Question about Philips 32PT6441/37 32" TV
The picture on my tv went out as I was watching it and the power light blinks. What can i do to fix this? Why did this happen?
  • Philips Master
  • 1,216 Answers
You will have to install an horizontal timing kit. This is an approved authorization repair. The kit you will be using is, part number 483 531 057 673. Follow the instructions. Show this to a TV tech. Thanks for asking and good luck!
Posted on Jul 04, 2010
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Same thing happened to me
Well, no sound no picture = power supply unit
Sound no picture= flyback
picture no sound =tuner/audio logic
You get my drift?
You power supply is bad you replace it you got another new TV, with this digital conversion hitting I would rather advise you to get a nice flat panel and donate that one to Goodwill
Jun 13, 2009 | RCA F32650 32" TV
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Tv goes off then red blinking light comes on
Hello it is the bulb the bulb's on the Rear projection tv are ****. Buy  new tv cause it costs alot to have these tv fixed.
Jan 10, 2009 | Sony KP-46WT500 46" Rear Projection...
JVC TV WENT OFF. TURNED IT ON AND THE LAMP LIGHT STARTED BLINKING
If the Fan is clogged up with dirt set will not run fan must be working.
Dec 01, 2008 | JVC AV-30W776 30" TV
TV and Vedio-Projection televisions
what i would do is crack into the tv and watch the individual parts being careful not to unplug anything while you take the back panel off.....turn it on and see what happens. let me know what happens
Sep 30, 2008 | Televison & Video
Toshiba theaterview tz50v51
my guess would be flyback however your lucky you might be able to see a burnt spot on the board giving you a better clue.
Nov 25, 2007 | Toshiba 55H70 55" Rear Projection...
No picture, just went off while watching tv
The pink lines in the set happened when the first time it blew out. It is called a burn in on the inside surface of the picture tubes. Not the fault of the TV repair guy. This is the fault of Toshiba. This set has known to have this happen and you should contact toshiba and request that they replace all three tubes for you at no cost. You should also stop using these repair guys who cannot fix a simple vertical problem. Find out who is authorized for Toshiba in your area and call them. They will know, or should know the problems that happens with this model number and take care of them once and for all. Good Luck
Nov 06, 2007 | Toshiba 51H84 51" Rear Projection...
Green flashing light - no picture
If the green power light is blinking and you have no picture, then your light bulb has burned out and needs to be replaced. It is not a cheap bulb to replace. If the TV is less than 1 year old it should be covered by the warranty
Nov 03, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Philips 32PT6441/37 32" TV Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
