Question about LG LSC26905TT Side by Side Refrigerator
No power I tried different outlet and it still does not have power.
  • LG Master
  • 17,130 Answers
If your fridge is new then seek the help of the service warranty, what you can do from the outside is limited. you will have to check for any damage to the power cord, the connection to the main relay and motor, Please take extreme care when the power is connected and trace to see if the power reaches the main relay at the rear bottom. further also check if the fridge light works, the thermostat is kept normal. thre could also be any case of rat damage if you have some of them around. so check this out otherwise get help and watch on with this tip. Helpful ?good day
Posted on Jul 05, 2010
Check GFCI outlet(with the button) .You probably need reset
Posted on Jul 23, 2010
I have a 922 printer and it won't turn on.
Did you try plugging the printer into a known live outlet? If the outlet tests good and has available power, check and make sure that no panels have come loose and could have tripped a safety switch during your move of the printer which could cause a no power up issue to prevent damage to printer. If still no luck, try a different power cord and se if that works. Hope this helps.
Mar 10, 2014 | Dell 922 All-In-One InkJet Printer
LG LDS5811BB power cord is good, however the dishwasher is not getting any power. No lights no nothing.
There is a fuse on power unit, that should be tested first, check also a different outlet.
Aug 09, 2008 | LG Dishwashers
Tip
Laptop will not turn on, laptop will not power on, laptop will not start
Make sure your laptop battery has a charge. Plug it into the wall outlet for 30+ minutes and then try powering it on. When you plug it into a power source, usually the laptop will have a light indicating that it is charging. Look for a light. If the light does not light up, try a different wall outlet. <br />If it still does not charge, you may have a bad power cord, a bad laptop battery, the wall outlet may be bad or the laptop itself is damaged and will need to be serviced by a technician or replaced.<br /><br />Through the process of elimination you can narrow down possible causes.<br />-Try a different wall outlet(or by testing another device make sure the wall outlet is good)<br />-Try a different power cable.<br />-Try a different laptop battery.<br /><br />If none of the above help then you may need to have your laptop repaired(internal damage) or replaced.<br /><br />If your laptop is under warranty you should contact your laptop manufacturer or warranty policy holder to have it repaired or even replaced. <br /><br />If it is not under warranty you should look for local computer repair shops or technicians. <br /><br />-G33k<br />
on May 22, 2011 | Computers & Internet
Tcl model 21k77
Try turnning your tv off, unplug unit from outlet, press and hold down the power button for 30 seconds, let go of power button, if plugged into surge protector try wall outlet, if plugged into wall outlet try a different outlet, power tv on using power button on tv. Did you have a storm in you're area?
Jul 24, 2013 | Televison & Video
Breaker tripped and now my nintendo wii wont turn on
Few things to try:
1. Different Outlet. Plug the console into a different outlet in your residence. If the Wii turns on, the outlet is dead. I would recommend an electrician to fix the outlet.
2. Try a different power adapter. You could purchase another power brick or get one from a friend and use the new one to try and power up the console. Also try in a different outlet (step one) to be sure
3. If none of this works, the console may have just received too much power and burnt out the power supply. Contacting Nintendo. Information below:
http://www.nintendo.com/corp/contact.jsp
Mar 06, 2011 | Nintendo Wii Console
My D-Link AirPlus Xtreme DI-624 Wireless Router all of a sudden doesn't power up when I plug it in. I've tried other wall outlet on the outside chance that the outlet I tried doesn't work, but to no avail....
Base from the description of your problem that the router wont even power ON this can be cause by several reason , like the power outlet is bad and since you already tried a different power so that is not the problem, this can be a problem with the power cable that you have so if possible for you to try a different power cable to test the router that will be good and if still wont power ON using a different power cable the router is already dead and needs replacement.
Aug 12, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
My wrt54gx2 will not power up,is this a common problem and how do i fix it?
Did you try plugging it in to a different power outlet? If there is no power light on your router still after trying a different power outlet, this means that the router has gone bad .
May 22, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I get no power to the wii. I have tried different outlets and have checked to make sure a breaker wasn't blown. Other electronics work in the outlet.
same thing happen to me first pull the power cable out of the wii and out of the outlet let sit for 24 hours if it doesnt work call nintendo that is what i did
Jul 29, 2009 | Nintendo Wii Console
My wii does not turn on and all connetions are plugged in
Make sure power connection firmly in both ends.
Change power outlet... if plugging in to strip TEST directly to wall outlet.
Try differenct wall outlet.
Try different WII power adapter.
Jul 28, 2009 | Nintendo Wii Console
LG LSC26905TT Side by Side Refrigerator Logo
199 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
