Question about Kenmore Washing Machines
Hi...I have a Kenmore front loader washing machine Model 44152. Yesterday I interrupted the spin cycle and removed the item. today i tried using the maching and it will not start. the green lights go on and when i press the start button it just flashes. i have unplugged it, waited, and replugged it but to no avail. is there anything else i can do before i call sears for repair. i would greatly appreciate if someone knows what is going on. my thanks pat seghers
  • 1,284 Answers
Hi, you made a wrong move by disrupting and interrupting the spin cycle of the washing machine which is definitely the reason the machine would not start up.
Interrupting the spin cycle has affected the control board (electrical power related problem) which means the control board needs to be serviced before it can start work again. Contact sears as you have rightly suggested and it will be fixed.
Take care
Posted on Jul 04, 2010
Kenmore 43142 front loader bangs during spin cycle any ideas on what the problem might be?
always check the load to the drum is not to heavy on one side, this could cause it to bang.
Aug 25, 2012 | Kenmore Washing Machines
Drum will not spin
did he run the diagnostics per the tech sheet within the machine?if it will do everything else but spin out,then the drain pump is plugged,as a plugged drain pump will shut down these front load units,you will need to remove hoses off pump and clean out pump and all hoses from tub to drain stand pipe,by running the diagnostics you can run each washer cycle and see what cycle isnt performing in a matter of 5 minutes versus 1 hour real wash time on some cycles
May 01, 2012 | Kenmore HE2 Plus Front Load Washer
Have a front loader kenmore model # 41744052400 washing machine
Ours doesn't even spin. I'm trying to connect with a repair guy.
If we gets our repaired, I'll try to remember to get back to this page.
Good luck with yours.
Apr 07, 2010 | Kenmore Washing Machines
My Kenmore front loader model #44152 continues to smell even after using magic washer and tide washing machine cleaner. It works for about 1 day then continues. Is there any other solution?
Use white vinegar and hot water to rinse out the machine and wipe down the rubber boot. Leave the door open after using it and dry the boot off after the last load of the day.
Eric
Sep 17, 2009 | Kenmore Washing Machines
Kenmore front loader not draining.
Hi, UNPLUG the washer and shut off the water. Remove the lower front panel and you can access the water pump. You will need a wet/dry vaccuum to **** up the water as you open the sump cap on the pump. Spmetimes you can lower the drain hose into a bucket and get water out. Once the water is removed, open the cap and see if the filter is plugged as well as the pump inlet/outlet ports. This is common. If there are no obstructions, check voltage to the pump. it should get 120V.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Kenmore Elite 45986 Front Load Washer
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
How do I get a repair manual for my Kenmore front loader
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 04, 2008 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Kenmore Front Load 3.5 cu ft Washing Machine, NO SPIN CYCLE
is it in a diagnostic mode? unplug from wall for 15 sec or so and try again.
May 15, 2008 | Kenmore Elite 45986 Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Washing Machines Logo
fordexpert
Mike Squire
Robert Rankin
