Question about Sanyo DP46848 LCD TV
The screen is very dark on one side with line running through it. It used to fix itself after it warmed up but now it is worse than ever
4 Suggested Answers
SOURCE: I have a Sanyo 46 inch flat screen hdtv purchased
I have the same problem, my television is faded black on the left side with lines on the left top side. I have had the 46 inch unit for 1 year and 7 months. I am planning to write a demand letter to Sanyo and then taking them to small claims court woth evidence that this is a common problem with their units that they know about and is not trying to remedy. Also the Attorney general in Texas should have an interest in them (Walmart and Sanyo) selling these defective proucts in the state.
Posted on Jul 28, 2010
There is no solution this has happened to me 3 times in 13 months each time they replaced the screen panel (basicly the whole TV) I have a 2 year service contract, the next time it does it they will not bring it back but will write me a check for the price I payed for this peice of ****.!!! Do not bother fixing it.
Posted on Oct 22, 2010
joeguest2
  • 2080 Answers
SOURCE: I have a SANYO DP46848,
This is likely a problem with your TCON circuit board inside the back of the tv.
The TCon board usually has 2 (or 4) very thin ribbon like cables running from connectors on the board to the actual LCD screen panel. Each ribbon controls one half (or one quarter) of the screen. If you are lucky, it's possible one of the ribbons came loose or is not making proper electrical contact with the connector on the TCON board.
If your tv is out of warranty and you are comfortable working safely with electronics then you may be able to repair this yourself with a few hours of screwdriver work. The ribbons may just need to be reseated in the little flip up connectors, or you may have to clean the copper at the tips of the ribbons gently with a pencil eraser to remove any oxidation.
If you are unlucky enough to have a bad TCON board or are not comfortable disassembling your tv yourself then you can bring it in to the shop and they can probably repair it for less than $150.
Good luck and please post back with how you make out.
Posted on Jan 25, 2011
Fix wet tv
Replace all ur vertical section condenser .
Apr 15, 2014 | Televison & Video
LN-T4971F dark on the right side of screen.
Hey Steve,
Sorry to be the bearer of bad news but you have a bad LCD panel tab. There are videos on youtube that show you how to repair this but they are temporary in nature.
Jun 28, 2013 | Samsung Televison & Video
Red vertical lines on right side of LED TV set
It is likely the main board that processes all signal to and from the display panel (entire front screen unit).
It is also possible it is the display panel itself which is fatal.
May 16, 2012 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
I have a Sanyo 46 inch flat screen hdtv purchased from walmart sept, 2009. Sure enough, months later my tv is having picture problems and getting worse. It started having portions of the screen darken,...
Call Sanyo for warrenty repair,tv is less than a year old.The problems,u discribing could be cause by the Tuner board,that the board,where the incomming broscasting signal cable plug into it.Worse cause,the LCD picture screen is shorting out and dying,than the tv is not worth repairing.The LCD screen panel are 90% of the tv,will cost the same as a new tv,if the LCD screen panel was to be replaced.Sorry,than the tv not worth as a whole tv any more,only as electronic's boards for parts,that it.
Aug 12, 2010 | Sanyo DP46848 LCD TV
Dark, horizontal lines after text and dark images.
This implies that your monitor had gone bad. you need to take it to a computer repair shop.
Apr 10, 2010 | HP w1907 LCD Monitor
Sanyo 46 IN. tv DP46848. The left 1/3 of screen is dark
It is a common problem for this model of a Sanyo TV, it uses a Samsung or Chime LCD panel.
The problem is the data buffer IC soldered on the flat flex cable between the LCD panel & the buffer board that gets damaged or loose soldering. If you be able to fix yourself, you may find some videos on YouTube, it will show you how to fix the buffer problem.
Jun 01, 2017 | Sanyo Televison & Video
I have a Sanyo 46 inch flat screen hdtv purchased from walmart aug. 31rst, 2008. Sure enough, 13 months later my tv is having picture problems and getting worse. It started having portions of the screen...
Nov 01, 2009 | Sanyo DP46848 LCD TV
Dark streaks on the inside of the screen
If it's an LCD TV, then what your seeing is Liquid Crystals inside. Chances are that someone has bumped the LCD or damaged it, and now the screen is broken. The "Dark Lines" are from misfiring pixels which is a sign that the LCD is damaged and will either stay the same, or get much much worse. I'd lean towards much much worse.
Just keep it until it really gets bad then just replace it. You can have it fixed, but the repair would cost more then just buying a brand new one.
Oct 24, 2008 | Televison & Video
Sanyo DP46848 LCD TV Logo
216 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
