Question about Keurig B30 Mini Coffee Maker
I put the coffee grounds in the water place by accident. I tried to clean out the grounds and poked around with an ice pick. Now the water comes out the bottom of the machine. What can I do?
  • 518 Answers
Sorry but get a new one
Posted on Jul 04, 2010
My coffee machine is dispensing hardly any water on either setting
How long has it been since you did a good cleaning? If you can see the opening where the water is suppoise to come out at take a tooth pick or toothbrush and poke thru. Then put vinegar in the water reservoir and turn on machine as if you was making coffee, but no coffee grounds. This will help clean the inside if the machine that you can't actually get to. May need to do this several times if you haven't cleaned in awhile, then run another cycle with just cold water to remove any vinegar taste. Hope this helps, if not it's probably time to get a new machine. Remember to do the vinegar cycle once every couple of months for preventive measures.
Apr 25, 2017 | Coffee Makers & Espresso Machines
No coffee will come out
Maybe the coffee is down, around the waste container. In this case the grinder must be opened probably the cofee funnel is jammed or is not in his place to direct the grinded coffee.
Jul 29, 2014 | Saeco Odea Giro Plus Coffee Maker
My keurig does not have water come out into the cup
1. always a dumb question but I have forgotten this more than once so I have to ask, does it have water in the basin?
2. A common issue with keurig's I've owned has been that some finer ground coffees will clog the spray nozzle that pokes into the top of your kcup. It's kind of a pain to clean,but if you are really careful it can be done with a very small jeweler's screwdriver.
UNPLUG THE KEURIG
lift the lid and find the groove that allows water to flow from the nozzle.
VERY GENTLY run the screwdriver across that groove being careful not to damage the nozzle by vigorous scraping. DO NOT ATTEMPT TO PUT THE SCREWDRIVER OR ANYTHING ELSE INTO THE OPENING.
Replace the water in the basin and try with a new kcup.
Jul 22, 2014 | Keurig Platinum B70 Coffee Maker
Recalls on keurig
Empty the reservoir of any water. Fill it back up with white vinegar. Get a paper clip and poke it up in to the needle that the water comes out of on the top of the lid. Run the vinegar through the machine until the reservoir is empty. You can even let the vinegar sit in the coffee maker for 10-15 minutes. Refill reservoir with purified water and run the maker until all the water is dispensed and the reservoir is empty. There should be no more vinegar smell. Never use tap water. Do this every two months. Note: if the area where the K-Cup sits gets dirty with grounds, put a large bowl under it and then pour a glass of water over the whole area to clean. Also, on occasion just run a cup of water through the machine (with no coffee) just to make sure that there are no grounds caught in the needle. Done!
Feb 19, 2012 | Keurig B60 Coffee Maker
Water does not go through the cup
The drip spout may be clogged. Easy fix, just poke through it with something like an ice pick or even a paper clip. Also, you may be using too much coffee grinds which could slow down or stop completely the flow of water.
Dec 25, 2010 | Keurig B60 Coffee Maker
Some idiot put ground coffee and water in the whole bean reservoir of out titanium Gaggia machine. I may have been there for a day or 2 before we noticed something wasn't working correctly. we took it...
It is fairly easy (if you have the instructions I'm going to give you) to take the grinder apart to clean it out completely. This would be the best way to clean it - by removing the burrs so you can get right into the grind chamber and grinds delivery chute to clean.
At least vacuum it out as best you can and don't add any beans until it has had time to dry out.
OK ... first take off the water reservoir and set aside. And unplug the power cord. While you're at it, remove the drip tray and set aside and remove the brew group and set aside. You'll want to rinse off the brew group very well.
Next remove the three screws that hold the bean hopper and lift the bean hopper out and set aside.
Lift off the round rubber top from the grinder - it has four slots that line it up so it'll be easy to put back on later.
Now, notice the ring with gear teeth on the edges? This is the grind adjustment that turns around when you turn the grind adjustment knob. Twist that ring counterclockwise and you'll see a painted mark - twist counterclockwise until that mark is pointing to about 7 o'clock. Now you can lift out the center part (the burr) - you'll need to wiggle it a little and you should be able to lift it out - notice the painted mark that would have been pointing to about 3 o'clock. Brush this burr clean with a stiff brush (a toothbrush would work) and set it aside for now.
Vacuum all the mess out in the grind chamber - you may need to loosen the coffee grounds up with a toothpick or a stiff brush.
