Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
WHICH BUTTONS DO I PRESS TO FORCE THE DISH DRAWER TO DRAIN EXCESS WATER?
  • ralexander_a Jul 04, 2010
    I DO NOT HAVE A KINKED HOSE AND THE MACHINE IS FINE. A LARGER AMOUNT OF WATER SEEMS TO SOMETIMES REMAIN IN THE TOP DISHDRAWER AND IT WAS SUGGESTED BY MY SERVICE TECHNICIANS THAT THE MACHINE IS WORKING PERFECTLY BUT THIS MIGHT BE DUE MY SIMULTAEOUS USE OF THE NEARBY SINK OR WASTE DISPOSAL WHICH CAUSES THE PIPES TO BE 'OVERLOADED' SO SUFFICIENT WATER IS NOT PUMPED OUT OF THE DISHDRAWER. I AM AFTER THE BUTTON KEY CODES THAT THE TECHNICIAN USES TO FORCE THE MACHINE TO DRAIN WATER. THAT IS WHAT I NEED. CAN YOU PROVIDE THAT?
  • ralexander_a Jul 05, 2010
    There is no button labeled drain -- there is 1)power on/off 2) start/stop and 3) lock. inside there is a button to choose the cycle (heavy pots/ regular/ glasses/ rinse/ etc).
    I need to know from someone who actually knows the Fisher and Paykel machine dd6031 double dishdrawer what the series of technician button presses is that will force the machine to drain excess water. There is nothing wrong with the hose -- the water remains according to my service technicians probably when we use the nearby sink at the same time as the machine is trying to drain. I just want to press the correct buttons to force the machine to drain.
    Thank you.
  • Fisher and P... Master
  • 3,247 Answers
Just run the shortest wash cycle and check if it empties in the end. If not, then you have some blockage in the filter sump.
Go to the part of the user guide which explains how to clean drain filter and filter plate.
Hope this solves the problem.
Posted on Jul 05, 2010
  • Sam Jul 05, 2010
    Sorry did not get to see your earlier comments to another fixya.com consultant previously.
    What you need is to go into diagnostic mode and run the Fast Cycle as there is no drain cycle available.
    Press and hold Keylock, then Start/Pause for 5 seconds
    All LEDs & LCD segments except Keylock are illuminated
    Press Power Button Twice
    FC will show in the display ( for integrated: Heavy, Normal, Delicate, Rinse LEDs showing)
    Press Start/Pause Twice
    The 5 minute fast test cycle will start
    Press Power
    To exit
    Hope this achieves what you are after.
  • Jade Haggerty
    Jade Haggerty Feb 17, 2018
    Thanks, worked a treat. :)
  • 10,865 Answers
Hello. There is usually a button labeled drain. Push it and let it work. Then open the door and check. If there is still water that is an indication that there is a problem. Usually, debris stuck in the drain pump, the drain hose, or the sink trap. Last week I had a dishwasher call and discovered a chunk of glass in the drain pump. That glass was too large to get through the pump and resulted in an inch or so of water remaining in the floor of the dishwasher. Once I removed that chunk of glass the problem was solved. J.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Press the cancel/drain button to drain the excess water. If the dishwasher is still not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 04, 2010
Water in crisper drawer of Whirlpool model number ET18TK
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
Dec 25, 2013 | Cars & Trucks
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have the fisher and paykel dish drawer DD630 and on both of the dish drawers the F-1 signal is flashing... and will not shut off. I do not know where my power supply is..I thought i would take all...
Hi
F1 error means that the flood switch has been activated. You'll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please click on this link to locate repair centers in Ukiah, CA. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 16, 2010 | Fisher and Paykel (IWL12)
Kitchenaid refrigerator mdl KTRS22M has water under veggie drawer
Hi, water could be excessive moisture, check door gasket, or check drain at back above veggie drawers, could be block, make sure produce not blocking drain hole, clean, check carefully for drain.
Aug 02, 2009 | Refrigerators
Water will not drain out of top drawer
To determine if your pump work, before attempting access from the bottom of the top drawer: You can manually pump the water out by doing the following:
1- Press the Power button to turn off the display.
2- Press the Lock button and then the start button the same tim. Hold them until the display showing up.
3- If the display is not clear with all the characters, press power button to see clear the display.
4- The first display is bL, then Er,Ld..dd, FU, P1, P2...by pressing the Start button to go by the sequence until P2 (drain). If you miss, be patient to continue press and release the start button to get back to P2.
5 When is is at P2, press Lock button to tun on the drain. When you hear the water flowing to the drain, you could pull the top drain to see how the water is draining.
6- When the water is out, press the lock button again to stop it.
7-When it is done, press the Power button to get out of manual mode.
If this is working, then your water is there because you are running the bottom and your air gap allow back flow to the top drawer.
Please let me know if this is not the case.
Jun 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water won't drain
To determine if your pump works, before attempting access from the bottom of the top drawer or from the bottom of lower drawer: You can manually pump the water out by doing the following:
If this is working, then your water is there because you are running the bottom and your air gap allow back flow to the top drawer and or you are running the top and your air gap allows a back flow to the bottom drawer.
Water in top drawer
I am not a repairman but have installed several duel drawer dishwashers. Most dishwashers have a check valve preventing backflow. Water under pressure will always follow the path of least resistance and in your case it is going into the upper drawer. Be sure the drain is open and flowing easily under your sink whether that be the disposal or a TEE. It may help if the drain line is elevated as high as it can go under the sink just before it reaches the drain. How often do you use the top drawer? Perhaps run a cycle on the hottest cycle without dishes to attemt to clean or force through any contaminants in the check valve through into the drain. Hope this helps, Ken
May 01, 2009 | KitchenAid 23 in. KUDD01DPPA Stainless...
FP DD603 draining problem
This device will solve the issue of cross-draining between drawers on Fisher paykel double dish drawers.
http://fisherpaykelparts.net/index.php?categoryid=1&productid=7
Aug 10, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Fisher and paykel dish drawer
U1= Machine has failed to prime with water within
approx. 3 minutes
 The water supply is not turned on
 The machine is syphoning
 The spray arm is not in place
 Excessive foaming
 The Inlet Valve has failed
 The electronic controller has failed
 Rotor not fitted correctly
Jun 26, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hotpoint WD440 1400 Spin
There has been an unbalanced load and the machine could not spin
(see ‘Automatic Features’, Starting and Programmes).
Has the drain hose been installed correctly (see Installation)?
Are the drain hose, standpipe or undersink connections blocked?
Has ‘Rinse Hold’ option been selected? If so press the Rinse Hold button
drain hose make sure there are no kinks and the end is over the top of washer to drain this ensures that there is no back flush with drain pipe
clean the dispenser drawer regularly
Clean and dry the dispenser
drawer, syphons, grate and
fabric conditioner exit channel
(A). Also regularly clean the
outlet pipe area
Never force the machine door: this could damage
the safety lock mechanism designed to prevent
any accidental opening
May 21, 2008 | Hotpoint Aquarius WD640 Front Load...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
9,646 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
