Question about Pacific Digital PRIMEVIEW801 Video Recorder
Lost remote I have lost the remote control for my Pacific tv and need to change to av channel to play on my Wii does anyone know if I can do this wihtout the remote? Help please
Go up to ch 80 and the next one is the AV ch
Posted on Jun 29, 2008
I need to know how to change my tv to channel 3 without the remote.
look along the side right or left and there is a row of buttons . they do all the functions a remote will
Mar 06, 2015 | Samsung Televison & Video
Can not play video in dvd/vcr player
Well yes whether it be a DVD/VCR it has to be played on the AV-Channel. If you don't have that yet just scan your tv via remote control, but do it manually because automatic skips the av channel. otherwise check that the video itself is not damaged
Mar 30, 2009 | Philips Magnavox DVD/VCR Dual Player
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
you might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
Mar 12, 2009 | Televison & Video
Lost remote
Actually I found there are several remotes that work. The first is the Bright House networks remote, the larger one...The second is The Universal Remove Control by GE. It's numbered 24944 in the upper right hand corner of the paper. It's sold for $4.94 at Walmart in the checkout area...
I found that manually inputting the code for the remote doesn't work. You have to do a search for the code using their method...on this particular remote from Walmart, its hold the setup button down until it lights up, then press and depress the TV button...then press channel up until the TV changes channels. It worked once, but I just kept going, the 2nd time it worked, then I pressed the mute button [to keep the code] and it works...you simply press input and it switches to AV.
I have to admit I thought it was ridiculous that you can't use this particular TV without the remote, but I was happy that I went through the effort the first time to keep trying remotes...
This is the first kids TV that I have found that you can't find the AV channel by going through the channels AND you can't hook up two items to the AV outlets because you have to disconnect the back or front ones, to use the other....PLUS it only comes with a dual AV outlet, instead of the 3 plugs [red, white, yellow] only has the white and yellow.
A disappointing TV to say the least.
Feb 11, 2009 | Emerson SpongeBob SquarePants TV
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
Hitachi C28W440N can't switch over AV channels no remote
have you tried buying a universal remote? you can get a decent one for £10 these days from any electrical store, such as curry's or maplins. it gives you a 3 digit code for the tv to link up with the remote and then you can switch over to av. some hitachi tv's also link up to av automatically if you connect your game station via scart socket (in the back of the tv) if you turn the tv off and link your wii up to the back and make sure the power is turned on before the tv is switched on, there's a chance the tv will auto detect the av channel. not all do but it's worth a try. hope this helps!
Dec 25, 2008 | Symphonic ST419E TV
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
Change TV channel on SAMSUNG DVD-VR350
Hello Giancarlo, You'll have to use the projectors remote for T.V. tuning. I don't think the samsung DVD remote will operate your projector or your T.V. channels, will it? If it does, You just have to switch the input button on the remote to change between T.V. and Video. I hope that helps.
Jun 02, 2017 | Samsung DVD-VR320 DVD Recorder/VCR
Game systems
Try channel buttons on TV, if it doesn't work then you'll need a cheap universal remote control.
Aug 27, 2008 | JVC AV-32S33 32" TV
Teenage mutant Ninja turtles 13 inch TV
My son has a TMNT tv and the remote is broken or just the button to turn it to the games. I bought a universal remote and it does work some so that he can play his games but it doesn't let him enter two digit channels to change them so he has to scroll through them to get where he wants. It is an RCA - RCR312W remote and is universal but I had to go through the steps for the auto code search which was a little confusing and took a little while. The remote only cost about 8.00. All of the features don't work and I am sure that with a little playing around I could figure out the brand from the code but I haven't yet. Hope that this helps and if anyone else has a better solution please let me know.
Thanks!
Jun 16, 2008 | Emerson SpongeBob SquarePants TV
Pacific Digital PRIMEVIEW801 Video Recorder Logo
374 people viewed this question
Top Pacific Televison & Video Experts
RSole
Are you a Pacific Televison and Video Expert? Answer questions, earn points and help others
