Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Washer is making a strang growling sound and will not drain
    Champion:
  • 274 Answers
The washer is clogged,take clothes out and see if it emptys,if not try draino-max and wait1-2hrs. and try cycle again. No clothes
Posted on Jul 05, 2010
My washer will not drain the water out their are still clothers in the machine
Sounds like maybe the water pump is messing up. make sure there is nothing in the pipe to the drain or in the drain under the washer tube. I once found a credit card had some how gotten under the tub and blocked the drain hole. it was hard to get out.
Dec 30, 2014 | Washing Machines
Washer won't drain
It sounds as though you may have something in the pump housing such as a coin or small chain which would prevent the implore from turning so remove the pump again and dismantle it if there is something there it will be easy to remove.
Mar 28, 2017 | Washing Machines
Washer machine wont drain
Good Afternoon Danny, this is JK. I understand that your washer is not draining. Is the pump making a humming sound? Yes, than it could be just a restriction in the drain line. If you do not hear a humming sound you might have a bad pump or timer. If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect. Hope this helps!
Mar 18, 2014 | Frigidaire Washing Machines
Whirlpool cabrio washer f 33 error code
Whirlpool Cabrio strange fix. This thing acted strange, If I went to drain spin it would run trying to work but I could not cancel this function and would have to unplug to reset the machine I had the F 33 fault code, I pulled the drum out and found about $2.00 worth of change. Then I put the washer on it's face and removed the back panel then disconnected the hose to the pump and spun the impeller to make sure no blockage was present. lt was clear so I reassembled the washer and washed one load of clothes and had the same problem occur. Washer would not drain or spin. Went back to work on the washer and in the process of moving it out from the wall I disconnected a 4' hose that I hadn't disconnected the first time that I have running to the drain from the drain hose on the washer, at this point I noticed water coming out of the washer drain hose. To make a long story short my 4' drain hose addition had a ripped up sock plugging the hose. Unbelievably this sock made it through the washer and pump and plugged up the hose. I never thought a sock could make it past the impeller so if your Cabrio is not draining or spinning check the hose past the pump, you may have an easy fix.
May 16, 2013 | Washing Machines
Washer will not drain and it makes a strange sound
on the front of the washer theres a panel under the door, remove it and there will be a drain plug open it and remove the gunk! there are two screws under the front panel by the floor!
Apr 11, 2013 | Kenmore HE2 Plus Front Load Washer
Ghw9100lw1 washer is not draining as well as it should. I believe the pump may have some debrees in front of it or something. The drain hose and line are open and draining freely. The machine is making...
Hi browny376,
You may need to clean the drain filter on your machine, find instructions on how to do it, by reading this following tip:
ACCESSING AND CLEANING THE DRAIN FILTER
Kind Regards :-)
JEDEMEYER1
* If you found this solution helpful, please rate it.
Jul 12, 2011 | Whirlpool Washing Machines
Our washer wont spin fast and shuts off saying ND code. what does that mean
ND means that it is Not Draining. Does it make the same water-pump sounds that it used to make at that point in the cycle? In my machine, it sounds like a low-pitched loud hum when it's working.
It might be that your water pump needs replacing. If there is any strange sound (such as grinding) then there might be a coin or something stuck in the pump.
Sep 29, 2009 | Samsung WF337AA Front Load Washer
Fridgidare affinity washer will not spin, makes a growling noise
use a shop vac and attach it to the end of the drain hose remove all the water then you need to check the drain pump and see if there is anything blocking the pump.
Sep 27, 2009 | Frigidaire Affinity ATF7000E Front Load...
Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See www.neptunehelp.com for disassembly photos and for more info on the faulty door latch wax motor.
Jan 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Slow to spin and making a loud noise.
Control boards don't growl, the fry out and die. Sounds like a drive train problem to me. If it's a front load machine, the spindle/bearing assy. has gone to washer heaven. If it's a top load machine... could be the transmission, brake/clutch assy. or the tub bearings. In either case, if it's less than 5 years old, the drive system will be warrantied through the manufacturer. If you could provide a make and model number, I could narrow this down to a fine point.
Dec 15, 2006 | Kenmore 43142 Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
153 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
