Question about Sony KV-35V36 35" TV
No picture or sound
Tv set just turned itself off and acts like there isn't any power going to it. I tried to turn it on with the remote control and on the set itself....no success. I checked the plug and the set was plugged in at the wall and the tv set itself. All other items plugged into the power strip (the satellite receiver and dvd player) were both working ok. Please help!!!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 72 Answers
Often these errors are related to a bad solder joint on the main-pcb or crt-board or what was once just a solder connection failure to the vertical circuit is now a full cascade failure of the vertical output circuit. You can check this by tapping on some parts on these pc's with an isolated screwdriver. Whenever you tap, and the picture goes dark, you're sure it's a bad solder joint and you'll need to re-solder it. Also bad solder connections around the flyback transformer as well as in the vertical sweep circuits. Please If you have no TV repair experience, call in a tech to assist you in this repair. Good Luck and let us know how you made out with this repair.
Best Regards,
Beach TV Repair
Treasure Coast, FL
Posted on Jul 04, 2010
The sound on my Emerson TV went up by itself, and now I can't get it to turn down?
try to turn off with the TV, if does the problem is in the r.control
You must open the remote control, clean all keypads from dirty, corrosion, bad contacts, and oxide use contacts cleaner and try again.see the picture attached, the LED must be TURN ON, use digital camera5c53e0fe-ea86-4c30-b415-4c12054e98f9.jpg
God bless you
Jul 21, 2013 | Televison & Video
I have an LG model 37lc2d the screen is black but has illumination and no sound at all and the green power light flashes 16 times upon powering up?
Things to check: Make sure your TV is set to the correct input.
I DK about the light flashing 16 times but that could be a stuck key on your remote control. If you can, urn off your remote and try turning on by hand and going through the "INPUT" choices to make sure you have it on the correct setting. BTW, if your TV is 5 years old, you'll make the money back in no tie if you get a new "Energy Star" TV. The new Energy Star TVs run on very little electricity compared to 5 years ago.
Jul 03, 2012 | LG 37LC2D Television
My 52 ince screen stopped showing picture. It is just red, or yellow or green with thin vertical lines. I can hear that the channels are changing but no picture. Is there a reset button or something?
To reset the tv to factory/ default settings, please follow below procedure.
Turn On the TV, while holding down Up Arrow on the remote control, press Power button on TV, tv will turn itself Off then back On again, release Up Arrow on remote control.
This procedure will reset all settings in tv to default settings.
Problem seems with lcd panel and I'm afraid it does not seems to get solved by resetting tv however try to reset tv by above said procedure.
Thanks.
Aug 04, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
When i turn my tv on it says FDA Lock ON and then it turns itself off and wont come back on. it shows the power button is lit up but it has no picture and no sound. we have tried to reset the password to...
Hello
Your TV is locked I thinks. Do the following and see whether it help you.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Dec 20, 2010 | RCA TruFlat 27F520T 27" TV
There is shadows on the insdide of the screen
Turn your TV on by pushing either the power button on the front of the TV or the power button on the remote control, which is located in the upper right corner of the remote.
Step 2
Press and hold the "up arrow" button on the remote control. The up arrow button is located in the middle of the remote, to the left of the "Input" button and below the "Picture" button.
Step 3
Press the power button on the TV while still holding down the up arrow button. The TV will turn off and then turn itself back on.
Step 4
Release the up arrow button. Once the TV turns itself back on, it will restore your TV to its factory settings.
Hope this helpout.......
Aug 03, 2010 | Televison & Video
How do i reboot my konka television?
Step 2
Step 3
Step 4
Release the up arrow button. Once the TV turns itself back on, it will restore your TV its factory settings.
Aug 03, 2010 | Konka KDL32AT23U 32 in. LCD Television
My JVC 27" can not be turned on or off with the remote or the on an off button. Any ideas?
try all in one remote/it can be the infrared on tv not picking up signal/point remote does light flash on tv ?
Dec 23, 2009 | JVC AV-27530 27" TV
I have a Polaroid 37" LCD TV (FLM3732)
it could be 2 caps on the power board, i had the same problem and for $3.39 at Radio Shack solved it.
There is a link on hre with pictures and instructions from stiv0, that works. Of course your on your own if you try it.
Sep 30, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Set turns itself on and off with no picture nor sound
You have a major problem with this set. Could be the main board, the Y-SUS board, or the power board or some combination of these.
Mar 30, 2009 | LG 42PX3RV 42 in. EDTV-Ready Plasma...
Televison & Video Logo
123 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
