Question about Solar Rheem Gas Fired Pool & Spa Heater Model P-m266a-en-c
Rheem digital gas pool heater fan code
Rheem digital gas pool heater "fan" code?????
also had "cfh" code
heater worked fine yesterday, but won't work today. either wont ignite, or seems to ignite and run fine for a minute or two, the get "FAN" code and can still smell the gas
  • 760 Answers
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Posted on Jul 05, 2010
Why does pool heater read SPK and won't light?
Sounds like your ignitor is shot. You may have to replace it.
Jul 24, 2014 | Rheem Water Heaters
What does CFH mean
this is not an error code. it means a call for heat. the pool water temp is colder than your tstat set point
May 25, 2014 | Rheem 266K to 399K BTU Swimming Pool...
Heater takes a long time to fire up.
There is a flow switch if that's not working. same problem needs to be tested Gas valve solinoid could cause this Igniter could cause this problem Gas pressure regulator wrong pressure should be about 2.7KPA LPG Gas valve should be set to about 2.6 KPA LPG
Mar 28, 2013 | Rheem M206A 206K BTU Pool and Spa Propane...
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have model # p-m267a-nc-c it comes on I git error cfh then after a while i git hl2 and it wont heat after that. HELP Please TKS
"CFH" is Call for heat. That means your heater is trying to fire (not an error code). "HL2" is an error code which stands for "High limit #2". This error means the water in the heat exchanger is too hot,and the heater shuts itself down to prevent damage. Most common causes are poor water flow .Make sure the correct pump is running,and you have at least 10psi on the filter gauge. also be sure that the bypass valve is at least 1/2 way closed.The Bypass valve is located on the return line after the filter just passed the first tee.
Oct 12, 2010 | Rheem 266K to 399K BTU Swimming Pool...
ROL Fault code
replace fusible link and check gas pressure and for burners clogged
Jun 06, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Solar Rheem Gas Fired Pool & Spa Heater Model P-m266a-en-c Logo
1,062 people viewed this question
Top Solar Pool & Spa Experts
Jay Finke
Jay Finke
Are you a Solar Pool and Spa Expert? Answer questions, earn points and help others
