Login to the router, with the current password, and then change it.
Or, turn the router off.
Straighten one end of a Norwegian paper-clip, and insert the end into the small hole in the back of the router, to completely reset the router to its "factory" settings. Then, you can start again to configure the router.
Click "Apply Changes". Your new password is now
active.
Do
not forget the new password and keep it somewhere safe.
If you forget your password, you'll be unable to access your router's
settings. If you forget or lose your password, you'll need to perform a hardware reset on the router. This will reset the password to
its default, as well as erase any
and all other settings you may have changed.
All Belkin Router's ship without an admin password. If you require an admin password then follow the below instructions.
Setup steps:
Click "Apply Changes". Your new password is now active.
Note: Do not forget the new password and keep it somewhere safe. If you forget your password, you'll be unable to access your router's settings. If you forget or lose your password, you'll need to "restore to factory default". This will reset the password to its default, as well as erase any and all other settings you may have changed.
Use a strong alphanumerical (letters/numbers) password.
Setup steps:
Setup steps:
