Question about SanDisk Sansa View 8GB MP3 Player - Black
Wont switch on
The sandisk will not turn on even though the battery is not flat.
Prior to this happening,,it was showing to be empty even though it had hours of music on it.
  • 17,129 Answers
Please try to reset your sansa using the reset, there is a small hole in the backside of the sansa, reset the button by using a small office pin. the sansa should come back to action, if not connect to the PC, open the memory and check the files, delete off all unwanted files, rest and check again, Helpful? good day
Posted on Jul 05, 2010
Emptied the hoover and now it wont switch on
The switch that is activated by the canister is your likely culprit based that it was working prior to emptying. Youtube has a quick video on this solution.
Jan 13, 2014 | Hoover Turbo Power Long Reach Pets Utp1605...
My sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
Mp3 player shows that battery is dead even though its charged and the screen only works if i hold the on off switch the whole time
try inserting the charger to a different socket until it works. if not you might be having problem with the charger. not the mp3 player and if you already triedto change the charger you might be having problem with the battery of your mp3 player ok send me a message for more concerns.
May 04, 2009 | SanDisk Sansa m240 MP3 Player
MY SANSA HAS BEEN STUCK IN THE REFRESH DATABASE MODE AND WILL NOT TURN ON NOR OFF . IT WONT EVEN CHARGE EVEN THOUGH IT IS SHOWING A FULL BATTERY HELPPPPPPPPPPPPPP THANK YOU MRS.C.L.C.
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa e250 MP3 Player
Song's won't load, even though the files show
Yeah, the songs are in the wrong format for your player.There are some DRM-protected songs that allow you to play the song on your computer, but they won't actually play on an mp3 player even though they appear to transfer. If you download ALL of your songs in mp3 format, you will never have this problem.
-Tha Mp3 Doctor
Feb 01, 2009 | SanDisk Sansa e250 MP3 Player
Ipod touch wont switch on even though its fully charged
hold the middle button in and at the same time hold in menu for about 10 seconds to reset it.
Jan 23, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Wont switch on
Same thing happened to me and I freaked out. Sit it on the charger overnight and then try to turn it on. Basically, what happened with mine was I had completely drained the battery to the point that, even though it was charging, it didn't have enough juice in the pack to turn itself on. If this doesn't work, then try resetting (use the end of a paper clip to push the "button" next to the area where the USB plugs in. If that doesn't work, try Archos tech support.
Dec 15, 2008 | Archos 605 WiFi Digital Media Player
Nothing happens when I click on Menu button
SanDisk Sansa View - Reset - Use the slide switch on the side and hold it tward the Mic hole for 10 sec. Start the computer program before you plug in the View??
Jan 20, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
It overheats and wont turn on even though battery is full
You need to contact sandisk so they can RMA your device..there isnt anything wrong your firmware...it is the device itself..so call them to see if they can set up and RMA for you...
Jan 02, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk 250
ok this is weir this exact same thing happened to me this morning and i was on here looking for help and i came across your post i also went to ten sandisk website and found some helpful info. i just tryed it and my player is fine so what you have to do is take the back off of your player the four screws need to come out then take it off and you will see the battery it looks just like a cell phone battery take it out and put it back in its simple then your player should turn on. let me know if i was helpful my email is applebottem_ME@yahoo.com
Mar 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa View 8GB MP3 Player - Black Logo
214 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
