Question about Mastercool Portable Air Conditioner
Have a master cool MMB10 and all of a sudden the fan runs slower on both speeds. Motor bad or something else?
  • 76 Answers
Mine did that too. Either the motor needs to be cleaned out or the motor is shot. You can try to have the motor repaired. If that fails a replacement motor is about $120 if you can find one.
I posted this to another solution for someone looking for the motor:
Unless you can find an HVAC shop with a NOS motor for this unit you will not find a drop in replacement. Even if you do get lucky and find a NOS motor be prepared to pay nearly as much for it as you would a whole new evap cooler.
That said, there are motors out there that will work, but you're going to have to make them fit with custom mounts.
It's still a little spendy, especially if you want two speeds like the original motor had, but you can get out for $80 or less if you're willing to settle for one speed (on/off).
boatandrvaccessories.com has a "Packard 40066" compressor motor for $69 plus $13 shipping. It may work but has only one speed.
Basically what you're looking for is a "48 frame", 1/8 hp, direct drive, 110-120v, 1075rpm, 1/2" shaft diameter and around 3" in length (to give you flexability when mounting), "totally enclosed" or "open drip-proof" housing (NOT "open"). Rotation can be either CW or CCW as you can mount the motor on either side of the housing and some motors are reversable. If you've got the skill to custom make some mounts then you can probably fudge some of these specs. The ones you can't change are the 1/2" shaft and the RPM. Do not exceed 1075rpm. The blower assembly simply can't be made to go much faster in that housing and if you try you will overheat the motor and burn it out very quickly (trust me on this one!). Most of the cheap motors I've found are 208-230v and I just don't see the point in having a small 220v PORTABLE evap cooler, that's just dumb.
After a LOT of online research I've found the following motors that would be a suitable replacement, with all the above mentioned specifications. I'm sure there are more, but cross referencing this information for someone not in the business is tricky and time consuming.
AdobeAir 1/8 HP 115V Motor for Adobe MMB10A RF031095 $116.66
http://www.comfortgurus.com/product_info.php/cPath/25_142/products_id/7451
Emerson 4856 (k055srj4796722b) (www.emersonmotors.com)
A.O. Smith 136A (UH1036NB) (www.aosmithmotors.com)
Magnetek 136 (now owned by A.O. Smith - www.aosmithmotors.com)
Fasco D733 or D261 (fasco.com)
Marathon X924 (www.marathonelectric.com)
AdobeAir RK232A check acehardwaresuperstore.com
Emerson K55HXKZT-9867
Grainger.com is a good resource but they are expensive.
The motors listed are suitable replacements, but have only one speed, "ON" or "High".
Packard 40066 - 115v 1075rpm $69 - SINGLE SPEED
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Good reading for selecting a replacement motor:
http://www.aosmithmotors.com/WorkArea/DownloadAsset.aspx?id=13100
I suppose that if you found a smoking deal on eBay for an "Open" type motor you could try it, but I doubt it would last long and make damn sure that ****** is grounded well.
Posted on Sep 06, 2010
Cooling fan motor gets hot when running high speed why
Check the bearings. If the friction is high the fan will not run at rated speed. When it runs slower it uses more current and gets hotter...
Disassemble, clean and lubricate to make sure fan runs full blast and does not burn out.
Or if the fan has two windings, one for starting and one for running it is possible that the high speed run winding has some shorts in it resulting in more current and more heat.
Oct 13, 2015 | Cars & Trucks
I have a Dometic Duo-Therm model no. 59516.531 AC. The fan runs slowly and the seems to run but doesn't cool because the fan doesn't run fast enough. Any help on where to start?
try testing the capacitor for the fan if there is one. if there is multiple speeds on the fan motor see if it is getting the correct voltage to the motor if it is getting reduced voltage it will cause it to run slower. U can find the max voltage on the side of the motor and just test the motor by making up a lead if u can.
May 22, 2014 | Dometic Rooftop RV Air Conditioner
Air conditioning
please follow this steps and fix it.
A fan failure, or a failure of the fan relay or control circuit is bad news because it can allow the engine to overheat.
Five things may prevent an electric cooling fan from coming on:
  • Defective temperature switch or coolant sensor
  • Engine thermostat is stuck OPEN (engine never gets hot enough to turn on the fan)
  • Failed fan relay
  • A wiring problem (blown fuse, loose or corroded connector, shorts, opens, etc.)
