Question about Vacuums
I have a ge dehumidifier Model# ahr40lmg1. I have a hose hooked up to it but the water keeps going into the bucket.
Sheikhtijani
  • 1284 Answers
SOURCE: I hooked up a hose
Hi, check to make sure the drain hole connection on the Dehumidifer's reservoir, that you have the hose hooked to, isn't plugged.
Also, you might want to see if the hose connection on the reservoir, still has the "knock out plug" still in place. Look at the hose connection on the reservoir, and if you can't see through it, or put a screwdriver through it, you need to punch it out the middle with a screwdriver. Open up the hole as much as you can so it will drain into and through your hose.
Check your hose also, as it might be plugged, disconnect it and blow through one end to make sure the water can flow through it.
Those are the only three things that could be preventing it from draining out the reservoir, through the hose connection, and through the hose to your drain
Take care
Posted on Jul 18, 2010
  • 3 Answers
SOURCE: we have a zenith dehumidifier
I've had the same issue with mine. I am a 12 year refrigeration tech. I checked the float switch which would normally cause that indication light. However manually pushing the switch and then checking it with an electric meter that was not the case. I think that is instead, an error code set by the manufacturer to assist the service tech when or if this failure occurs during the warrenty period. I also checked the next possible failure in the sequence of opperation which would be the compressor overload relay. That is sometimes why, as some people have posted, that after when unplugging the unit, it operates for a short time then again fails. In my case that was the failure. If that would have not been it than I would have tried the compressor start relay. I purchased the overload relay from my local HVAC/plumbing supply for around 7$. The control can easily be replaced by any handy homeowner. Also, as a service tech, 7$ and two wire nuts is better than a 145+$ service call.
Posted on Mar 20, 2011
  • 1833 Answers
SOURCE: dehumidifier Zenith ZD300y0, indicates
Make sure that you have water bucket and drain hose properly connected.
You may need to replace the sensor.
Posted on May 26, 2011
  • 142 Answers
SOURCE: I have hooked up a
Cut out the plastic in the bucket where the hose attaches to allow the water through.
Posted on Jun 01, 2011
  • 6 Answers
SOURCE: Hooked up a drainage hose
Unit needs to be tilted slightly back to drain, put a thin spacer on front wheels only.
Posted on Jul 13, 2011
I'm just looking for a owners manual for a Whirlpool Dehumidifier model AD50USL3 to see if there is anyway to connect a hose to run to a drain instead of having to empty the water collection chamber.
If your looking at the front panel of the unit look on the left side of the bucket there is a cover for the optional hose attachment.
Jun 20, 2011 | Vacuums
I have hooked up a hose to my firgidaire energy star dehumidifier, 25 pint, but it is still draining into the bucket. What do I do?
Jun 01, 2011 | Vacuums
My dehumidifier shuts off within a few minutes of turning on. There is humidity in the air but it is not collecting any water in the bucket. I feel air being sucked in the front and blown out the back. I...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 21, 2011 | Vacuums
Should my dehumidifier be blowing air out? It is also not collecting water?
heatman101
Apr 17, 2011 | Maytag Vacuums
Dehumidifier fan appears to be working, but no water is being collected in the vessel. 'Clicking' noise when in operation
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 12, 2011 | Vacuums
Our dehumidifier(Simplicity Model 43-54006 ) all of a sudden has stopped pulling water out of the air. It runs but it does nothing. Any suggestions? Thank you.
heatman101
Sep 02, 2010 | Vacuums
I have a GE dehumidifier that i hooked a garden hose to for direct drain. it will work okay for awhile then will only drain into the drain bucket. is there something i can do to ensure that it will drain...
This seems to be a fairly frequent complaint on these GE dehumidifiers, and none of the solutions I've read here or anywhere else have fixed mine. My hose is clear, straight downhill, tight to the nipple with a good gasket, no plugs visible in the nipple, but has always filled the bucket rather than drained through the hose (and it's always bone dry). After two years of this and emptying the bucket, I'm about ready to disassemble it to see if I can fix it but with all of the other unresolved complaints I've seen GE should step up to the plate and post a solution.
Aug 19, 2010 | Vacuums
I hooked up a hose to my Whirlpool dehumidifier for continuous drain and returned the bucket like the manual states. The bucket continues to fill and shut off. Model AD25DSS1 Serial Q1123013
Take care
Jul 18, 2010 | Vacuums
How to install a new water pump on a big Green machine?
I have replaced this pump before, and had the pump "seize" again. I hooked the output of the bissel to a siphon pump to pull a vacuum while i had the input hose (with the little filter) submerged in a bucket of water. After i got the pump started, I submerged both the inlet and outlet hoses (after the trigger handle) into a bucket of warm water and turned the spray switch on to circulate clear water through the whole deal
Jun 27, 2008 | Bissell Vacuums
Vacuums Logo
48 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
