Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Remote control unit does not open the door. we
Remote control unit does not open the door. we have 2 doors with same 1/2 HP opener. the remote has 3 buttons. the big button does not open either door, the middle button opens one. we have 3 remotes and all 3 can open and close the one side. the door works fine mecahnically when puhing the button on the wall. so we know the door works. can't get the remote to work?? help. Thanks.
  • 201 Answers
You can try reprogramming the remotes to the opener that is not working. Sometimes they get a brain freeze and drop the codes and reprogramming can fix it. Next to where the wire hangs down will be a colored square button (the learn button) press once and release, you have 30 seconds to try and program a remote, you don't need to do all in the 30 seconds. Press and hold the button on your remote that you want to use until you see the light on the opener blink or hear a click sound from opener, let go of the button. it should now be programmed. If you can't get any of them to work then the logic board is bad.This repair can cost as much as a new opener + install. Sears sells a "remote control conversion kit" it comes with 1 remote and a plug in receiver you attach to your existing opener. 2 wires come off it and hooks up where your wall control hooks up at the openr.It's pretty easy to install. FYI the remote controls are color coordinated meaning the buttons on the remotes have to be the same color or they won't work, so if existing remotes are not the same color as the one in the kit they will most likely have to be replaced. good luck!
Posted on Jul 05, 2010
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
The remote opener in my far works, but the garage door opened on the wall of my garage will not open the door. What is wrong?
Perhaps the wall opener control needs to be accepted by the opener, press the button on the opener head unit and then press the wall switch. Consider new batteries before you do so.
Mar 04, 2011 | liftmaster Garage Door 1/2 Hp
Craftsman Garage Opener (Unit run front & back only for 2 second)
Double check to make sure the sensors are wired correctly. The 2 solid white wires go to terminal 2 and the wires with black stripes go to terminal 3. If the wiring is correct then you possibly have a bad RPM sensor. The RPM sensor is a small circuit board just in front of the motor.
Jul 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
248 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
