Question about Gateway PGA370 E139761 DIMM Motherboard (4000700)
After moving the cmos Jumper the system does not seem to boot. There is no diplay but the floppy and cdrom have there check lights diplay.
I have the same problem....
Posted on Dec 27, 2010
M2n-mx bios problem
try new cmos battery
Feb 13, 2014 | Computers & Internet
Desktop wont boot past floppy disk seek failure
There is a menu in the BIOS (set-up) menu that disables the floppy drive. This option enables or disables the floppy drive.
Aug 15, 2012 | Dell Computers & Internet
Reset cmos and now it won't showhard driveand it
can u view the HDD in Boot sequence in BIOS boot seq...have u reset the BIOS/COMS using any tools...try reseting the BIOS boot seq to boot from HDD insted of floppy or CDROM...also check how many HDD is displayed in the BOOT seq...the machine normaly boots from HDD 0....
else try to boot from CDROM....and insert a BOOT CD/WinXP cd in the CDROM drive...
Dec 15, 2009 | HP (D7580-60003) Motherboard
Cmos problem
checkcu fix jumper in its 1-2 position
also refix ram
also check dispaly cable is fixed properly.
Apr 13, 2009 | Intel Motherboard
I cannot boot windows xp
Hi praph_wicked, normal order would be, floppy drive first, CDROM second & Primary hard disk drive third.
How ever if your bios does not comply you can always press the F8 key every two seconds & that should bring up (Please select boot device). Which will look like this;
Choose the CDROM drive with the windows CD in it.
If you have just one CDROM drive, make sure the jumper on the back side of the CDROM is set to "Master". If you have two CDROM drives connected, set one as master & the other to slave.
If using an IDE cable for the two CDROM drives. The CDROM at the end of the data connector is to be set as master, the 2nd CDROM connects to the next IDE connector & Its jumper is set to slave.
Mike
Dec 13, 2008 | EliteGroup P4M800-M7 Motherboard
6514MR-ES
Unplug mains from wall
remove lid
find CMOS reset jumper (usually 3 pins with a jumper/link on two of them near the button cell battery on the mainboard).
Move jumper to other position, then move jumper back again to original position.
fit lid and connect mains supply and switch on.
If you can go into the BIOS, set Defaults and set the date and time, Then try to boot.
If it has been of for a while and time is wrong when ou next boot it, replace the button cell battery on the mainboard.
Aug 07, 2008 | Intel Motherboard
Computer won't boot
if you want too boot your computer when you start computer thne click delete click one or more time and setting screen available. set first boot cdrom option select.. and save satting. and restart. then you are cdrom open and put bootable CD in cdrom and restart computer see bootable your computer..
i hope to thankfull to you..
Dec 01, 2007 | E-Machines EMA IMPERIAL GV (845GV) TG3...
A: drive
get into the bios F2 or Del on boot up and change the first boot device to cdrom and 2nd to HDD then last the 'a' drive. The floppy drive may be faulty, if you dont use it just disconnect it.
Sep 26, 2007 | Intel Motherboard
Medion Compsoser 5200
Based on the information that you gave us...You can't access your BIOS for reconfiguration. To go to BIOS settings, try to press DEL or F2 button when you see the LOGO of the manufacturer.. Then change its Boot Sequence: 1st Boot - Optical Drive..2nd Boot- Floppy (if there's one) and 3rd Boot - Hard Drive. If your BIOS is protected then you need to shutdown your computer, 1. remove the powercable, 2. open your Desktop CPU, 3. look for the CR2032 Button battery, 4. locate the jumper near this Battery with CLEAR CMOS label. 5. change the setting of this jumper by removing the jumper and mount it on the other setting. Maintain for 5 seconds and then remove it back from its original setting.. Note: dont forget the original setting of this CLEAR CMOS jumper. Also never to POWER ON your Desktop while the jumper is at CLEAR CMOS setting. This will destroy your motherboard. 6. Connect the power cables and power ON your Desktop and you will encounter an error on BIOS setting. press DEL button or F2 to configure BIOS. 7. Then change BOOT SEQUENCE of your Desktop to boot to Optical Drive or CDROM first and then press F10 to Save and Exit. ..................... Check your keyboard if its working well otherwise get a GOOD Known keyboard or a new one.
Apr 09, 2007 | Medion M3 Composer 5200 PC Desktop
Computers & Internet Logo
81 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