  • Bad fan motor
ELECTRIC COOLING FAN QUICK CHECKS.
One way to quick check the fan circuit is to start the engine and turn on the A/C to max. If the fan runs, the fan motor, relay, fuse and wiring are all okay. But this test doesn't show if the temperature switch or temperature sensor and PCM are energizing the fan when coolant temperatures are high.
To check the temperature at which the fan comes on, turn the A/C off and keep the engine running until it reaches normal operating temperature. Most fans should come on when the coolant reaches about 200 to 230 degrees. If the fan does not come on, something in the control circuit is defective. Resistance checks should then be made on the temperature sensor or switch, and a voltage check on both sides of the relay (you will probably need a wiring diagram of the fan cooling circuit on your vehicle to identify the relay terminals and wiring connections).
The fan motor itself can be checked by using jumper wires. Unplug the wiring connector on the fan, and use the jumper wires from the battery to route power directly to the fan. If the fan motor is good, the fan should spin at normal speed when supplied with 12 volts. Noisy bearings or a slower than normal speed would indicate a worn motor.
Jun 11, 2013 | Cars & Trucks
01- Dodge Caravan AC Heater Control it only works on high none of the speeds work when I rotate the switch from low to high. Is this a swith problem or a motor problem?
Most likely neither. The most common cause is that an electrical device called the blower motor resister block, has failed. This device provides all the slower speeds. It is generally mounted in the HVAC [Heating, Ventilation & Air Conditioning] box, very close to the blower motor. FYI, we mechanics call the fan motor inside the cabin the blower motor. The electric fan motor behind the radiator is called the cooling fan motor.
If the resistor block is OK, then you have either a bad fan speed switch or a melted electrical connector at that switch. 95% of the time, the resister block is the problem.
Charlie
Aug 22, 2011 | 2001 Dodge Grand Caravan
One of the two fans is running slower ,is this normal ??.(intake fan)
Yes that is fine. Your motherboard controls the speed of fans connected to its case, cpu pinouts. Fans have ratings as well and default RPM specs that determine their speed.
Not to worry as long as the fans are turning you should be ok. If you are uneasy, fans are really cheap to buy. (9-$18) is all you need to pay for one.
Regards, Chris
May 19, 2011 | Cooler Master Coolermaster Hyper N620...
Why is my Whirpool Window AC fan speed not changing? I have replaced the switch already!
possible that the fan motor speeds have gone out.. On the cooling cycle the fan speed is set for higher speeds and heat cycle slower speeds. it is possible that the fan motor in that speed you are needing is burned out
Jul 11, 2009 | Whirlpool ACQ108XL Air Conditioner
No low speed on my mobile master cooler module no mmb12c
Could be as simple as the switch, could be as complex as a pole burned out on the motor. If you reverse the connections on the speed selector switch and you end up with low speed and no high speed then you know it's just an inexpensive switch.
May 30, 2009 | Cfm 2000 Swamp Air Cooler MMB10 MasterCool...
No high speed on blower motor
if motor works on heat, but not on cool ,then the low speed is energized by the heat strip or control board .if the motor doesn't run in high on cool, then the fan relay or black high speed tap from the board is not being energized. usually its the fan relay ,which is only a factor in cool in high speed fan mode. try turning fan to on at stat. that energizes fan relay and blower should run in high. gently tap the side of the fan relay and see if fan comes on all of a sudden. if it does the relay is bad. change it wire for wire label all wires and use exact replacement relay unless you know how to read wiring diagram then you can use a 90-340 generic fits all replacement. trace motor power wires back to relay or control board to find where they are fed from.
Dec 07, 2008 | Carrier Heating & Cooling
High cool not working
Compressors on these units runs at only one speed. The change to high cool is only a change in blower speed moving air faster over the cooling coil. I would have the running capacitor for the fan motor checked. A bad capacitor can cause your type of problem. The other problem could be that the high speed winding in the fan motor is bad. Try it operation in the fan only position through the two speeds. If it works in the low and high speed for fan only your problem could be in the selector switch.
Jun 23, 2008 | Dometic Rooftop RV Air Conditioner
Mastercool  Portable Air Conditioner Logo
1,644 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
