Question about IBM ThinkPad T41 Notebook
What is the little gadget under the dvd tray? Theres' a slide button, and if you push it to the right, a smaller "tray" pops out... it's about as big as a dime. I bought this used, and did not get the manual.
    Brigadier General:
  • 10,406 Answers
From the manufacturer's web-site:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-46474
look at the "exploded" view of the T41, and identify the part.
Posted on Jul 04, 2010
How do i open to place an cd on the acer computer?
This is your laptop's (Acer Aspire 3680) right side, do you see the tiny button in the middle? Turn on your laptop and click it, it will open and you'll be able to place a CD.
Jul 21, 2014 | Acer Aspire 3680 Laptop
Samsung Optical Drive SE-208 tray rattling won't eject
if you look on the drawer you will see a little hole.push a pin in the hole and the drawer will open.
Nov 15, 2012 | Samsung Optical Drive SE-208AB/TSBS...
How do I add more staples to a Panasonic Electric AS-302N stapler
I have one right here. Push the button in the back (above where the power cord enters the machine.) The tray holding the strips of staples should pop out of the front of the machine. If it doesn't, try grasping under the staple tray and gently pull the tray out while pushing the button in back.
The button is a release button, while the tray is spring loaded to pop out..
Jul 14, 2011 | Tools & Hardware - Others
Cannot remove dvdrw on acer aspire 5720z
If the button on the side of your laptop will not open the drive then you can try two things.
1. click start at the bottom left of your desktop (7 and vista will be a windows logo) then click computer. A list of hard drives and cd/dvd drives will show up. hover over the dvd drive with your mouse and right click. Then click eject, the tray should open.
2.Get a paper clip. located on your dvd drve cover is a small hole just big enough to fit a paper clip in. Push the paper clip in and pull it out it should pop open the drive.
May 07, 2011 | Apevia Acer Aspire 5720Z AC Adapter - 90...
Inserted a DVD wrong way around (silver side facing towards us) now we can not ejecetd or play it.
Here are some options from best to worst and I recommend that you turn off the computer beforehand
Use a straightened paperclip and insert an end into the auto eject hole. (A little pinhole on the front of most disk drives)
Use a knife or flathead to pry the disk tray open.
If it doesn't have a tray you could use tweezers to pinch it out of there
I have pryed open disk trays before without issue
Mar 15, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
I cannot open the door of my computer to get disk out
On the front panel below the tray that slides there is a tiny hole.
Straighten and insert a paper clip, apply a little pressure and the tray should unlock slide out.
Oct 11, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
DVD stuck, computer won't turn back on
If you look at the door of the CD/DVD tray/shelf, you should see a little hole. Stick a paper clip into the hole and it will pop out the CD/DVD tray/shelf and you can get your DVD back. I would call Gateway support to fix the rest of it. If it is still under warranty, they can send out a tech to fix it.
Sep 28, 2009 | Gateway MX8711 Notebook
Change of CMOS battery in IBM Thinkpad 1400 2621
This battery is hidden under the keyboard slightly up and to the right of center of the keyboard. To get it out is a pain.
Start with the computer sitting flat, lid closed, lid latchs facing you.. just like you were getting ready to open and use it.
Spin it around, rear ports facing you. Right above the external video port, on the right hand side, there are two screws, at a diagonal UP from the port itself, very close to the bottom edge of the LCD. Remove them. There is a small notch between the screws, using a small flat-blade screwdriver, pry up in the notch and pop the platic backing free from the rear of the laptop. DO NOT open it more than a small crack, you are just popping loose a small plastic tab. Open it too wide and you will lock it closed again or break the plastics when you open the LCD lid.
Spin the machine around again, and open the LCD carefully as far back as it will go normally. Find the Power Button. The Power button is to the far right of a plastic 'strip, with 4 other buttons on the far left. There is a small clear plastic strip overlying this button 'tray'. Find the small notch in the bottom edge of the clear plastic strip, use the flat-bladed screwdriver, and gently pry up, popping the plastic strip out of the tab holes in the tray. Under this plastic strip is a black adhesive 'strip' that has a house, magnifying glass, etc. markings on it, and 'i Series' or somesuch printed on it.
Using a razor blade, peel up the black adhesive strip on the left and right ends of the button 'tray'. You will find two small silver screws. Remove these. Then using your screwdriver, or as I did, a dental pick, *gently* pry up the entire tray from the BACK edge of the tray, and by lifting up the left side of the plastic tray. You will have to work it out from under the edge of the LCD bottom on the left side. DON'T yank on it, there is a small cable attached to the bottom of it. You will be able to rotate it toward you and roll it over, exposing the small latch holding the cable in place. Its a small, press-fit latch like what holds a keyboard cable in place. You'll need to work it open by lifting the left and right edges till the latch becomes loose. Pull the cable straight out of the slot, remove the entire plastic 'tray', and set it aside.
On the far upper right of the keyboard there is a small metal tab holding the right upper edge of the keyboard. Reach around to the back of the computer, right-hand side rear, find the little square thumb-notch, and pull it out. The latch on the upper right edge of the keyboard should retract. Now, while lightly pressing down on the keyboard, push the keyboard away from you. It should slide backwards and the front tabs on the front keyboard edge will pop out of the slots. Lift up the touchpad area, popping up the bottom edge of the keyboard, clear of the plastics, then pull the keyboard slightly toward you. It should pop loose all the way around. DO NOT yank on it, there are 3 small cables attached underneath. You wil need to lift the keyboard up enough to reach the cables and pop the lockdown tabs loose, then pull the cables straight out of the slots they are in. The cable slots are attached to the motherboard, the cables are attached to the keyboard.
Removing the keyboard will expose a flat silver panel underneath. There are 5 screws holding down the panel, 4 in a 'box' configuration on the left, and a single one on the right, and several slide-tabs around the edges. Remove all 5 screws, then slide the whole tray to the right, while lifting up. The entire tray will pop up, with the video card heatsink attached on the left-underside of the tray. Set this aside. Directly in the middle of the big hole you now have is the battery. Its smaller than a standard desktop motherboard battery, looks like a small silver button. Gently pry up on the bottom-left edge of the battery, very carefully or you will break the plastic clips holding it in place, and pop it out.
All done. Reverese order to put it all back together.
Feb 21, 2009 | IBM Thinkpad I1400 2621 Planar TV...
Razer Diamondback
under the big plastic slide of the mouse theres a screw you just need to take out .. then gently pop it open the bottom end and pull it back.. DON"T TRY TO PULL IT OPEN COMPLETELY.. there is a little hinge that holds the top 2 buttons in place. just pry open the lower end and gently pull back.
Oct 31, 2007 | Razer Diamondback
IBM ThinkPad T41 Notebook Logo
65 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
