest".
Answer
I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
5) Restart unit
Jul 28, 2009 | LeapFrog Leapster 2 Learning System
Sub-Channels
Here is a link to a list of older TalkAbout user manuals. Use the pulldown menu to look at various models. In general, most of them program similarly by using the menu button to select the feature and the PTT button to lock in the change. http://www.giantintl.com/motorolafrsold.htm
May 26, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
Hi... I have a leapster which we purchased on march, 2008.Recently, the screen doesnot seem to respond for the stylus. but the button works well. what can we do to fix it? [i live in indonesia]
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Jan 23, 2009 | Leapster Learning System
NO RESPONSE FROM YAMAHA YST-SW305/205
Hi Ron,
It sounds like the sub is not auto turning on, or has no audio output, and or the sub driver itself has failed. Do you have a multimeter, and we can diagnose the unit? :)
regards
Graeme
Mar 02, 2008 | Audio Players & Recorders
Motorola TalkAbout T6530R (14 Channels) 2-Way Radio Logo
35 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
