Question about Intel Desktop Board D865GBF (MBIND865GBF) Motherboard
Code that uses sound version of what drives ??
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 308 Answers
Looking for drivers i guess.
follow the link below and look for the files driver pack. download, extract and read the text file in it for instractions.
good luck
Posted on Jul 04, 2010
Hi, i have a Media Dashbaord 525A and all the USB and sound slot work. But, when i want to use for the SD card it failed.
Which version of Windows are you using ? My Dashboard started to perform better when I changed the drive letter to 'A'
May 09, 2017 | Cameras
Reinstalling autodesk bc legal version 2011 and getting error code 112 hard drive failure
Since the problem is with the drive you must try to opt for other methods of installation as the version you are using is legal then the auto desk may have all the appropriate alternatives doing it in any other way.
https://www.structuredsettlement-quotes.com/
Dec 31, 2013 | Computers & Internet
I want all secret cod of nokia n72 and all software code plzzzzzz thank you
*#06#
To check the IMEI.
*#0000#
To check the firmware version and date
*#92702689# *#war0anty#
To check the IMEI. The date when it was purchased
and the date when it was repaired.
*4720# (*hra0#)
To activates the Half Rate.
#4720# (#hra0#)
To deactivates Half Rate.
*#3370# (*efr0#)
To activates Enhanced Full Rate.
*#746085685# (*#sim0clock#)
To check the SIM clock status.
*#7220# (*#pca0#)
To activate the GPRS and Packet Common Control
Channel(PCCCH) supports.
*#7230# (*#pcd0#)
To deactivate the GPRS and Packet common control
channel (PCCCH)supports.
*#7760# (*#ssn0#)
To check the manufacturing serial number.
*#2820# (*#bta0#)
To check the Bluetooth MAC address
(Phone must have a built in bluetooth adapter).
*#7370925538# (*#res0wallet#)
Reset the mobile wallet.
NOKIA PHONE CODES :
Nokia Codes : *3370#
This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
Nokia Codes : #3370#
Deactivate Enhanced Full Rate Codec (EFR)
Nokia Codes : *#4720#
Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
With this Nokia code you can deactivate the Half Rate Codec
Nokia Codes : *#0000#
Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
Nokia Codes : *#9999#
Phones software version if *#0000# does not work
Nokia Codes : *#06#
For
checking the International Mobile Equipment Identity (IMEI Number)
Nokia Codes : #pw+1234567890+1#
Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
Nokia Codes : #pw+1234567890+2#
Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
IDRISH 911
Nov 11, 2010 | Nokia N72 Cellular Phone
Wont let me play says send error report
Well most xbox units in the US will have a code with the xbox error report, you need that code when calling microsoft customer support at 18004myxbox. If it goes to a black screen and gives an error code here is a list of known codes.
E45: Unknown (possibly dashboard update related)
E64: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
E66: DVD Drive Error: DVD model, or version does not match that of the version expected by the dashboard. OR the firmware version on the drive is older then the firmware version expected by the dashboard. Make sure the DVD drive is of the same version originally included with the console and that it is using either the original firmware included with the console or newer.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
E72: (not yet known)
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
E76: (not yet known)
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
If the xbox is telling you something is wrong via the rings of death just make note of what the colors were and where they were.
Sep 10, 2010 | Microsoft Xbox 360 Elite Console
Drive problem
What sound device is you motherboard manufacturer using, i.e.;AC97, nVIDIA, etc? Check to make sure you have installed the Int'l version of the manufacturer driver for your particular sound board
Mar 26, 2009 | Computers & Internet
ERROR: 573/#https://home.tomtom.com/shop/onetimeDeviceUpdates: Error from server: You have an invalid version of the TomTom application installed on your TomTom device. To use HOME you need to install the...
Go to My Computer, then the TomTom drive and click explore. Move your Map folder to the desktop. Then, delete everything on the tomtom drive. Unplug it, plug it back in, and start up Tomtom HOME and install all updates, keep unplugging, plugging back in, and installing updates until there aren't any more updates. Then move your map folder back to where it was on your TomTom drive.
Please rate, Thank you!
Dec 27, 2008 | Tomtom ONE 3rd Edition GPS
Purchased office 2007 key code online...
it sounds like the product on your pc is not the same as the one that you purchased the code for.
EG.
there are many different releases of office 2007:
pro
home and student
small business
standard
then for each of these releases there is the standard retail version or the OEM version.
I would say you did not purchase the correct key for the version that you have.
Nov 16, 2008 | Microsoft Office Professional 2007 Full...
I have a valid code for Office 2007, but need help
You need to activate it. Install it, open word and the product should start the activation process. You will be prompted to activate on the Internet or the phone, use the phone. You will be given a phone number and a long number call Microsoft you will get to a rep and tell them about what happened with your hard drive. They will give you an activation code.
Nov 15, 2008 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
