Question about Philips GoGear HDD6330 MP3 Player
Help My Computer says it is plugged in but wen i go to music player (WMP) it says no device is detected and i think its a problem with the usb because i plugged in my Webcam and it showed it was plugged in can some1 direct me to a site or help me with this problem
  • Acidstarsz May 11, 2010
    My mp3 player has a faulty hard disk but this solution didn't work.
  • 476 Answers
Could be a faulty hard disk in the player.
You can check as follows:
Connect the HDD6330 to the power supply and PC.
Press and hold VOL+ & POWER ON to reset the player.
As soon as the player resets, release VOL+ & POWER ON, and quickly press and hold VOL--
Keep hold untyil the PC registers the player.
If all is ok the HDD6330 will show as a Rmovable Drive n:
Check that you can access the files on the player, if so the problem lies with the PC or connection.
Posted on Apr 20, 2008
Tevion MP4 Player TM311 Just bought one & I'm completely confused by it ! If I plug it into my computer to download anything, it just looks as if it could be charging and none of the buttons...
when you plug in usb it becomes a local hard disk. (look in my computer plug in usb and you'll see it appear. open and you can now drag and drop music files (mp3) into disk. for video use the converter tool included and hard disk. read the manual which came with device and it explains all. i reckon it's a great gadget for the money. regards t
Aug 12, 2011 | Audio Players & Recorders
I just bought a Sony NWZ E354 mp3 player. When plugged into my usb front main port, computer sees it as MTP device but disables it. I' running Win XP Pro and WMP 11. Take same player and its...
I upgraded my usb drivers -- I have windows xp pro -- i think they use all the same -- I used Realtek USB 2.0 card reader drivers. ( http://bit.ly/qeofyZ ) plugged it in (NOT in the front, but the back)_ & it recognized it after going to start, computer as "walkman" -- did a right click explore & all the data/music was still on the hard drive. then it showed on the walkman that it was charging & the battery was dead. i was previously using an AC usb adapter (plug in the wall) & it didn't seem to be charging it correctly -- so the computer works out for me & will only use that from now on -- fully operational.
Jul 14, 2011 | Sony Ericsson Audio Players & Recorders
Help cant put music to my mp3 player!!!
sounds like its defective i just loaded my music straight from WMP return it and get a new one.
Dec 27, 2009 | GPX MW3837 MP3 Player
Doesn't show up when i plug it in to my laptop
To download music or photos on to your Philips GoGear, you need to use a computer that has Windows Media Player and Device Manager already installed. Once these are installed, the steps to sync your Philips GoGear Jukebox using Windows Media Player are fairly easy to follow. Follow these steps to sync your Philips GoGear.
Connect your Philips GoGear to the computer with the USB cable. The USB connector on the GoGear is on the top, and will be on the front or back of your computer. You will see a USB connection icon as soon as the GoGear is connected to the computer.
1.Start Windows Media Player from the Start Menu or from the desktop. To transfer files to your GoGear from your computer, click Copy to CD or Device (with WMP 9) or the Sync tab (with WMP 10). 2.Find the Items to Copy pane. In the drop-down list, click the category or playlist that you want to copy to your GoGear. Make sure that items that you do not want to copy are unchecked. 3.Locate the Items on Device pane. In the drop-down list, click GoGear. When you have selected the items that you want to sync, click the Copy (with WMP 9) or Start Sync (with WMP 10) button.
Apr 25, 2009 | Audio Players & Recorders
Help downloading onto computer
This is an easy process, just connect a commercial USB cable that is compatible with your device or the USB cable that came with it to ur computer. go to my computer and double click on the MP3 player drive icon. Navigate to the MP3 drive folder where ur music files are stored, launch windows media player( WMP 11 is AVAILABLE AT MICROSOFT.COM/DOWNLOADS) or if you already have windows media player 11, that's good. click on tools in WMP and select OPTIONS, click on LIBRARY and click on MONITOR FOLDERS. select ADD to add your MP3 player drive to the list of monitored folders, after you finish adding the MP3 player to the list, click on OK and windows will search the drive for music and video files and add them to your WMP Library.
Dec 14, 2008 | SanDisk Sansa Fuze MP3 Player
Can't download music onto my Sansa e250
If you have more than one USB port try another port. If not try downloading Yahoo! Music Jukebox.
Dec 27, 2007 | SanDisk Sansa e250 MP3 Player
Files on player are not listed in wmp or in windows explorer
change the settings of the player to MSC and connect the device to your computer. It will be detected as a removal disc drive. Open it and it should contain the folders in your player. IF you can only see a few folders. Click on Tools-Folder Option - Show hidden files and folders. Then you should see the folders that you have. Right click on the song and choose delete.
Aug 14, 2007 | SanDisk Sansa m230 MP3 Player
WMP won't detect my MP3
See if this helps: -Close all programmes on your computer. -Turn off your Sansa e250. -Attach the cable into the USB port of your computer before attaching it into the actual e250. -The scroll wheel on the Sansa should have turned on by now. -Then it's just a matter of waiting for a few seconds. -Try opening Windows Media Player to see if it detects your device. Otherwise, be patient. Goodluck.
Mar 15, 2007 | SanDisk Sansa e250 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
