Question about Maytag 24 in. MDB4100 Built-in Dishwasher
Diswasher runs and cleans, the only thing that doesn't work is the gray water does not pump out. We have had this diswasher for a couple of years, first time this has happened. Is there a pump that may have gone out? Thanks in advance...
    Problem Solver:
  • 4 Answers
Have you recently installed a garbage disposal?? If so, your problem is most definately the plug where you attach the dishwasher hose to it. Before you attach the hose, there is a little plug in there that you have to knock out. Just disconnect the hose, stick a screwdriver or punch in there and tap it with a hammer. (Don't forget to remove that little metal plug from the grinder area) Then reattach the hose. Problem fixed!
Posted on Jul 10, 2010
No control panel lights on Bosch SGV43A03GB/17 diswasher
i have nearly the same problem ! but my one have no water left in it !but pump still running if i put bucket of water in it will drain it away but no lights on panel and anyone know what that is please ?
May 14, 2012 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Bosch Diswasher
Remove the drain hose and check if you have any residual into it. After 11 years your appliance may need a thourought cleaning.
Check also if the pump has enough pressure.
Apr 22, 2008 | Dishwashers
Diswasher water isn't draining?
It is most likely the drain pump. If the drain pump passes a tech's test ok, have the drain passage checked for clogs.
Apr 17, 2012 | Dishwashers
My diswasher has alot of water in it after we run the dishers thru. May be a clog? How can i check if there is a clog?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 19, 2011 | Hotpoint Dishwashers
The water will not drain out of the diswasher.
Hi
Daniel
Jun 16, 2011 | Dishwashers
I have an older model kelvinator dishwasher and there is water in the bottom of the dishwashwer and the diswasher will start and then stop but will go through all of the cycles. It just doesn't do the...
Pull the dishwasher out of the slot. There is a motor underneath that runs the pump to drain it. The usual cause is the it has a bad connection.
May 28, 2011 | Microwave Ovens
I have Frigidaire FDB956RBC1 diswasher. I have to turn off the water to fix the faucet. When I turned the water back on, water did not go to the diswasher when I used it. The diswasher runs normal except...
FRIDG... EXPERT HERE
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 19, 2011 | Frigidaire FDB956RB Built-in Dishwasher
Water valve not working and leak under dishwasher
The water leaking causes the float switch to activate the drain pump and as long as there is water in the pump housing area that is the only thing that will run.
Remove the water from below the unit and it should run long enough to trace the leak.
The easiest way to access this is to uninstall the unit and remove the lower back panel. remove the water wih a shopvac
remember to shut the power off.
Apr 01, 2009 | Viking Dishwashers
Diswasher doesnot drain the water out
Hi fahense,
I'm Harvey the Master Plumber.
Your problem is: diswasher does not drain the water out
If the motor runs but it won't empty then the pump needs replacement. If the unit washes but the motor won't come on to empty then you have a control problem. The pump is under and requires removing the d/w. The control is in the top of the door. You might consider utilizing the Repair Directory to find a repair man. If the d/w has some years on it you may compare the costs of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Dishwashers
Maytag 24 in. MDB4100 Built-in Dishwasher Logo
66 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
