Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
KitchenAid Superba. Freezer gets frost all over
KitchenAid Superba. Freezer gets frost all over the inside then eventually stopps freezing and causes the fridge side to stop cooling also. If I turn it off and let all the frost melt then turn it back on it works fine for about 5 days then does it again. Any idea what could be causing this and how to fix it?
    Top Expert:
  • KitchenAid Master
  • 63,373 Answers
If it is supposed to be a frost free, then either the defrost element has failed or the timer for same has . I would suggest you call a repair service tech.
Posted on Dec 28, 2017
SOURCE:
  • 1073 Answers
SOURCE: Kitchen Aid Superba side by side
check the relay on the compressor
Posted on May 16, 2008
  • 15 Answers
SOURCE: frost free fridge freezer freezing
make sure that the vents between the freezer and box are not frozen..check to see if the fan in the freezer is working(evaporator fan)..check timer and defrost heater,,
Posted on Aug 18, 2008
  • 4 Answers
SOURCE: Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
Posted on Apr 24, 2009
  • 75 Answers
SOURCE: my kitchenaid superba ksra22fkss fridge side not
open freezer side and check if the inside fan is running if it is then you may need to replace the heating element around the evap coil
Posted on Jul 03, 2009
Illeagle
  • 525 Answers
SOURCE: KitchenAid Superba fridge section not cooling, freezer is cold.
You have done a good job of attempting to diagnose by process of elimination, but this is a more complex system. I have provided some links below to assist you in diagnosing your problem. Links courtesy of www.repairclinic.com.
1. Ascertain that the evaporator fan is operational. This may be controlled by the Door Switch, (No.4) and could cause the fan to be inoperable.
2. Ascertain that the Fresh Food compartment light goes off when door is closed.
3. The air diffuser may be faulty by not controlling the air flow from the freezer properly
Tip: Always maintain dual temperature control settings at equal or +/- 1 setting position.
How refrigerators work:
http://www.repairclinic.com/0088_4_3.asp
You will need to verify operation of the following components listed below:
1. Evaporator fan motor
2. Air diffuser assembly
3. Light switch for refrigerator/freezer light
4. Door switch
Click on the links to identify the parts listed
1.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di921541&PartID=921541
2.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di827263&PartID=827263
3.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di438889&PartID=438889
4.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di586519&PartID=586519
Parts breakdown diagram:
http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram
Posted on Aug 13, 2009
Frost in freeze and refrigerator not cooling
Your unit is in need of a auto defrost repair..There are 3 components that might need replacing..1 defrost heater..2 defrost thermostat..3 defrost mechanical timer or newer models have a computer PCB type control..usually all 3 are replaced to guarantee resolve of problem.
Jan 04, 2018 | KitchenAid Refrigerators
Does it make sense that the freezer is very cold and the frig is warm on our kitchenaid Superba frig?
freezer may be frosted up look on the back wall of freezer see if there frost if so there is a defrost problem there is a defrost control that may be bad
Oct 04, 2010 | KitchenAid Refrigerators
Kitchenaid superba side by side top is too warm,
The defrost cycle is suppose to be automatic on this model. To see if you have a defrost problem take the lower container out of the freezer, and empty the bottom shelves enough to see the back panel inside the freezer. If there is a build up of frost on the panel or the slots in the lower back panel the automatic defrost is not functioning. The most likely suspect is the ADC or automatic defrost control. This control runs about $120.00 and is located in the console of the fresh food section (top).
If there is no frost check to see if the fan in the freezer is running. If the fan is not running you have a failure of the fan motor which is a little less expensive but a bit more challenging to replace, the shelves, the shelf slides and back panel of the freezer have to come out to replace this motor.
Apr 18, 2010 | KitchenAid Superba Architect KSCS25INSS...
We have a superba fridge/freezer. the problem is
A model number is necessary to correctly help you with this problem.
The usual cause of the problem is the ice door not fully closing allowing warm, humid air to rise into the freezer. This will cause cubes to fuse together causing a large jam inside the dispenser. There is a kit available which contains all the parts necessary to correct the problem. The kit does not fit all models so the model number is necessary.
Replacing some of these parts can be quite a challenge for non-technicians although the kit comes with instructions.
Jul 09, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Upper half of refrig/freezer not cooling
The First thing I would check do you ever hear a fan running inside the freezer . No Fan could cause that. if that is running now check the back wall of the freezer is there frost building up on it if there is then your unit is not defrosting and that could also cause that let me know what you find and I can help from there.
Apr 03, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer freezing up
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer is only cool, everything melting
  • possible causes:
Jun 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
Warm freezer
seems to me that the freezer control motor is not pushing the freezing gas around cooling the unit. Suggest an engineer.
Thanks J
Jan 26, 2008 | Engel Freezer Portable Freezer & Warmer
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
94 people viewed this question
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
