Question about KitchenAid KSBS25FK Side by Side Refrigerator
I have a KitchenAid KSBS25FK Side by Side Refrigerator. Sometimes it freezes on the top shelf. Everything on the top shelf is VERY cold. But when you put things lower they don't freeze. This is new.
  • 4,793 Answers
Check the door seals for fit an air leak will cause the same symptoms.you may have to adjust the door or seals to fit.
Posted on Jul 05, 2010
GE Profile Side-by-side Refrigerator TFX28PBBABB
Most ge have a Multispeed fan control on board. But if you had to start the fan with your hand, I would guess it would be a fan issue
Sep 08, 2012 | GE Refrigerators
My fridge side is too cold -everything freezes. I have the fridge setting to off and the freezer turned down to 1 and items on the top shelf in the fridge still freeze. The fan works well.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 22, 2011 | Refrigerators
Icemaker water line is frozen...i will remove everything and open the freezer door to let it warm up. When I chill the freezer again do I keep the icemaker arm up until the freezer is cold and then lower...
Dont leave freezer door open it will cause alot of problems. The ice maker will not call for water until the temp in freezer is cold enough. Remove the ice jam. If you remove from back of freezer it helps alot. Pull out of the back wall and remove ice be sure to put it back the way it was. Any further assistance please feel free to contact me.
Jun 16, 2010 | KitchenAid KSBS25FK Side by Side...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Need schematics for kitchenaid refrigerator
Can you tell which schematics you need as there are many. Thanks, Sea Breeze
Jun 15, 2009 | KitchenAid KSBS25FK Side by Side...
Freezing in refrigerator
Inside the fresh food compartment on top left there is something called an air baffle. It runs between the freezer and fresh food compartment and its purpose is to electrically control the amount of cold air coming from the freezer. Sometimes they freeze open and will not close. So you may need to turn off the refrigerator during the time you examine it. Look for ice blocking the movement of the baffle damper. Sometimes just one time clearing the problem is all you need to fix it. Let me know what you find and if you are able to get it going again, Thanks, Sea Breeze
May 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Refrigerator side freezes
sorry to be late with the reply, but Frigidare side by sides have a flapper valve between the freezer and refrigerator that breaks and the cold air enters the refrigerator unchecked. Remove the shroud in the upper part of the refrigerator and you should see it. Usually the flapper is broken off and layind down next to the duct.
Sep 06, 2008 | Frigidaire FRS23F4C Side by Side...
Top shelf on refrigerator side freezes everything into ice
well..that's most likely due to a problem with the relationship between the control and the compressor.
is your unit under warranty?
Jun 03, 2008 | Frigidaire FRS26R4A Side by Side...
KitchenAid KSBS25FK Side by Side Refrigerator Logo
181 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
