Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
My hot tub had a OH where the temp usually is, then went blank and i wasnt able to reset it. i just replaced the cord and resiliconed around the temp readout
    Problem Solver:
  • 13 Answers
If you reset the spa & it immediately reads OH & shuts down I would go after your "High Limit" sensor that is attached to your heater. also double check your filter. A dirty filter will slow the water flow passing the heating element therefore alowing the water to get hotter than it should, resulting in an overheat error.
If you reset the power to the spa & your topside starts showing a crazy temp. that the water isn't, then go after the temp. sensor. It should be in or near your filter area.
Posted on Jul 13, 2010
  • 990 Answers
This is probally your temp sensor. Where it is on your system is hard to say. If you have a book on the system it will be in there.
Posted on Jul 05, 2010
OH code for x500 how to repair?
if water flowing possible bad temp sensor or recirculation pump running too slow
Jun 13, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have just replaced my circuit board (balboa 53247) for my eclipse hot tub and as soon as I plugged the unit in, I got an OH reading from the top-side control. Then I noticed that if I pulled the temp....
Unfortunately, I would have started with the sensors and then escalated from there. A hot tub is one of those items that I generally recommend hiring a technician to sort out, it's just flat not worth the headache of troubleshooting without the know-how.
As for your particular problem, the OH code on a Balboa control pack is "O.ver H.eating" it means that the heat sensor detected high temp and shut down to prevent damage to the system (as well as cooking you like a pink lobster) The sensor could be bad or the control board could be malfunctioning. A new sensor is $75-85 if memory serves me and is relatively easy to replace. one sensor is in the heating tube and the other is screwed into the tub shell to monitor tub temp. I would suggest new sensors, both of them because when one goes out the other usually isn't far behind. Make sure you shut the power to the tub off at the breaker box before doing any kind of tub repair. If you have shutoff valves on your tub you can replace the internal one without draining the tub. the one in the shell you need to drain to replace (at least to the sensor hole level) I hope this helps you to get your tub working properly again, if you still experience issues after this, I suggest biting the bullet and calling in a tech. Thanks for your question =)
Oct 28, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Reads OH but still cold
you either have a bad temperature sensor (check the wires for damage) or a bad circuit board. I would recommend replacing the temp sensor first. If that doesn't work, pull the board and take it and have it tested.
Mar 18, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Temp. gauge reads high some times. but the motor really isnt hot
It sounds like the coolant temperature sensor is beginning to fail. It is highly unlikely that the in-dash gauge is a problem. The coolant temp sensor inputs to the computer affecting everything from radiator fan speed, engine fuel/air calibration and a variety of other parameters.
Be absolutely certain to "burp" every bubble of atmosphere from the coolant system too. Air bubbles have the amazing ability to prevent coolant flow and will cause all sorts of problems, especially if the bubble wants to hang around the temperature sensor location.
Normal operating temperature is going to be around 210 F.
Most Autozone, Advance locations will read engine problem codes at no charge, so drop by one of those locations and let them read the problem code.
My guess will be the coolant temperature sensor. Then have the problem code reset, remove all air from the coolant and let us know how this worked.
Mar 11, 2010 | 2004 Chevrolet Impala
Panel reads HHO-----, no temperature display until activate jets, then shows a temperature drop sometimes down to 65 degrees ,then starts heating upwith jets going
"OH" is an overheat error. In normal function, it is used as a safety shut off if the spa water temperature reaches over 110 degrees in the event of a thermostat failure. But more commonly, (if the water temp hasn't gotten too hot) it indicates that the temp sensor(s) have failed. If you have a digital display on the topside controller of your spa, then it is a circuit board controlled spa pack. Most spa builders use the same control pack manufacturer - Balboa Watergroup. The sensor kit usually consists of 2 probes and wires that plug directly onto the circuit board. Depending on the spa, they could both be located onto the heater manifold, or one on the manifold and one mounted to the tub making direct contact with the water via a thru-wall sensor mount. If I knew the spa manufacturer, I could further assist you. If you replace the sensors, and encounter the same problem... then the circuit board is bad, and usually a costly replacement. The sensors are usually listed as a "BA sensor assy" Hope this helps you,
Dec 24, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
What does OH mean on a hot tub control panel
OH stands for overheat. This normally occurs when the water temperature of the spa reaches over the safe temp of 104 degrees, as a result of a failure in the thermostat control. But if you receive this error and the water is not scorching, (a fairly common occruance) then the temp sensors have likely failed. Replacing the temp sensors will most likely rectify the problem. If the problem persists, then the circuit board is bad.
Oct 31, 2009 | Coleman (5040B750) Patio Heater
Reset error code hot tub
tub is in sleep mode usually to change u must press temp button then light button you want to b on standard mode STD
Oct 04, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
OH reading on my spa
either dirty or old filter or bad temp sensor
Jul 16, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Apr 10, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
629 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
