Question about Car Audio & Video
Where do you find the relay for the cooling fan on a 1990 mercury topaz we understand there are two fuse boxes on the car but we can only find one
    President:
  • 2,468 Answers
They are under the hood in a plastic box marked electrical fuses/relays on or near the drivers side of the engine compartment open this plastic box and there's a fuse/relay diagram under this cover
Posted on Jul 05, 2010
Cooling fan relay location
should be right on the fan,fan schroud, or in that area.check u r owners manuel if u hav 1.
Apr 21, 2013 | 1988 Mercury Topaz 2 Door
Where is the fusible link for the cooling fan on a 93 Mercury Topaz?
I can supply only general information. There are actually three fusible links: a 20GA DK BLU (YEL wire), a 20GA BLU (RED/LT GRN wire), and a 14GA DK GRN (YEL wire). All three wires connect to the constant control relay module which has a RED output wire connected to the powertrain control module (PCM), a BLK/LT GRN wire connected to ground, two DK BLU wires connected to the electric cooling fan, a TAN/ORG wire connected to the PCM, a LT GRN/PPL wire connected to the fan, and a LT BLU wire connected to the PCM. Sorry for the roundabout description but it's all the information I have
Oct 07, 2012 | Mercury Topaz Cars & Trucks
Overheats raditor cleaned and flushed no power to fan 94 mercury
try the fan tempature sending unit. it tells the fan to come on at certain tempature if it went bad it wont tell the fan to come on
Jul 11, 2010 | 1994 Mercury Topaz
HI. This relay is very hard to locate. It is located just to the left of the battery ,as you are looking face down at it. It will be tucked up against the left radiator support, near the headlight. look in between the battery and the radiator and you should see it there.
Jul 04, 2010 | 1990 Mercury Topaz
1991 Mercury Topaz
I'm surprised there isn't a cover that has the diagram on it but for the fan its gotta be a relay under the hood i'd say
Apr 05, 2010 | 1991 Mercury Topaz 4 Door
FUZE BOX DIAGRAM FOR 1990 MERCURY TOPAZ
Replacement
  1. Access the fuse panel from the left of the steering column.
  2. Locate the blown fuse and pull out. DO NOT TWIST.
  3. Take note of the ampre number written on the top of the fuse. To install:
  4. Push a new fuse of the same ampre into the receptacle, making sure the contact is being made on both sides of the fuse.
LOCATIONS Headlights and Highbeam Indicator
  • One 18 amp circuit breaker (22 amp in 1987 vehicles) incorporated in the lighting switch.
Front and Rear Marker, Side Parking, Rear and License Lamps
  • One 15 amp circuit breaker incorporated in the lighting switch.
Windshield Wiper
  • One 4 1⁄2 amp circuit breaker located in the windshield wiper switch.
Power Windows
  • Two 20 amp circuit breakers located in the starter relay and the fuse block.
Power Seats and Power Door Locks
  • One 20 amp circuit breaker located in the fuse block.
Hazard Flasher REMOVAL & INSTALLATION NOTE: The hazard warning flasher is located on the rear side of the fuse panel.
  1. Locate the hazard flasher in the fuse panel.
  2. Pull the flasher out. DO NOT TWIST. To install:
  3. Push new flasher into place making sure a good contact is made with both terminals.
  4. Test flasher to make sure they function properly.
Various Relays LOCATION Cooling Fan Controller
  • Located behind the left side of the instrument panel.
Cooling Fan Controller Module
  • Located behind the right side of the instrument panel.
Cooling Fan Relay
  • Located in the air conditioning cooling fan control module.
Electronic Control Assembly
  • Located under the left side of the instrument panel.
Electronic Engine Control Power Relay
  • Located behind the glove box on the right side of the instrument panel.
Fuel Pump Relay
  • Located behind the glove box.
Horn Relay
  • Located in the fuse block.
Fig. 1: Main fuse box located on driver's side to the left of the steering wheel, above the brake pedal
This is the best info I could find....I hope this helps ya!
Jul 23, 2009 | Mercury Topaz Cars & Trucks
Aparently there are 2 fuse boexes in a 1990 mercury topaz i need to know where they BOTH are
The secret fuse box is under the hood on the driver side fender wall.Be careful there are spies everywhere trying to find this piece of high tech fuse concealment. :-)
Jun 23, 2009 | 1990 Mercury Topaz
Where is the fuel pump relay located on a 1992 Mercury topaz
the fuel pump relay is located on the left shock tower in the engine compartment in a black box 6x4x1 inches. there are other relays inside the same box which is actually called the ccrm or constant contorl relay module, there should be a double connector with 20 to 26 wires in it, hard to miss.
May 31, 2009 | 1992 Mercury Topaz
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
