Question about Maytag PAV2300 Top Load Washer
Spin cycle problems
When going into the spin cycle it will start to speed up but then the motor cuts out (like a overvoltage sensor trips) and it stops. sometimes it will spin but most often just shuts down. Wash cycles work normally.
    Champion:
  • 274 Answers
The machine is unbalanced.try moving clothes around.
Posted on Jul 05, 2010
I have an LG washer that get stuck in low spin at 10 minutes left.
If you just do a spin only cycle does it go fully sped?
May 16, 2018 | LG Washing Machines
Keeps tripping power at 13minutes remaining, just before the spin cycle
Hello. It sounds like the motor has gone bad--possibly a shorted part of the motor, or a jammed drain pump. It also could be the transmission binding at the point of going into spin mode. You didn't provide a brand/model number so my help is limited. The clue here is the clicking before the power trip.
Aug 19, 2015 | Washing Machines
How to fix the spin cycle on my Whirlpool washer?
Usually Debra you have to replace the motor when this happens motor is weak and heating up cutting out to soon ..Hope this helps
Mar 02, 2015 | Whirlpool WFC7500VW Washer
Ci 394 washer
during which part cycle the spin or pumping the water out just before spin cycle just before is the pump which may have been jammed pull it out and check for debris like the underwire from a bra if its the spin check belt if not belt than chances are the motor is going bad to check you would have to put a meter on it and see what amps its pulling
Mar 26, 2014 | CDA Washing Machines
Power trips in spin cycle
Pump is leaking water and causing problems. Replace the fault part and clean thoroughly.
Feb 27, 2014 | Samsung Washing Machines
SPEED QUEEN TOP LOAD WASHER HA4011W. Motor trips at SPIN start
I would call whoever repaired the washer back out and have them diagnose.
Jan 23, 2009 | Speed Queen AWS52NW Top Load Washer
My washing machine is tripping the circuit breaker
sorry to hear about the problem it will be your motor or module try online for recon both these parts are prone to go on bekos
Jun 14, 2008 | Washing Machines
MAYTAG MAH5500BWW Fails to spin properly clothes wet
I replaced the motor and circuit board but that did not fix it. I changed the out of balance switch and the shock absorbers or snubbers. I think the ultamate fix was the snubbers. it has worked great since. They wear out like your car shock absorbers allowing the drum to shake too much triggering the out of balance switch to stop and restart the spin.
Oct 22, 2007 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool gold washing machine
It is either a timer issue or a motor issue. I know, that you knew. But if you have a motor with like circuitry and size, you can try that or to put it into the spin cycle and see if it is a mechanical obstruction or with a voltmeter see if the timer is working.
Apr 19, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag PAV2300 Top Load Washer Logo
157 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
