Question about Electrolux Guardian Bagged Canister Vacuum
Vacum shuts down when suction starts
Vacuum shuts down when suction starts
  • 73 Answers
Try turning the knob on the top of the vac all the way to the right.
Posted on Aug 07, 2010
Suction stops when vacuuming with the DC40 model
There may be a clog where the air flows from the brush roll into the vacuum
Jan 29, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
Thehose has no suction
remove and clean the filter. you can use a air compressor to blow it out or use a brass wire brush and tap the filter on the table until it looks nice and clean,, this will return the suction to your vacume. also at the same time as you are cleaning the filter, check the hose for any blockage ( especially down by the floor sweeper where the hose kinda bends down into the unit ) -- when a filter is dirty and the suction is not that great, dirt loves to collect and compact in this spot,, use a wire coat hanger to fish out and clean any debris.
c...
Jan 05, 2011 | Dirt Devil 12 Amp HEPA Filter Vacuum...
While vacuuming, the unit will stop/shut down. A short time later the unit will operate again but not for much longer. All filters are clean/new.
Check your hose for a clog. It's likely there is a plug somehwere. Run it (not while vacuming the carpet) with all three filters removed. See if you get good suction. If not then look around for a plug of dirt and hair somewhere.
Jul 24, 2010 | Bissell 3750 Lift Off Bagless Upright...
I have no suction on the Lindhause healthcare pro Hepa
Make sure that the on switch is in the upright position. Down won't give you give you suction when vacuming.
Make sure that the hose is securly in the lower part of the vacuum.
Test the hose with your hand before you put it back to see if you're getting air sucked in through hose. If not it must be clogged up somewhere. You might contact Lindhause home base.
Feb 23, 2009 | Lindhaus Healthcare Pro 14 Bagged Upright...
Loss of suction bissell vacume
that is normal for the vacume to shut off if the motor overheats you must keep teh dirt cup clean and empty and all the filters clean, when you empty the dirt cup if you have a lot of pet hair take the hose off and make sure that it is clean as well, and do not try to pick up any of those cleaning wipes that will stop it up real quick
Sep 29, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
I just purchased a DC07 Dyson vacuum cleaner. It is not vacumming my floor - I have hardly any suction at all. Do I need to activate something in order to initiate the suction?
With vac upright suction is sent to the hose ie top of vac handle when handle is tilted down to the user vacuum position it should send the power suction to the floor also make sure collection bin it in securely that make be the problem
Sep 08, 2008 | Vacuums
Vacume Overheating
There will be a filter between the cylinder/bag and the engine. If your vacuum has a HEPA filter there will be one on the other side of the engine. Remove both of these and clean them out with water, allow to dry and replace.
Jun 18, 2008 | AEG Vacuums
Fantom vacuum
sounds like a partly clogged filter
Mar 10, 2008 | Fantom Vacums FM741 Twister Bagless...
Electrolux Guardian Bagged Canister Vacuum Logo
141 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
