Question about JVC Audio Players & Recorders
I have a JVC RX-503 and I cant get any sound to come out of the speakers
5 Suggested Answers
The Marv
  • 72 Answers
SOURCE: JVC RX-618V SOUND IS MUFFLED
check to see if the radio is clear. If it is it may be the signal going into the amplifier. if it is muffled as well, depending if you have an Equalizer hooked to the unit. This also could cause the problem. Finally check the bass, treble balance and volume knob but turn them back and forth while unit is on and see if signal clears up momentarily. if this is the case the control knobs need to be cleaned. Also spin the connection jacks {RCAs} in the rear and see if this clears it up. If not you may have to have the unit serviced by a professional.
Posted on Aug 05, 2006
djnick989
  • 1067 Answers
SOURCE: JVC STERIO RECIEVER MODEL RX-554VBX
on remote try to un mute it is a ch only on not a and b or none use a ch only go in main menu of system cheak auto mute turn off
Posted on Jan 30, 2008
  • 51 Answers
SOURCE: speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Posted on Jan 02, 2009
  • 4234 Answers
SOURCE: JVC RX 703v My equipment
The key here is whether or not the unit clicks. When turned on, you should hear an initial clcik followed a short time later by another. I suspect that you are not hearing the second one. This indicates that the unit is in "protect" mode. Please see the link below for an explanation of protect mode. Feel free to post any additional questions here.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Posted on Aug 19, 2011
I have a JVC RX-9010V I am not getting any sound but i am using smaller speakers rated at 8 omns but the one is rated 150 watt..no sound no hiss..The amp does click as it where turning on, have seen n
Have you tried re-initiating it ? Strange the unit initiates but no sound.
Sorry, I forgot exactly how, but you can Google " factory reset
JVC RX-9010V". hope that helps.
Oct 27, 2014 | JVC RX-9010V Receiver
As this radio shack trc 503 cb radio will only transmit but it has loss it audio sound and no noise as nobody seems to don't why this has loss it audio and soun
If its RX audio you have lost then your audio chip is faulty or the speaker, try an external speaker or new internal speaker
Oct 24, 2013 | Radio Shack TRC-503 CB Radio
My jvc rx-500 has no sound, it turns on and functions but no sound
you might have the speakers turned off there is a difference between mute and speakers on and off mute will stop sound but speaker off and on stops power from getting to the speakers that may be your problem.Is your amp makin any weird noises?
Mar 20, 2013 | JVC Audio Players & Recorders
JVC RX-801V - No sound from right channel in speakers or headphones.
I'd troubleshoot first, even though you've already tried the headphones (good thinking). Get a battery (AA battery works) and put the black and red wires on opposite sides to see if the speakers are working.
Is there a menu of settings on the jvc, and is it set to 5.1? Just trying to help...
Jan 15, 2012 | JVC RX-8010V Receiver
JVC RX-8030V, I have TV Audio hooked to back of receiver (TV Audio In) but I cannot get any sound from TV to Receiver, I can hear the speakers humm when I plug the cables in but then it goes away and no...
First of all, it is bad form and potentially dangerous to be changing cables with speaker power ON. Second, IS the unidentified TV passing audio out those jacks? Its own audio menu and controls may be between the sound and the jacks.
Oct 02, 2011 | JVC RX-8030V Receiver
My left channel in my JVC RX-305 isn't working...what do I do to fix it? When I either push the volume up or down it makes a clicking sound. It was working just fine last night. My right channel is...
Try swapping the speakers or just check the left connections WITH POWER OFF. Disconnect the left speaker completely and see if the clicking stops.
Sep 05, 2011 | JVC RX-618V Receiver
I have a JVC RX 554v Receiver when it's turned on I have no sound their is a mute auto light that's lit in the window....Tried changing the speaker wires with no results...
From the remote control only: Press MUTING to turn off the sound through all speakers and headphones connected. "MUTE" appears on the display and the volume turns off. To restore the sound, press MUTING again. Turning MASTER VOLUME or pressing VOLUME +/- also restores the sound.
Sep 01, 2011 | JVC RX-554V Receiver
Little or no sound JVC RX6010V
i had the same problem but i went to adjust settings and it says right speaker left speaker and you have to set them on ten
Jan 02, 2008 | JVC RX-6010V Receiver
221 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