Once you've vacuumed out all the grinds, there is a "chute" where the coffee grounds go through - it's hard to see because it will be caked up with coffee grounds. This is at about 5 o'clock in the grind chamber that you just cleaned out and goes towards the front of the machine. Poke something in there (a chopstick or a wooden coffee stirring stick works well - or the handle of your brush) to loosen up the caked up coffee grounds and vacuum again.
To really get this clean, tip the machine onto its back and open the front door (you've already removed the drip tray and the brew group, right?) You'll see a little trap door with a triangular shaped handle - this is right directly above where the funnel of the brew group would be if the brew group were inserted. Pull down on that triangle and the trap door will open. Vacuum and brush out all the grinds you can and you should see the other side of the "chute" that you were trying to clean out earlier in the grind chamber. Poke your chopstick or stirring stick in there and loosen all the packed coffee grounds (they'll be falling back into the grind chamber now). If you have a can of compressed air you can blow it in there and get coffee grounds all over your kitchen (oops).
You may have to go back and forth a few times between cleaning under the trap door with the machine on its back and then setting the machine upright and vacuuming out the grind chamber and then putting it on its back again and cleaning under the trap door.
You may want to tip the machine completely upside down so any coffee grounds can fall out. This is all very messy but you'll have a nice clean grinder when you're done.
OK ... now that everything is clean and dry - here's how to put it back together and get it aligned correctly.
Put the burr back in with the paint mark pointed to 3 o'clock. Make sure that the outer ring still has its paint mark pointed at about 7 o'clock. Wiggle the burr a bit to make sure it is sitting all the way down in place and then rotate the outer ring clockwise a little - as the ring gets to about 10-11 o'clock it should have locked the burr in and started to pull it down. Verify that you cannot lift the burr back up (if you can, then you didn't get it fully in place and you need to turn the ring counterclockwise again back to 7 o'clock and make sure the burr has snapped all the way into position and try again).
OK - now that you can feel the burr being captured by the ring as you turn the ring clockwise, turn the ring all the way clockwise (the paint mark will be pointing at 3 o'clock. Put the rubber cap back on top of the burr and work it down so the four tabs are fully through the four slots.
Notice the straight plastic piece with gear teeth on it to the right side, just above the burr. This is the dose adjusment - push it all the way towards the back of the grinder.
Now get the bean hopper and set the grind knob to zero and the dose knob all the way to + as far as it will go. Set the bean hopper in place and you may need to wiggle the knobs slightly until they line up in the gear teeth and the hopper can set fully down in place. Verify that you can turn the knobs and see the adjustments moving below (the outer ring should turn and the straight rod with the gear teeth should move forward and backward. Turn the three screws back in to hold the hopper in place.
With the grind setting at 7 or 8, you should see the paint mark on the outer ring at about 1-2 o'clock when you look through the clear plastic of the bean hopper - and this is a good starting place for your grind setting.
Clean the brew group really well (no soap - just water) and put it back in the machine. Put back the drip tray and the water reservoir and plug the power cord back in.
Now that the grinder is completely empty and clean, the first time you fill it with beans and make coffee it will take a lot longer than usual for the first cup to grind - it may tell you the bean hopper is empty - just select a coffee again so it grinds some more. Once it has ground enough beans to get them moving through the chute it should start making coffee again.
Hope that helps --- it isn't as hard as it sounds.
Oct 16, 2010 | Gaggia Titanium Espresso Machine
The water isn't fully coming out when brewing a cup of coffee and won't fill the cup. I am maybe getting 1/4 cup of coffee
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 15, 2010 | Keurig B70 Coffee Maker
I have water draining back into the reservoir. It has been descaled and the needle openings have been cleaned.
Oct 14, 2010 | Keurig B60 Coffee Maker
Grounds in cup;water leaking.
Could be a couple of things. Clean out the channels of the coffee machine. Clean out the upper pick that pierces the K-cup. Sometimes this can start with a defective K-cup...yes, it happens.
Nov 05, 2009 | Coffee Makers & Espresso Machines
Leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following: 1) take of the warmer plate on the top - 2 storz screws but an allen key works as well 2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess 3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front 4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly. 5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely. 6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free 7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel. 8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece. 9) You will now see the plugged spouts. It goes back together really easily.
Aug 13, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
Keurig B30 Mini Coffee Maker Logo
120 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
