Question about Craftsman 20 Hp 42" Deck Lawn Tractor
How do I get the gear off of the starter, it's stripped and I need to replace it.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
I don't think you will be able to find a replacement starter motor gear, and disassembling and reassembling the motor is challenging. Generally you have to replace the starter/solenoid as a complete assembly. They are available on eBay.
Posted on Jul 04, 2010
2006 Pontiac G6 V6 makes a grinding noise when starting, does starter need replacement?
sounds like you have a stripped starter gear or stripped fly wheel, I'd pry for the stripped starter gear.
Oct 29, 2014 | 2006 Pontiac G6
Troy built snow blower the electric starter grinds
sounds like your starter pinion is stripped. remove your starter and inspect the gear. If the teeth are worn then replace gear if not replace starter. you will also want to check the teeth on your flywheel
Oct 07, 2014 | Garden
How do I find the part number for the starter gear
Try this site:
http://www.partstree.com/parts/
Get all the info off your equipment (labels or metal tag riveted onto), so you have the info you need to "drill down" through the site to find your particular starter.
Sep 14, 2014 | Garden
I have a Craftsmen riding mower/tractor, model number is 917257630, the gear on the starter that goes up and turns the motor and starts it, the teeth r stripped off, how do i take that gear off??
You're not going to be happy. You can't replace that gear. You have to replace the whole starter. I've run into the same before and was very upset.
Jul 15, 2011 | Garden
My vehicle has difficulty starting, it's weak to start and makes a loud screeching sound at the same time.
The problem is the starter is not meshing with the flywheel properly or the gear on the starter is stripped or the flywheel gear is stripped. You will have to remove the starter and then check the flywheel gear they should be sharp looking if they look sort of rounded then you have to replace the flywheel. If the flywheel is OK then check the gear on the starter and the same rule applies (Sharp or Rounded ) If this is OK then the Starter is not position to the flywheel properly so you must adjust it by shimming it. Sometimes you have to replace the starter because the starter has been lose and the holes for the bolts have widened and there is to much play.
Apr 21, 2011 | 2000 GMC Denali
After starting my Chrysler town and country and when I release the ignition key back to run position the starter continues to run. I then turn off the ignition key and the starter still runs. The only way...
You will need to replace the starter and or solenoid as the starter drive is not disengaging the starter gear and power is constantly being fed to the solenoid. Don't drive the vehicle this way as the starter drive will burn up and possibly strip the starter gear which is a much more major problem to fix.
Feb 22, 2011 | Chrysler Town & Country Cars & Trucks
Starter gear doesn't move up to engage flywheel gear when started
The solenoid does two things -- it closes an electrical contact to run the starter motor, and also pulls a lever to slide the motor gear up to engage the flywheel. Since the contact is closing, the solenoid itself must be OK, but the lever could be broken, or the sliding gear could be binding or stripped. Since you're looking at a probable replacement, try cleaning with compressed air, then squirting some WD-40 into the starter gear area - you could get lucky! Otherwise, you can replace the starter/solenoid assembly -- you can find replacements on eBay for about $80. Less expensive but more time consuming is to remove the assembly, disassemble, and replace just the defective parts if you can find them. Good luck! Please rate my answer if helpful, thanks.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
When trying to start bike starter has whirring noise,odd occasion tries to turn over?
Your starter is not engaging? Bad "bendix', low power level in yolur battery or stripped gear on your starter. Id suspect the gear.
Remove the starter (two bolts, probably 8 mm <>) and the power wire. Inspect the business end of the starter (the gear) . Stripped? replace it.
If you are brave, hook up the wire, create a ground path using a heavy jumper cable or equal, turn on the switch and press the button. What happens? If the gear is deformed, replace it. If the gear fails to shoot out - find out why. If it runs slow, you may have a low voltage issue. Check your batteryand charging system.
If you need more help, let me know. Let me know if this works for you.
a
Sep 22, 2009 | 2001 kawasaki ER-5
19.5 hp 917270810 starter making loud squeel
remove a plastic cover above or near the starter to access the gear and check the teeth on the gear.\
if it is chewed up replace gear or the complete top of starter assemly consisting of a clutch a gear and fastening components.
Starter will have to be removed to do this.
check the flywheel gear also to be sure its teeth are in good shape.
if gear is good move motor off of compression stroke and try again
Jun 14, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Engine will not start
Take the starter out and see if the starter drive gear is stripped or just need lub for the bendix( the thing that makes the gear move forward to engage the other gear.
Jan 01, 2009 | 2002 BMW R 1200 C Independent
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
136 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
