Question about Kenmore HE3T Washer
F35 error code keeps coming up during every load. This is our second machine to do this. We had it replaced last year because the service technician couldn't figure it out. SUD also appears from time to time.
  • 5,081 Answers
The F35 indicates that the main control board detects a problem with the analog pressure sensor (water level pressure switch) in the washer. This component senses and controls water level in the washer. This failure could be caused by a pinched or broken air hose between the air trap at the bottom of the washer tub and the analog pressure sensor. It can also be caused by a clogged air trap or a failed analog pressure sensor. If you are able to unplug the washer and pull off the top panel, you can check for the probable cause of this failure.
To remove the top panel, remove the screws on the very back of the panel that secure it to the washer cabinet. Pull the top panel back slightly and then and off of the washer. It is on the side wall just behind the expansion control board. You can check the air pressure hose connection and the wire harness connection on this component.
This component costs around $99.This information was based on the general description of the washer model that you provided (Kenmore Elite front load washer). There are several different models of this washer.
The following link explains the error in more detail and how to correct:
http://www.fixya.com/support/r3608687-sud_error
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code can be generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
COURTESY:jsrock - A senior expert of fixya.....
Posted on Jul 05, 2010
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
I have kenmore elite HE5 front loading washing machine. it keeps flashing F35 during cycle and there is no help in the manual.
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 22, 2009 | Kenmore Elite 45986 Front Load Washer
F35 and Suds error on Kenmore Elite HE5t
I also got the SUDS error followed by F35 many times. I replaced the analog water level switch, Wirlpool part number W10156252, and the problem went away. The part is located against the back right corner of the top of the washer after removing the top cover. The part cost $62.99 + $12.95 express shipping from ApplianceZone.net. I have the Kenmore HE3t Steam Washer, model number 110.46752 700 front loader. I was able to run about 6 loads of laundry by unplugging the washer, waiting about 5 minutes, the re-plugging and re-starting the washer. Thereafter, the problem became permanent. I always used HE detergent. The washer was purchased new in December 2007, and the I made the repair in September 2009. I spent about $1300 for the Kenmore H3t Steam Washer, and I am disappointed that it required repair after less than 2 years. My mothers old Maytag washer lasted more than 15 years, and was not susceptible to soap SUDS.
Jul 20, 2009 | Kenmore Elite 45986 Front Load Washer
F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE5t Error Code F35
we have a kenmore HE2 Plus washer, front loader. been getting F28 code for last several months. usually we can push cancel button, and it clears, unlocks the door, we restart and complete the wash. But now it is locked and we can;t clear it. have even unplugged the machine over night, it still will not reset. any ideas?
May 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
He5t Kenmore ELITE front load washer flashing f35 code
Hi, Both of these fault codes point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after diong this, you will likely need to replace the pressure switch. If you have any further questions or concerns please feel free to comment again, Good luck.
Aug 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3T Washer Logo
188 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
