Question about KDS Radius RAD-7c 17" Flat Panel LCD Monitor
Brightness! How do I make my monitor brighter. It has a few buttons on the one side but I see nothing for brightening it. All my other monitors had a brightness control and for the life of me I can't figure this one out . Please help, thank you
    Genius:
  • 1,970 Answers
Mcdevito75 here, You can try this, 1 of the buttons should say AUTO presss this button and the monitor will automatically adjust, and Or press the MENU button and see if there"s a brightness feature, I believe there is, you can use the little arrows on your monitor within the MENU options. First try the AUTO.
Posted on Jul 05, 2010
Testimonial: "You're a pal! I just couldn't figure it out. You hit the nail right on the head. Thank You so very much and have a Happy 4th of July"
MY SCREEN WENT DIM ANDI FOGET HOW TO BRIGHTEN IT
Laptop. Make sure it is plugged into the mains as the battery saver may have activated. On my HP Laptop, pressing the F3 function key brightens, F2 makes dimmer.
On computer monitors, you need the menu button which will be somewhere at the front of the monitor either on the face or just underneath out of site. Press menu to bring up the options, use another button to scroll to brightness, press another button to select, one of the button you just used to make brighter and then menu to save out.
Mar 29, 2017 | Computers & Internet
Philips dcb152 05 display is very dim it's almost un-noticable. Is there anything i can do to make it brighter
yes. You can always use the contrast and brightness tabs in the monitor.
Go to the MENU of the monitor by pressing a button(prob it should on a side of the monitor).
Choose brightness and then increase it.
May 24, 2014 | Philips Televison & Video
How do i brighten my monitor?
It depends on your monitor make. usually, there is an adjustment for modifying your brightness, contrast, hue and color (chrominance) amount. Select proper button in the side of bottom of your monitor and adjust your settings.
Oct 31, 2013 | Dell Computers & Internet
Brighter display on the left side of monitor than the other side
Sounds like the lcd screen might be going bad. There are no display settings that can modify parts of the screen. It's all or nothing as far as settings go. Have you tried hooking up an external monitor to see if it displays correctly? If it shows correctly on an external monitor the problem is definitely with the lcd screen. If they both show the same image of brightness on the left side, then your video card in the laptop might be going bad.
Apr 18, 2012 | Computers & Internet
HOW DO I BRIGHTEN UP MY MONITOR SCREEN?
hi,
you can adjust the contrast and brightness of the screen accordingly using the following instructions. Please select the right combination of brightness and contrast according to your desire.
  • Please check out controls in the bottom of your monitor, below the scree. I have provided the image below for your reference.
  • In this the fourth option is OSD menu. Please click on it and you will scoll down to options .
  • you can see options called "brightness and contrast". I have added picture for this too!
9b04c60.jpgOnce you go that page,use the menu to enter! then use the 2nd and 3rd button to adjust the brightness. Now your job is done.Please click on 1st button to exit. If you need more assistance in this, please write back to us. Please rate my solution as helpful!
Apr 02, 2010 | Acer AL1715 17" LCD Monitor
MY ACER MONITOR IS DIM , HOW DO I BRIGHTEN IT UP?
Push the button on the front that says menu. Within that menu you will find the brightness control. Use the other buttons to move through the different menu items until you get to Brightness. Once there push the menu button again and then adjust the brightness with the other buttons.
Nov 27, 2009 | Acer AL1916W 19" LCD Monitor
I cannot adjust the monitor brightness, it's too dark..
Since this problem was posted generically.. Monitors, whether they are the old tank style CRTs, the newer flat panel LCDs or the newest LEDs, all have 'Brightness' controls. All are typically marked with what looks like a bright, or radiant light bulb, usually offset to one side, to show that "adjusting the ?? that way" will brighten the screen. Most LCDs are now Menu Driven, so looking for a button that says "Menu" is your starting point. You will need to find your adjusting control and the 'light bulb' to figure out which way to brighten or dim your screen. Once found, adjust to eye pleasing brightness. If your brightness is at 100%, you are on your way to needing a new or used monitor. Typically, there is no Brightness settings in the operating system. Your enhanced video card maybe doing it to you, They usually have their own control center and the types of abilities vary greatly. If you hav a friend that can loan you a monitor, borrow it to test at least the output your monitor is receiving. That will tell you whether you are having a problem with your video card or your monitor.
Aug 18, 2009 | Dell (H5195) Laptop Cooler, CPU Fan,...
Dark scree
I too have the same problem with the same monitor.. tv looks great OSD looks great.. pc is dim.. This has nothing to do with the inverter board or the backlight.. I believe that there is an issue with the components that render the Computer video.
Jan 17, 2008 | Samsung SyncMaster 17" TFT LCD Monitor
KDS Radius RAD-7c 17" Flat Panel LCD Monitor Logo
194 people viewed this question
Top KDS Computers & Internet Experts
Denise
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
