Question about Tefal UltraGlide 1659 Iron
FV 9330 iron, stopped heating
Is it worth to send it for repair?
How much it will cost the repair or would be bettrer to buy a new iron?
Will not heat up. Light comes on
Small appliances are not worth repairing. The heating element is defective. Buy a new iron.
Nov 06, 2015 | Irons
It does not heat up
The heating element is defective. Buy yourself a new iron. It is not worth repairing it.
Sep 21, 2015 | Irons
My iron went nuts and got way to hot. I shut off and the next morning it would not heat up. What to do?
I would say you throw it away and buy a new one. The heating element probably shorted out, overheated and is burned out. Too expensive and not worth the effort to repair.....
Dec 03, 2010 | Black & Decker D2030 Iron
I have described my problem repeatedly. Again - My Oreck Cord-Free Steam Iron JP8100C series stopped heating
Ok whenever an iron stops heating it is either the Thermal Fuse,or the Element or the actual temperature control. One would have to use a meter to check the Voltage at the element of the iron. & Test the Thermal Fuse.
Also though with Cordless irons it may simply be that your batteries aren't working as they should. They can quickly be ruined if not charged correctly.
I do NOT think, that this is a job for a home repair due to the added complexity that the batteries add.
You need to take it to a professional repair center and ask for a "Quote" before allowing any repairs to proceed. As the cost of repair may exceed the cost of a new one.
Aug 08, 2010 | Oreck Cordless Speed JP8100CA Iron
I HAVE A LEAKY IRON, SUNBEAM AND ROWENTA
Buy a new one , the tank seals have gone and it is not worth repairing it.
Cost of parts plus cost of fitting = new iron with a 12 months warranty
Jan 14, 2010 | Rowenta Powerglide DE011 Iron with Auto...
Power Light goes on but iron will not heat
If it is more than 3 years old (no warranty) then you can get it repaired or replaced. The heating coil is broken. The heating coil in the iron cannot be fixed, but must be replaced.
If the iron is less than 3 years old, you can get it repaired under warranty; however, shipping and other costs may not be worth having it repaired. (More than $30).
If you can get an estimate, you might want to have it repaired.
My recommendation? Replace it.
Sep 03, 2009 | Rowenta Irons
Sunbeam Steam Master Iron 4048-015 stopped working after cleaning. Will not heat. Can it be opened to look inside?
any steam iron more than a few years old...usually isn't worth repairing.  Just buy a new one.
Mar 24, 2009 | Sunbeam Irons
I have had 2 Shark irons and both simply stop turning on
The cost of repair is more than the cost of a new one. Therefore, trash it and buy a new one.
Mar 11, 2009 | Euro-Pro Shark GI490 Iron
Iron will not heat up when it is on. The lights come on when plugged in but not the heat.
Your electric iron probably has an open heating element.. Probably not worth repairing.. since thecost to repair might be equal to the cost to replace.. Wrinkled clothes are making a comeback... ( at least .. in my house..LOL) Good luck my friend !
Sep 04, 2008 | Westinghouse Irons
Doesn't heat up...
Authorized Appliance And Repair in St. Louis Mo, works on all model Rowenta Irons.
Nov 01, 2007 | Rowenta Professional DX8800 Iron
Irons Logo
69 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
