I can't get the sound on my samsung 403t flat screen monitor to work. i bought some brand new pc speakers that i plugged into the the audio jack on the back of the monitor , and it still doesn't work. help!
  • 484 Answers
The monitor is not meant to produce any sound. Monitors do not produce sounds.
For you to get any sound, it has to be from the CPU or any other device you connect the monitor to.
Connect the speaker to the CPU or the device you connect the monitor, and it will produce sounds.
Take note, your CPU should have a sound card that the speaker is to be connected to.
Take care
Posted on Jul 04, 2010
I have a samsung flat screen TV with a3.5 mm audio out jack when plugged in to dvd player audio in rca jacks no right channel plug head phones into tv have l and r channel.
The audio jacks on the DVD player get connected to the audio IN RCA jacks on the TV The audio out jack on the TV is for a sound bar or amplified speakers.
Nov 24, 2015 | Samsung Televison & Video
I have a samsung syncmaster 403T lcd monitor..its working good in self tet mode..picture is ok.. working normally,the problem is when i connect to pc or any video signal suddenly work after goes to wh
Sounds like T'Con board fault. Contact any service technician. When video signal interfaces, it goes overloaded. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 23, 2014 | Samsung Televison & Video
I bought Philips auxiliary speakers for my Samsung monitor (used with HP desktop computer) which has no speakers. They worked fine until I moved...upon hooking them up in my new location...I do not have...
Hi, I think you connected it wrong. Make sure it is in the green plug on the back of the PC. If that does not fix it. You may need a new audio card. Good luck.
Aug 03, 2011 | Philips Audio Players & Recorders
I have a Samsung P2771hd monitor. I have green and black cords (for sound and microphone) coming from the computer. I bought a cable that has the black plug from the pc that splits to the red and white...
The Red (right channel) nand White (left channel) RCA plug to miniphone jack is made for audio amplifier with RCA input jacks. The monitor should have Green audio input mini stereo phone jack for the audio input from the PC audio line out (Green mini phone jack).
You will need the shielded audio cable with mini stereo phone plug at both end for the audio hook up.
Dec 21, 2010 | Samsung P2270HD 22" LCD Monitor
No sound from built in speakers HP VS 17. Device is working properly when i checked the device manager and i can see the speaker icon in the taskbard. was working before i shifted the desktop to a new...
Try using MP3 player feeding the monitor to see if you get the sound OK first. Are you using stereo male to male mini jack for connection from PC audio line out (Green jack) to Monitor audio line in (Green jack)?
Feb 27, 2010 | HP Vs17 17" LCD Flat Panel Monitor
I recently bought a Windows 7 64 bit PC. I have Optiquest monitor with built-in speakers. The sound was working fine and then it stoppped. I tried stand-alone speakers, then anoither monitor with speakers-...
Go into control panel / sounds / sounds and audio / select audio blind / should see a driver listed in each device. Back to sounds blind /test sound, if you can see the black arrow but its greyed out then driver is faulty. If you can click on it and it changes baxk to th esquare all is OK, ensure the sound jack is plugged into the GREEN ones at rear PC. Also check in volume blind that speakers are selected.
Feb 24, 2010 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Do I need speakers with my syncmaster 2233 for sound, if so WHERE do I plug them in on the computer?
Yes you do! Simple speakers with one jack plug into the green jack plug connector either on the front or at the rear of your computer.
Nov 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Can't get my laptop speakers to work through headphone jack
the reason for this is that the audio thru this jack is attenuated to a level where you don't loose quality and to prevent ear damage. You better try the audio out or audio monitor output jacks located in the back of the tv(if this model comes with them). you'll probably need an audio amp to get the speakers to work properly though.
Sep 09, 2009 | Insignia LCDTV26 26 in. Television
Relisys Sound
CJ,
1. Check make sure the audio cable are plugged in from the monitor to the PC output audio jack (light green).
2. Open your on screen display and go to Volume settings. See if it set on mute or set to 0.
3. Turn of your monitor & PC and unplugged all the cables from your monitor and PC wait for 10 seconds and then replugged it all the cables and audio cable back. Then turned on you PC...
4. If it still doesn't work.. open the back cover see if the speaker cable are plugged in.
5. If that doesn't work...then your monitor AD board built-in speakers are defective.
6. Why not just used a external speakers, it give better sound quality.
Have a nice weekend!
Aug 17, 2008 | Relisys RLT1720 17" LCD Monitor
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
