Question about VillaWare Mickey's Classic 2 Slice 5555-07 Toaster
My lever won't stay down for toasting
I have a villaware Mickey Mouse Classic 2 slice toaster. I love to hear the Mickey tune and see his face on the side of my toast. Now I'm not able to use my toaster because the lever won't stay down.
  • 883 Answers
SOURCE: 4 slice toaster
open the unit. look for disconnected wires from sloppy factory
Posted on May 21, 2007
  • 69 Answers
SOURCE: Black & Decker T-1029 2-slice Toaster - lever broken
Main problem with these is crumbs, they get stuck between the 2 surfaces of the small electromagnet that keeps the lever down, consequently it does not stick anymore, try drop kicking it in the drection of the garbage can, this sort fright may just scare it into working again.
Posted on Sep 25, 2007
Ian Prins
  • 11 Answers
SOURCE: toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Posted on Dec 06, 2007
SOURCE: when i push the lever down to make toast, it does not stay
no solution, problem, my lever (sometimes) will stay down, sometimes not, but it makes a loud "ractething" noise many times when the lever is pushed down>
best, randy
Posted on Dec 12, 2007
SOURCE: only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Posted on Sep 05, 2008
The lever won't stay depressed
mcdevito75 here, The lever mechanism could be worn OR the setting for darker / Lighter toast is set to Light, swtch to darker see if that helps.
Jun 22, 2010 | Breville CT40 Retro Classic 4-Slice...
We have the four slice toaster. The arm on the left will no longer stay down. The side still toasts, but the arm will not lock in the down position.
try removing the lower claening plate and remove the bread crumbs and see if that makes it work again. Many people don't know there is a cleaning try on the toaster.
Mar 21, 2010 | VillaWare 5850 Uno Classic 4-Slice Toaster
I just bought this kenmore 2 slice toaster and the toast lever won't stay down!?
Make sure it is set dark enough. Some toasters will not stay down if they are set too light.
Feb 11, 2010 | Kenmore 135101 2-Slice Toaster
Villaware mornin toaster 5555-11 When you put the
When you push the slide down on the side, there's a wire that it pushes down inside the toaster. If the wire gets bent down a bit, pushing the slide down doesn't push the wire down enough. The wire is like a teeter totter. When it gets pushed down, it closes the circuit which turns the toaster on. The reason why the slide doesn't stay down is without energy, the electromagnet doesn't get engaged. That's what keeps the slide down. You need to remove the 4 screws on the bottom, and the 2 screws that hold the legs on that also hold the side on with the slide. Once the side is off, take a pair of needle nose pliers and bend the wire up a bit that acts as the teeter totter.
Jan 03, 2010 | VillaWare Mickey Mornin' 5555-11 2-Slice...
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
When i push the lever down to make toast, it does not stay
This is a problem, our old toaster had this problem, and it would only work if we jammed the handle down, but don't try this, only because ours broke after we tried this, but if you can send it to the manufacturure, they should be able to fix this. If you don't what to do this, please phone me at 505 9181, but please call me from 8:00-10:00, 2:30-8:00.
Oct 21, 2007 | Cuisinart CPT-60 Custom Control Total...
Toaster lever wont stay down
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Aug 11, 2007 | Black & Decker T1029 Classic Chrome...
VillaWare Mickey's Classic 2 Slice 5555-07 Toaster Logo
Top VillaWare Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Michael Vincent Cruz
Angel Joseph Jr.
Angel Joseph Jr.
Are you a VillaWare Kitchen Appliances - Other Expert? Answer questions, earn points and help others
