Question about Whirlpool Duet GHW9150P Front Load Washer
Won't restart or clear off
Opened during add a garment sequence, added garment, shut door, failed to restart. The time remaining continually flashes and the machine will neither start nor clear. What do I do now?
  • Anonymous Sep 21, 2008
    I tried to add a garment during the "add a garment" light and the washer would not restart.  It just continued to flash the minutes left during the cycle.
    President:
  • Whirlpool Master
  • 2,651 Answers
Try unplugging for a few min adn replug see igf that clears the computer, you didinbt by chance force the door open to addd a garment didi you??? if so the door lock has probalby beed compromised
Posted on Apr 18, 2008
Posted on Sep 22, 2008
Door won't open, Add Garment Light flashes
Not enough weight in the washer I am guessing. Try adding more clothes.
Jan 06, 2015 | Whirlpool WFW8300SW
Kenmore HE2 flashing lights
did the technician point out wat needs to be repaired
Aug 24, 2008 | Kenmore 46462 Front Load Washer
Hoover Nextra HNWF 3135 Door Not Locking
1) since you do not have any error code, because you do not mentione, we must shure you have problem with the switch door, test for open or defective and replace, Test the wires loose, or broken wires.
God bless you
Jun 28, 2012 | Washing Machines
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Will not restart after adding clothes
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. Wait for 2 minutes before trying the door. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Apr 19, 2009 | Whirlpool GHW9300 Duet Washer
Control Lock
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,655 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
